PCV questions for turbo set up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-23-2010, 06:16 PM Thread Starter
Trader Feedback: (15)
Hey got a few questions. I am getting ready to install a turbo on my 410. Need to know best set up for pcv. I was thinking I'd put a 90* tube in the exhaust and run up to the valve covers but, after thinking would a vacuum pump be that much more effective? and worth the $$. I did build the block with intentions of putting boost to it so I have the rings filed for it. Any help would be great.
408 d4, 225afr's hydraulic roller Ported Super Victor
42# injectors 90mm Acuafab
4500 non lock-up stall FBperformance 4STB
410's out back on 31 spline spool.
Harsesis is offline
post #2 of 7 Old 06-24-2010, 06:43 AM
UJUSTLOST's Avatar
I plugged the factory PCV hole at the rear of the intake. Then I ran a -10 line from each valve cover to a catch can. That was all I did on mine. A good vacuum pump is really the way to go but it will cost you. I have heard some debate as to whether a vacuum pump can keep up with crank case pressure on a boosted engine at full boost. Personally I think it can but there are others that think it wont. Good luck.
UJUSTLOST is offline
post #3 of 7 Old 06-24-2010, 10:32 AM
Trader Feedback: (36)
just wondering, what did you use to plug the pcv opening in the back of the intake?
1995 Mustang GT 5.0
DevaRoh is offline
post #4 of 7 Old 06-24-2010, 11:33 AM
Turbo99svt's Avatar
i was thinking of doing the -10 to catch can with a breather... (except without the check balls in the pcvs
1999 Mustang Cobra
On your own performance (on3) turbo kit TC78, Diamond pistons, Manley h beam rods, Forged Crank Kurgan tuned 580hp 605 tq on 76mm, 01 cobra heads, Built Th400 trans, Straight axle
Turbo99svt is offline
post #5 of 7 Old 06-25-2010, 06:57 AM
UJUSTLOST's Avatar
An expandable plug, they sell them at any auto parts store. Its a rubber piece that expands as you tighten the nut on it. Pretty simple. If I had the engine out of the car and things were more accessible, I would either use a freeze plug or tap it and use a pipe plug.
post #6 of 7 Old 06-26-2010, 12:16 PM
CaliNotch n MI's Avatar
I just hacked off the bottom of my PCV valve, took out the guts and used it as a fitting and ran a 3/8 line to a breather tank.
1993 Notch: Mexican 347 Hellion TFS heads/GT40 intake/Custom Cam Tremec 3550
1992 GT Convert: Green/Blk interior, 10th anniversary cobra's mostly suspension mods.
FB users please, PLEASE click "like" button. Thanks!!
CaliNotch n MI is offline
post #7 of 7 Old 06-26-2010, 12:20 PM
Turbo99svt's Avatar
I LIKE YOUR STYLE
1999 Mustang Cobra
Turbo 03 questions. 97QUICKSNAKE SVT & DOHC 4 01-03-2008 04:57 PM
Turbo questions 1madracer Turbochargers 2 03-06-2005 09:15 PM
