A Couple Questions, Fuel Pressure and Spark Plug Gap. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-05-2010, 01:00 AM Thread Starter
Blk4V00GT's Avatar
Ok so a couple quick questions, where should I gap my plugs? Stock 97 4v engine w/ .70 On3 Turbo Kit.
Second question is fuel pressure, my car was originally a returnless car that I am comverting to return. What fuel pressure should I run in just my base tune to get to the tuner? I will not be getting on it or driving in boost (if possible) but have no idea where to set it at just to start and drive the car.
Thanks for the help
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #2 of 5 Old 07-05-2010, 09:24 AM
The stock fuel pressure is right at 40lbs, I would start there on the pressure to get it running. Hopefully you have some kind of boost reference for the regulator to up the fuel pressure as boost rises. As far as the plugs, I'd try .035 and see if it breaks up under boost. The gap is going to be something you have to play with depending on what ignition you have, which plugs and how much boost.
Bunch of new stuff lol.
fastwhite99gt is offline
post #3 of 5 Old 07-05-2010, 12:35 PM
2002mustanggt's Avatar
When I was at 8psi I gap mine to .30 with NGK TR6
2002mustanggt is offline
post #4 of 5 Old 07-05-2010, 02:52 PM
you have a aeromotive regulator that is probably 1:1 ratio bosst reference. basically you just need to set idle pressure. having a little more is not going to hurt you, what hurts is lack of continuous pressure under boost. your engine usually runs between 38 and 40 psi at idle. the key is to have a bump of 1 psi of fuel to 1 psi of boost. i set my regulator at 40psi. your vacuum line should be hooked up after the throttle body. on the intake somewhere. as for your spark plugs, i would gap them to .030 and go from there. i run NGKTR6 plugs. never had a issue with them.
jaxboostedGT is offline
post #5 of 5 Old 07-05-2010, 03:17 PM Thread Starter
Blk4V00GT's Avatar
Okay thanks guys, I figured 40psi and 30 gap so I guess I was right just wanted to make sure. Thanks again
Spark Plug Gap/ Resistance/ Timing/ Fuel Pressure DarkMesa8 5.0/5.8 Engine Tech 5 07-18-2010 10:41 AM
spark plug questions bradbrenn 5.0/5.8 Engine Tech 9 07-07-2006 08:48 AM
spark plug questions. WICKED87COUPE 5.0/5.8 Engine Tech 2 05-10-2006 01:43 AM
couple spark plug questions Blivit GT & SOHC 0 07-08-2003 11:28 AM
Couple questions on spark plug reading and fuel mixtures... superirish 5.0/5.8 Engine Tech 4 11-19-2002 05:00 PM
