351w and 10.5:1 CR.... How much Boost?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 22 Old 07-02-2010, 12:04 AM Thread Starter
Ok I want to try turbo....
Current Setup of my car is telling me i have everything i need except the right cam and the right Compression Ratio
I have a a .030 over 351w with 10.5:1 Compression.
My Cam is the medium sized XFI CAM by comp cams.
I think .580 lift and 236int/248exhaust and a 114 lobe sep.
Im thinking i could run 10#s with an On3 kit (talked to them today).
I do realize i would most likely have to run meth injection to get this boost??
Otherwise, Im thinking it would make some good power??
Please let me know what you guys think...
91 coupe 65k miles - 428w 9.5:1 compression, TFS 225cnc HP, Accufab Midlengths 3 inch Mac exhaust. FTI Cam, super victor EFI, 60lb injectors - TKO600
94 cobra...Cobra R clone with stock 302cobra motor.
red93notch is offline
post #2 of 22 Old 07-02-2010, 03:29 AM
If you really have 10.5:1 CR and if you have accurate numbers for your cam and if your cranking compression isn't too high and depending on what heads and intake you are running and depending on what size your turbo is and depending on what size your down pipe and exhaust are you should be able to run 91 octane. Oh, try not to use a meth kit. They are a waste of money in the end.
nealysa is offline
post #3 of 22 Old 07-02-2010, 07:43 AM Thread Starter
I'm running Victor Jr heads and Victor efi intake.
What about using some nitrous as a cooling benefit?
post #4 of 22 Old 07-02-2010, 08:05 AM
smurfmobile8586's Avatar
DD. Or a track car ? Sounds like it will make killer power
smurfmobile8586 is offline
post #5 of 22 Old 07-02-2010, 08:49 AM Thread Starter
Track car. But I will drive it 40 miles o the track.
post #6 of 22 Old 07-02-2010, 08:52 AM Thread Starter
I intend on maxing out my fuel system
post #7 of 22 Old 07-02-2010, 12:27 PM
UJUSTLOST's Avatar
Could always go the E-85 route. It would make some serious power on that stuff.
UJUSTLOST is offline
post #8 of 22 Old 07-02-2010, 01:17 PM Thread Starter
actually that is a great idea... not much e85 around here.
I would need to change my fuel system though wouldnt i?
I have an a1000 pump with regulator and 8AN and 6an Braided steel line.
thanks for the help and ideas... still learning about the turbos
post #9 of 22 Old 07-02-2010, 03:51 PM
UJUSTLOST's Avatar
You could be alright with your current fuel system, it all depends how high you want to push it.
post #10 of 22 Old 07-02-2010, 08:15 PM Thread Starter
What about corrosion with the e 851 I plan to push the motor as hard as. It will go.
If the pump will get me there I want to run in the high 9s with the aod.
post #11 of 22 Old 07-02-2010, 08:18 PM Thread Starter
post #12 of 22 Old 07-03-2010, 12:27 AM
UJUSTLOST's Avatar
Not the first time I have heard the corrosion thing. They are running e-85 in new production vehicles which are composed almost entirely of aluminum and other alloys. If GM builds a car to run on e-85 that is made up of a bunch of aluminum alloys, I would imagine that the e-85 has corrosion inhibitor in the fuel to prevent it from destroying your aluminum components. I know 2 guys personally that run it with aluminum heads and intakes, they have had no issues. I honestly dont think corrosion is an issue with e-85 like it is with methanol. e-85 may be less corrosive due to the extra carbon molecule that ethanol has over methanol. I am not a chemist but had a bit of organic chemistry in college and I know methanol is a one carbon alcohol and ethanol is a 2 carbon alcohol. Perhaps that second carbon makes it less corrosive. Either that or they put a corrosion inhibitor in e-85 so it wont eat up all the new GM vehicles on the road.
post #13 of 22 Old 07-03-2010, 12:42 PM
Definitely look into the E85 route... I know of many guys down in south Florida running it and having great success... Just remember to need to factor about 30% more fuel (injectors, pumps, etc.) for E85. I plan to go the same route once I can find a consistent vendor.
1fast89 is offline
post #14 of 22 Old 07-03-2010, 09:00 PM Thread Starter
I don't think 60 # injectors is going to support enough fuel for the setup
post #15 of 22 Old 07-04-2010, 01:06 AM
UJUSTLOST's Avatar
I thought the same thing until I saw a guy running them with a similar setup. Personally I would go with 80+ # injectors.
post #16 of 22 Old 07-04-2010, 12:49 PM
Wow... duty cycle must have been 99% at WOT... Seriously, I have 60# with my 357/T70 combo and I think I figured I needed around 80's for mine when factoring in the additional fuel.
1fast89 is offline
post #17 of 22 Old 07-04-2010, 12:50 PM Thread Starter
I have 60# injectors already. I think i should try that.
E85 will most likely be the next step. I will be talking to a local guy in this area that has completely converted to E85 to see what he says i need to go with.
I will be tuning with an anderson PMS and im hoping that is all i will need.
post #18 of 22 Old 07-04-2010, 01:34 PM
guys are running that compression with turbos all the time. Gonna have to limit yourself to 6-8psi and knock the timing back a lot. Its all in the tune
rbonella is offline
post #19 of 22 Old 07-04-2010, 02:08 PM
the 60lbare good for about 650 to 700 @ the wheels
st pete chad is offline
post #20 of 22 Old 07-04-2010, 05:04 PM
68 Mustang's Avatar
yep I agree, 6-8psi should be safe for your compression
1968 Mustang GT, 302.
1992 Mustang GT, 347 trickflow top end
68 Mustang is offline
post #21 of 22 Old 07-04-2010, 06:04 PM Thread Starter
And how much could I run if sprayed nitrous also
post #22 of 22 Old 07-05-2010, 05:36 PM
60's will be fine...I have a 357 with a T70 running around 10lbs with 60's (running regular pump gas). Of course, if you go with E85, you'll need more injector. I was tuning with a PMS, but ditched that and went with a MegaSquirt II.
Is that taking the E85 into consideration?
1fast89 is offline
351w pan to intake ready for boost P&P Windsor Engine Parts 24 06-15-2010 12:33 PM
351w for boost. Overhere 5.0/5.8 Engine Tech 17 10-11-2009 11:03 AM
351w ringed for n/a; boost OK? couperdude Superchargers 2 05-15-2009 01:52 PM
351W bottom end for boost FoMoCoRacer 5.0/5.8 Engine Tech 0 09-22-2005 04:34 PM
how much boost on 10.7:1 carbed 351W phunk Superchargers 6 08-06-2004 12:04 AM
