open down pipe or full exhaust?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 06-26-2010, 02:03 PM Thread Starter
Banned Alleged Scammer
What are the advantages/disadvatages to running full exhaust as to open downpipe other then the niose?
Does the turbos spool faster and have less stress on them as opposed to a complete exhaust car ? Thanks for your replies-
post #2 of 12 Old 06-27-2010, 04:31 AM
Think of your engine as an air pump. Air in air out + fuel = horsepower. The less restrictions the better. Open downpipe would flow air better than full exhaust. As long as the turbos flow enough and you have enough fuel, it should make more power on open downpipe.
Lowvez is offline
post #3 of 12 Old 06-27-2010, 05:32 AM
1995gtCPE's Avatar
Trader Feedback: (34)
One downside to running an open downpipe is that if you have a headgasket let go on the big end you will wet the tires down.
1995gtCPE is offline
post #4 of 12 Old 06-27-2010, 09:53 AM Thread Starter
Thats true, a bit of saftey concern to take into consideration here. thanks 95gtcpe
post #5 of 12 Old 06-27-2010, 12:51 PM
Bobo's Avatar
I went open dp from Flowmaster American Thunder catback and picked up a few psi iirc, faster spool, much more power. No et's or dyno #'s for more verifiable evidence, but the seat of the pants meter was all the verifying I needed. Otoh, chambered Flows suck for turbos, so I'm sure the results wouldn't have been as dramatic with a straight thru catback.
Scotty we need more power!!!
Bobo is offline
post #6 of 12 Old 06-27-2010, 02:59 PM
UJUSTLOST's Avatar
I am just running a straight pipe off the down pipe and through a bullet muffler with a turn down. Its a little loud but not restrictive and moves the exhaust from under the rear tires.
UJUSTLOST is offline
post #7 of 12 Old 06-27-2010, 05:44 PM
I ran my old car 3 inch down pipe to a 2 1/2inch y and 2 1/2 cat back, just removed my mufflers for straight pipes. Sounded good fast spool too.
ds9182 is offline
post #8 of 12 Old 06-27-2010, 07:20 PM
Open dP = not street legal... Cat back = street legal just buy some pypes straight thru design
93coupee is offline
post #9 of 12 Old 06-27-2010, 09:36 PM Thread Starter
what if I pull the mufflers from the system and just let the downpipes run underneith. with this help the turbos spool faster?
post #10 of 12 Old 06-28-2010, 06:11 PM
jixxer's Avatar
While I was on the dyno we did a run with the cutout opened and closed and it gained 45hp to the wheels with the cutout opened.
1990 Titanium Frost Coupe, Quicktime Turbo Systems, Silverfox 700 AOD, Dirtydog Converter, TFS Heads, 42lb Injectors, E 303 cam, 501 RWHP
jixxer is offline
post #11 of 12 Old 07-02-2010, 01:23 PM
In most cases you will pick up power but if you drive the car much, the noise will get annoying. I drove my old 5.0 around for a few days and that was enough for me to put a ypipe kit on it to run it through the catback. On our kits, we have a cutout in the ypipe section so that you can open the exhaust up if you need but run it quiet if you drive it much. If you have another kit, you can just weld in a y section to run a cutout as well, just what I prefer and most seem to like it as well
On 3 Performance is offline
post #12 of 12 Old 07-03-2010, 01:54 PM Thread Starter
cool, I think Im going to do a custom 3" y pipe
open down pipe versus single 3" exhaust rob Turbochargers 12 09-13-2008 04:15 PM
Any way to open up a slightly crimped exhaust pipe? chrisallen General Mustang Tech 3 04-17-2006 12:02 AM
Open Exhaust or full exhaust? joeymustangGT General Mustang Tech 3 03-24-2006 07:15 PM
Exhaust ?, Can you open up a 2-1/2 inch ball collector to fit a 3" pipe? DropDTop General Mustang Tech 2 02-11-2004 09:22 AM
open longtube header vs. open longtube header vs full exhaust. Stang5Oh 5.0/5.8 Engine Tech 5 05-08-2003 08:29 PM
