dyno numbers w/ turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 07-06-2010, 08:11 PM Thread Starter
kellam's Avatar
so it seems i diddnt get the memo about how well the on3 kit was untill i bought a different more expensive kit. so anyways i have a cartech ss kit 60/96 turbonetics turbo. can anyone tell me what people were making when they used this kit. i looked at old post but its seems inconclusive.
89 gt turbo- R.I.P - f#@K TURBO GOING OLD SCHOOL CARB AND NITROUS...... BUILD IN THE WORKS.
kellam is offline
post #2 of 15 Old 07-07-2010, 04:52 PM
Cansogo's Avatar
Cartech......Wrong Forum!!......Try TM...Ha Ha
People on here are only good at guessing On-3 kits Boost is Boost!!
Late 30's not so fat anymore white guy drivin a Turbo 5.0.....15 years TOO late
09' G8 GT tune & 100 shot 12.2's
67 Nova LS1 MS3 150 shot...11.2's
2003 pink Barbie jeep....Cause the girls LUV it!
Cansogo is offline
post #3 of 15 Old 07-07-2010, 05:28 PM
ratedz's Avatar
LOL - hey the On 3 kits are the latest 'trend' around here.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #4 of 15 Old 07-08-2010, 04:18 PM
nmcgrawj's Avatar
Boost is boost? So cam choice doesnt count? Intake? Header design? Exhaust system?
Without knowing the entire combination this question is impossible to answer.
-Nate
'95 GT
nmcgrawj is offline
post #5 of 15 Old 07-08-2010, 07:29 PM
Put it on and then tell us. Guess my power numbers has been covered a million times. It depends on your setup, tune, what dyno your on, lbs of boost, etc.... There is nobody here that can tell you how much power your going to make.
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #6 of 15 Old 07-08-2010, 07:46 PM
Bobo's Avatar
Well I had that kit with a Precision 63mm. Never dynod or tuned other than by track times and feel. At 17 psi (at the top end with boost creep, turbo probably maxed out) it ran 110 mph in the 1/8 and about 3250 lbs. Simple stock block, lil cam, TW's, cobra int, c4, 3.73's on 28" et streets.
110 in the 1/8 should be almost 140 in the 1/4 (assuming it would have made it out alive after that second 1/8 lol), so the math says it was well over 600 hp with a hillbilly tune. Not sure if that really answers your questions, but hope it helps some.
Scotty we need more power!!!
Bobo is offline
post #7 of 15 Old 07-10-2010, 09:02 PM Thread Starter
kellam's Avatar
thanks for the info. i guess we will see. hey does anyone have any issues with open down pipes? thats about if for my exhaust.
kellam is offline
post #8 of 15 Old 07-10-2010, 09:54 PM
Open D/P isn't as loud as open headers... But my taste is full exhaust with tails
93coupee is offline
post #9 of 15 Old 07-11-2010, 03:39 AM
ratedz's Avatar
Wow - maybe I should put a match to my car.
100lbs lighter, low 1.4 60's, much better heads, better intake, C4, bigger turbo, etc.... but i'm only getting 105 in the 1/8th
You must have run some fairy dust mixed in with your gas.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #10 of 15 Old 07-11-2010, 10:30 AM
WHITEMACH's Avatar
Trader Feedback: (23)
had a cartech ss kit with a t-64 and dart sr iron heads stock cam,gt-40 intake mads @13psi 535rwhp 622rwtq with a anderson PMS,,,3 INCH MAC CATBACK.
2012 GT AUTO
bbr tune ,bbr x-pipe,jlt cold air
[email protected]
WHITEMACH is offline
post #11 of 15 Old 07-11-2010, 10:33 AM
1995gtCPE's Avatar
Trader Feedback: (34)
What did it run?
1995gtCPE is offline
post #12 of 15 Old 07-11-2010, 02:04 PM
WHITEMACH's Avatar
NITTOS 1.9 60FT 11.32 @ 126 full interior, cobra r rims, ac/ps/everything,,90 GT TKO600 3.27
2012 GT AUTO
[email protected]
post #13 of 15 Old 07-11-2010, 02:10 PM
1995gtCPE's Avatar
I would have thought the mph would have been higher. Every car is different I guess.
post #14 of 15 Old 07-11-2010, 05:02 PM Thread Starter
kellam's Avatar
how many years ago was this? and what engine build did you have then?
kellam is offline
post #15 of 15 Old 07-11-2010, 08:42 PM
Bobo's Avatar
Not unless the shop I got Turbo Blue at did so. I did have a lucky rabbits foot though.
I may have been running on the ragged edge of lean, never had a wideband on it, but didn't ever hurt anything. Timing was 10 base, so total timing may have been higher than many combos I've read about.
Bobo is offline
bg turbo kit dyno numbers 95mustang_gt Turbochargers 26 11-09-2009 09:45 AM
Turbo Mustang Dyno numbers? 03silverterm8r Turbochargers 23 10-30-2008 07:55 AM
New dyno numbers with 76mm turbo 9946nos SVT & DOHC 45 02-12-2004 05:21 PM
Dyno'ed my Turbo Stang yesterday...how do the numbers look?? South Jersey Stang Turbochargers 5 06-26-2003 02:15 PM
dyno numbers on twin turbo 4v are in sneekygt SVT & DOHC 9 06-24-2003 09:26 AM
