Turbo Fox AOD Question?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 07-05-2010, 08:29 PM Thread Starter
bod89lx's Avatar
Trader Feedback: (88)
Just wondering what you guys are running for trans lines and what trans cooler you are running in your street driven foxbodys with a Turbo.
2013 GT500 SGM \Black Stripe.
2003 Cobra Redfire
1986 GT 408W C4 T-Top Factory Paint
2013 Ram 2500
bod89lx is offline
post #2 of 11 Old 07-05-2010, 10:00 PM
I bought a b&m stacked plate style cooler and running a
-6 gates push loc style hose
93coupee is offline
post #3 of 11 Old 07-05-2010, 10:12 PM Thread Starter
bod89lx's Avatar
What did you use for the fittings on the trans if you remember, I need to order some and not sure what size the threads or what angle to get. any help would be great.
2003 Cobra Redfire
2013 Ram 2500
bod89lx is offline
post #4 of 11 Old 07-05-2010, 10:27 PM
firemanwill28's Avatar
Check the Click Click racing site; thats where I found all my AOD information. Its the Corral site of Ford auto transmissions.
1990 Coupe, 302/AOD, stock cam/short block, AFR 165's, 3.55's. Working on a N/A stroker build.
firemanwill28 is offline
post #5 of 11 Old 07-05-2010, 10:41 PM Thread Starter
bod89lx's Avatar
2003 Cobra Redfire
2013 Ram 2500
bod89lx is offline
post #6 of 11 Old 07-05-2010, 11:14 PM
I just used the biggest cooler I could get at Autozone, ran steel line, used a bender and flared fittings, works good so far
mallen13 is offline
post #7 of 11 Old 07-06-2010, 08:42 AM
I used straight fittings the screw in the tranny then I bought 4 -6 90* pushloc fittings and all fit great I can get you some pics if u like... I'm not using an aod but a c4 but I'm sure it's the same concept
93coupee is offline
post #8 of 11 Old 07-06-2010, 09:35 AM Thread Starter
bod89lx's Avatar
Thanks, some pics would be great if you dont mind, send to [email protected]
2003 Cobra Redfire
2013 Ram 2500
bod89lx is offline
post #9 of 11 Old 07-06-2010, 05:38 PM
I'll get some for you tomarrow
93coupee is offline
post #10 of 11 Old 07-06-2010, 06:58 PM
331merc's Avatar
Hard or braided lines are always a smart way to go for trans lines. Being trans fluid is so flammable you don't want any hoses slipping off or barbed fitting or holes burned through a rubber line. Being the exhaust is usually in close proximity it is a good idea.
The trans uses 1/4" npt fittings. So 1/4" npt to -6 would be a good choice. I believe I used 45 degree fittings and 45 degree hose ends to get a good compromise of tight fitting to the trans and easy of install of the lines.
The trans cooler should be a "par and plate" cooler for best performance. I tried the largest B&M Supercooler but it did not fit. Because of that reason I used two of the next smaller B&M Supercoolers hooked in series. It is slightly more surface area than their largest cooler. Worked out great.
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
post #11 of 11 Old 07-12-2010, 01:43 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
X 2 I used braided -6 line to and from the trans to the cooler. Just so close to a lot of the hot side I wasn't going to take a chance.
I'm currently using a cooler that came off a older F150 pickup truck. Not a lot a space to work with thats for sure!
NC STANG GUY is offline
Another turbo question Prochargedsnake SVT & DOHC 2 09-24-2009 08:03 PM
HP turbo kit question... 5.0fox Turbochargers 6 06-09-2008 09:35 AM
Yet another turbo question..... TFScoupe Turbochargers 2 11-16-2006 04:31 PM
turbo question mustang9989 SVO/2.3L 4 09-25-2005 08:46 AM
Turbo Question on a 97 GT TSD97GT GT & SOHC 0 10-09-2002 03:18 PM
