wastegate too big? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-22-2010, 08:20 PM Thread Starter
WarMachine762's Avatar
wastegate too big?
is it possible to have too big of a wastegate? I found a good deal on a 60mm gate. for my boost bros 5.0.
WarMachine762 is offline
post #2 of 4 Old 06-22-2010, 08:27 PM
Trader Feedback: (41)
Never
stangjumper is offline
post #3 of 4 Old 06-22-2010, 09:22 PM
Not beyond wasting money.
If you can get a good deal, it wont hurt anything.
r.barn is offline
post #4 of 4 Old 06-23-2010, 01:06 AM
(*article courtesy of Turbosmart)
TRUE OR FALSE
*The more powerful the engine, the bigger the
wastegate you need.*
False. This is one of the more popular misconceptions. A wastegate is possibly the only component in your whole engine package that can actually be made smaller as you increase your boost/horsepower output. Use this simple guide:
Big Turbo/Low Boost = Bigger Wastegate
Big Turbo/High Boost = Smaller Wastegate
Small Turbo/High Boost = Smaller Wastegate
Small Turbo/Low Boost = Bigger Wastegate
Wastegates don’t operate in high temperatures.
False. Contrary to the popular belief, external wastegates are usually mounted at the hottest part of the exhaust. It’s the place where all the exhaust gases meet, creating extra heat. This, combined with the late combustion of unburnt fuel (due to rich mixtures, retarded timing and high octane fuels) significantly raises the exhaust temperature.
Larger wastegate valve diameter = better flow.
True – sort of. While the valve diameter is without a doubt an important part of the flow rate, equally important, but often misunderstood, is the importance of the flow path. When comparing wastegates with similar valve size, it is important to have a balanced body/valve/spring combination that is designed to work together to allow for maximum boost control. All Turbosmart wastegates are designed with this in mind.
ElSPa is offline
Wastegate and bov 97QUICKSNAKE Turbochargers 14 01-11-2010 09:03 AM
WBT: wastegate rurockn Power Adders 1 10-19-2009 04:30 PM
WTB: wastegate rurockn Exhaust Parts 0 10-17-2009 02:54 PM
Need Wastegate homie3186 Power Adders 0 01-10-2009 05:02 PM
hks-s wastegate? mustangless Turbochargers 4 04-24-2006 03:09 PM
