Gt40 heads??????????? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 07-02-2010, 09:21 PM Thread Starter
conbread's Avatar
Trader Feedback: (60)
how much boost and what kind of gaskets are you guys running with the iron gt40 heads..
mine made 469 with 13psi yesterday,but is starting to pressurize my cooling system... It has studs on it but nout sure what gaskets,the motor was in the car whe i got it...
conbread is offline
post #2 of 21 Old 07-03-2010, 12:05 AM Thread Starter
conbread's Avatar
ayone???? are they just thin??
conbread is offline
post #3 of 21 Old 07-03-2010, 04:15 PM Thread Starter
conbread's Avatar
well i must be the only one with gt40 heads..i took it apart today and both side had pushed into all of the coolant ports..It had the felppro 9333 gaskets on it..I wonder if a 1011-2 or a cometic will fix it??
conbread is offline
post #4 of 21 Old 07-03-2010, 04:48 PM
nmcgrawj's Avatar
whats the difference with 9333 and 1011's?
-Nate
'95 GT
nmcgrawj is offline
post #5 of 21 Old 07-03-2010, 05:01 PM
nmcgrawj's Avatar
I'd check out these victor gaskets if i were u....
http://www.mustangsandmore.com/ubb/F...ML/009130.html
NGA3428SG $45.99
On 2nd thought, i cant find these.
Everyone on turbomustangs(theturboforums) recommends the 9333s.
-Nate
'95 GT
nmcgrawj is offline
post #6 of 21 Old 07-03-2010, 05:28 PM
nmcgrawj's Avatar
On 3rd thought, the guy from that site just emailed me back (within 10 minutes actually....customer service looks outstanding)
Hi Nathan,
Yes they are made.
We have over 20 in stock.
$60 each plus shipping.
Napa no longer carries VIctor.
We accept any CC except AMEX.
We also accept pay pal.
- Show quoted text -
Nathan
Alex Denysenko
Moneymaker Racing
6646 1/2 Johnson Rd
La Porte IN 46350
Phone: 219-861-1214
Fax: 219-871-0755
www.moneymakerracing.net
www.moneymakerracing.com
-Nate
'95 GT
nmcgrawj is offline
post #7 of 21 Old 07-03-2010, 05:45 PM
I am running the Felpro 1011-2's with ARP bolts on 302 w/GT40P's for 2 years now, with 15-17 lbs boost and no problems. I do not race it, but it gets the #### stomped out of it almost everytime I get in it.
Made 486 rwhp on the dyno last August in 96.57 deg heat!
Orginal stock shortblock.
500HPLX is offline
post #8 of 21 Old 07-03-2010, 06:26 PM Thread Starter
conbread's Avatar
all my car was just pressurizing the cooling system,i see some people say no more than 10psi with iron heads, but you say you are running 15-17psi and she is living...maby i can give it anther shot with thses and a 1011-2 gaskets...
i could drive it all day long and it was fine until i made some boost,then it would fill up the overflow...
conbread is offline
post #9 of 21 Old 07-05-2010, 12:00 AM
jturmanator's Avatar
Been beating mine up for over a year now with Fel 9333's. I also wonder how much boost mine will take before she spits out parts. Combo in sig.
jturmanator is offline
post #10 of 21 Old 07-05-2010, 10:24 AM Thread Starter
conbread's Avatar
keep pickng it up until it spits,LOL!!!! im going to try them again...thanks for the help guys..
conbread is offline
post #11 of 21 Old 07-06-2010, 03:00 PM
goatnipples2002's Avatar
Trader Feedback: (22)
I run 11-12psi through dooe heads (same as gt40s...kinda). No coolant problems. I run felpro stock replacements and e85/F-cam. In the process of switching out for the eddy heads and felpro 9333s right now.
How did you tune it? Sure it didn't detonate and you just found it?
goatnipples2002 is offline
post #12 of 21 Old 07-06-2010, 04:49 PM Thread Starter
conbread's Avatar
well it may have detonated before i got it tuned, because i took it out to see where the wastegate was but it had the spout out and was on 10 degrees...i know pumpgas will very from place to place, so it will just get race gas until i can get some good heads...I also took out 1psi of boost..
conbread is offline
post #13 of 21 Old 07-06-2010, 06:02 PM
Iron heads and amount of boost is not really related or not near as much as deck thickness. I ran 18lbs with iron Dart Sr heads and never one single issue. I ran 12lbs with old school gt40 heads and had a lot of issues. My issues though were from the heads being milled down and causing me to have an even thinner deck. In both cases I ran the old felpro 1006 gaskets.
post #14 of 21 Old 07-06-2010, 07:45 PM Thread Starter
conbread's Avatar
true!!! they do make good iron aftermarket heads, it's just this stock style junk we try to play with.. lol!!!!
conbread is offline
post #15 of 21 Old 07-06-2010, 10:03 PM
Bobo's Avatar
Yo Aaron! You got any idea how thick the decks are on say AFR 165's or TW's? I ran TW's w/o problems before, but I thought about maybe trying AFR's this time.
Scotty we need more power!!!
Bobo is offline
post #16 of 21 Old 07-06-2010, 10:08 PM
Bobo, I do not know anything about the AFRs. I have seen a number of people run various AFR selections but just never bothered to learn anything about them. Matter of fact I think perhaps Trent first ran them with his old turbo GT but I could be wrong on that. I'd hope the deck is just fine on them and the bigger worry I'd have is what would the compression ration be with them.
post #17 of 21 Old 07-06-2010, 10:21 PM
Bobo's Avatar
I thought Trent had some head problems back in the day, maybe it was with iron heads? I forget now
I think the TW's are 61 cc and the 165's 60 cc. I actually bought a set of 205's years ago....I think I was going to build a 408...I think lol. Damn memory. OCD + ADHD and I can't keep up with myself. But I haven't looked much at the smaller heads.
For some reason I've decided to almost redo a combo I did 10+ years ago, but maybe with some better parts and newer technology.
Bobo is offline
post #18 of 21 Old 07-06-2010, 10:23 PM
He always had Al heads, but I think he started with AFRs but I might be wrong. I'd go with opened up TWs.
post #19 of 21 Old 07-06-2010, 10:55 PM
Bobo's Avatar
Oh sorry to hijack the thread Conbread I know my buddy kept blowing gaskets with his GT40 irons and a Vortech. So that's not much info for your questions, but maybe you can save up for some aluminums that'll make more hp and hopefully keep you from opening up the motor again. More powah!
Aaron, I loved my old TW's, but I'll study up a bit on the 165's as I kind want to give them a chance. I thought the 185's were more along the lines of the TW's, but require fly cutting (not sure if I'd want to try my hand at that).
Bobo is offline
post #20 of 21 Old 07-09-2010, 01:08 PM
privatejoker's Avatar
Time to consider having them O-ringed.
privatejoker is offline
post #21 of 21 Old 07-09-2010, 01:58 PM Thread Starter
conbread's Avatar
no problem here buddy...that is my plan to try and save for some alum heads, but mabey some racegas will help me keep these headgaskets on..
conbread is offline
gt40 x302 heads vs. gt40 iron heads stangin' 5.0/5.8 Engine Tech 26 08-01-2009 12:32 AM
gt40 x302 heads vs. gt40 iron heads stangin' 5.0/5.8 Engine Tech 0 04-13-2009 11:49 AM
GT40 heads, GT40P heads, GT40(Explorer) intakes TommysCarbd86 Windsor Engine Parts 8 12-06-2008 10:27 PM
WTT: gt40 aluminum heads for gt40 iron heads mutiger93gt Windsor Engine Parts 2 09-28-2007 09:26 AM
complete 306 with gt40 heads(cobra)gt40 intake(tubular) good deal mygreengt Windsor Engine Parts 5 04-29-2007 05:33 PM
