88 Mustang with speed Density - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-25-2010, 05:54 PM Thread Starter
Im about to pick up an 88 mustang gt and it has speed density and Im curious as to what I need to do when I get a turbo kit for it to work with the speed density. I know you can do a maf conversion, but it seems pointless if I can spend about the same thing for a used pms or tweecer to tune it. I've read that you can use a check valve from like vortec so the map sensor doesn't get boost, but i've also heard you can use a bigger map sensor or one from a gm in order for it to work. Could someone clarify, and help me figure out what all I'm going to need for the turbo kit. I got a 255lph fuel pump and 42lb injectors in mind already. Thanks in advance.
302 Explorer Upper and Ported lower U/D pullies
Ported E7s with 3 angle valve job B303 cam msd ignition and blaster 2 coil smog pump deleted mac 1 5/8in shorty headers mac prochamber h pipe and flowmaster single chamber with dumps
kpack5982 is offline
post #2 of 7 Old 06-25-2010, 11:36 PM
Banned Alleged Scammer
Honestly just do the maf conversion , or spend alot more for a complete stand-alone efi system. The pms can help you tune, but only with maf, I think you can use the mega-squrt system for a complete efi ecu set-up, and theres the bs3, fast, but the price just keeps going up. Mega squrt is the cheapiest but has a learning curve and you have to have a laptop. Buy a a9p on here and get a blow thru maf and then get the engine harness to convert
post #3 of 7 Old 06-26-2010, 12:13 PM Thread Starter
I was actually looking at the megasquirt too. I think that'd be fun to learn. And if I remember right, it can come with a 2 or 3 bar map sensor too. Anyone done something similar with the megasquirt on a speed density with boost?
post #4 of 7 Old 06-27-2010, 12:03 AM
Carb'ed357's Avatar
http://www.moates.net/product_info.p...roducts_id=199
I use one of these on a turbo Mustang and it works awesome.
Carb'ed357 is offline
post #5 of 7 Old 06-27-2010, 09:33 AM
That just it Tweecer and PMS wont tune the S.D. computers.
Its not the S.D. that is the problem. It's that you cant tune the S.D. computers.
The aftermarket tuners are only compatible with the Mass Air computers.
S.D. is a better system for boosted engines, so if you want to change to Mega-Jizz
or an AEM or something that is a good option.
r.barn is offline
post #6 of 7 Old 06-29-2010, 11:03 AM
BobCat's Avatar
The TwEECer and Moates platform will in fact tune Speed Density vehicles.
94 GT 327 S-trim 4r70w yadda yadda
BobCat is offline
post #7 of 7 Old 06-29-2010, 12:35 PM
Learn something new everyday.
I guess its the SCT chips that all tuners burn that will not tune an S.D. computer.
r.barn is offline
89 mustang gt mass air or speed density 4x4 Ext. General Mustang Tech 3 08-29-2005 01:44 AM
wtb maf conversion for speed density mustang spot_84 Fuel System & Related 5 04-25-2005 01:42 PM
EEC IV computer for Speed Density (DA1) from 87' Mustang GT... WA2FAST Electronics and Entertainment 3 09-23-2004 07:11 AM
who has the fastest speed density mustang? importsuck Drag Racing 7 10-03-2003 01:26 PM
86 speed density in a 89 maf mustang???? WESBOB 89 5.0/5.8 Engine Tech 2 07-09-2003 07:06 AM
