00 GT on3 build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 56 Old 06-20-2010, 06:16 PM Thread Starter
00 GT on3 build
Hey guys, there is a bunch of on3 build threads so I figured i will open up my own .
Its a stock block with the on3 kit and a turbonetics 60-1(I sooo hope it fits lol).
Mods include,
QA1 k member and arms
UPR C/O kit
Tokico Hp's all around
MM CC plates
Rear Sportlines
Super King Cobra clutch
GT pump
Hurst shifter
Im about done with all the suspension and hoping to start with the actual kit by mid week!
This nut would not fit!! So i just trimmed it down and went right in!
This was a b*** to get out!!
naza is offline
post #2 of 56 Old 06-22-2010, 12:37 AM
Blk4V00GT's Avatar
Good luck on the build buddy. let us know how it goes and feel free to ask if you have any questions.
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #3 of 56 Old 06-22-2010, 04:52 AM
2002mustanggt's Avatar
Looking good man, ask any questions you may have. You might need to order bump steer kit .
2002mustanggt is offline
post #4 of 56 Old 06-22-2010, 11:48 PM
Turbo99svt's Avatar
Good looking turbo!!!
1999 Mustang Cobra
On your own performance (on3) turbo kit TC78, Diamond pistons, Manley h beam rods, Forged Crank Kurgan tuned 580hp 605 tq on 76mm, 01 cobra heads, Built Th400 trans, Straight axle
Turbo99svt is offline
post #5 of 56 Old 06-25-2010, 07:09 PM Thread Starter
Thanks bro!! I will ask everything that comes to mind haha.
I was actually thinking about that, but im gonna have to wait until after I get the rest of the parts im missing haha.
I know right!! BWT turbo is here bro!! It looks friggin nice!!! lol Thanks!!
Heat wrapping the pipes, Im gonna have to order another roll. =(
naza is offline
post #6 of 56 Old 06-29-2010, 09:28 PM Thread Starter
Hey guys, i've been hearing a lot about catch cans, what are these for and should I get one?
Thanks!
naza is offline
post #7 of 56 Old 06-29-2010, 10:07 PM
Thanks!
I bought Jez mini catch can, fits nice next to battery area. What is does is collect blow by oil from valve cover . It's better to have intake clean then all the blow by oil getting into the intake manifold and have detonation as when you in boost it will spit oil like crazy. I used to have breather so I know . Now I just empty about every two weeks.
Here is my setup
post #8 of 56 Old 06-29-2010, 10:39 PM
Blk4V00GT's Avatar
Most people run catch cans as 2002mustanggt said just to make sure oil doesn't go all over the engine bay. I'm gonna run breathers on my 4v to start with and just put covers over the breather to keep the oil from going out. Well see how it works, I may switch to a catch can eventually. Only reason I'm not it to try to keep the engine bay less cluttered but if you don't care about that go ahead and get a can.
post #9 of 56 Old 06-30-2010, 10:29 PM Thread Starter
aah ok so pretty much is an optional thing, I think ima stick with the breathers. You guys have a link or place where I can get them?
If i get a Pmas MAF, do i need to cut and weld or can i just stick it in there? Its the same one you have(2002) but the mounting bracket is on the down side.
naza is offline
post #10 of 56 Old 07-01-2010, 03:54 AM
When you buy Pmas maf from on3 it will come with maf housing , you need to cut a hole and mount the bracket , get it weld.
post #11 of 56 Old 07-01-2010, 03:59 PM
vorga's Avatar
I run a catch can like 2002mustanggt . I did that because i didnt want to run boost into my valve cover on the passanger side. But it think you can get a check valve that will only flow 1 way. I also used marine JB weld to mount my MAF adaptor from On3 . I know its not the best way but its done now .I am going to be running low boost for now and that sucker is really on there.
2002 MustangGT,FRPP 70mm TB,TF plenum,1/2" Intake/plenum spacer,Qa1K member A arms,UPR Coilover,UPR 4Bolt CC,Tokico HP's,FL subframe connectors,UPR torque boxs,SVT Focus Fuel Pump,BAP,42lb injectors,Magnapacks,SCT X3,Pro-5.0 Shifter,3:55 Gears,On3 MP Turbo T70,EboostStreet,446whp/511wtq
vorga is offline
post #12 of 56 Old 07-05-2010, 08:10 PM Thread Starter
The adaptor is already welded on there, will that adaptor fit a pmas maf?...IM STUCK!!!!!!
Alright, I started mocking up the hot side and evertything is going great!! But, im stuck with the oil drain/feed.
What size the bolt or what ever goes inside the tapped oil pan? Where can i get that piece?
Did you guys plug in the oil sensor back, or do i just leave that unplugged?
Vorga, can you hook me up with the turbosmart boost controller install instructions, please?
I have to replace that part with the shiny one provided right? lol
naza is offline
post #13 of 56 Old 07-05-2010, 09:37 PM
vorga's Avatar
i dont have a turbosmart boost controller .But they have the instructions posted on there site .
If your talking about the black tube in the pic ? Yes you change it out with the shinny one .
If you post a pic of the maf adapter you have i can tell you if it looks like the one i have with the pmas
vorga is offline
post #14 of 56 Old 07-07-2010, 03:47 PM Thread Starter
I'll post some pics up probably tomorrow.
Im still trying to find the brass fitting that goes in the oil pan, but no one seems to carry them lol
naza is offline
post #15 of 56 Old 07-07-2010, 06:08 PM Thread Starter
I went to lowes, home depot, ace, napa, autoze and advance and i didnt find the damn piece lol...
Can someone please confirm this is the right piece i need for the oil drain....http://www.jegs.com/i/JEGS/555/10048...ductId=1123904
Thanks!
naza is offline
post #16 of 56 Old 07-07-2010, 07:09 PM
vorga's Avatar
It should look like this . i think the size is wrong
http://www.oreillyauto.com/site/c/de...1165&ppt=C0248
vorga is offline
post #17 of 56 Old 07-07-2010, 07:41 PM
Need a 3/8 npt - 5/8 hose barb
93coupee is offline
post #18 of 56 Old 07-07-2010, 10:17 PM Thread Starter
dang! I bought a 3/8 npt and a 1/2 hose barb!!...i'll see what i can do when it gets here
naza is offline
post #19 of 56 Old 07-07-2010, 11:52 PM
pm sent back to you
On 3 Performance is offline
post #20 of 56 Old 07-07-2010, 11:53 PM
also you should be able to run the 1/2 hose and stretch is over the 5/8 in the pan if you had to. I would just return the 1/2 though and get the 5/8s either from us or home depot might have it
post #21 of 56 Old 07-08-2010, 04:59 PM Thread Starter
hey vorga this is the adaptor that is welded on to the pipe.
This is what I have for the oil drain/feed
I think this is what im missing.
naza is offline
post #22 of 56 Old 07-08-2010, 06:30 PM
Top part is stock part, bottom is for oil pick up for turbo. Call chad and get one.
post #23 of 56 Old 07-08-2010, 06:35 PM Thread Starter
For some reason my car does not have that piece, i dont know if it is because its a 00???
The oil sensor is actually on the other side right under the oil filter....
naza is offline
post #24 of 56 Old 07-08-2010, 07:38 PM
vorga's Avatar
Ya your MAF adaptor is deff. diffrent than the one on3 sends out . 2002mustanggt is also right on the oil feed . You should be able to pick that stuff at ace hardware probably be less than $10 . i dont have the sizes . you can remove the allen key plug and bring that and you oil feed hose to the hardware store and get your parts based on the threads on the allen plug and oil feed hose . wish i took pics of the brass fittens before i installed them .
Also you pic with the hoses . It looks like you have a extra hose .The top hose goes to the bottom of the turbo the second hose goes to the top of your turbo . Also looking at the same pic the 90 looking brass fittin looks like it will screw into your car oil feed if it does then you have the parts you need less the hose barb for tapping the pan
vorga is offline
post #25 of 56 Old 07-08-2010, 10:10 PM Thread Starter
Actually that fitting does fit into the oil feed, but the only problem is that it does not have another thread to put the oil sensor..
Sorry for the crappy pics..
naza is offline
post #26 of 56 Old 07-08-2010, 10:59 PM
vorga's Avatar
if you dont have a bolt with a allen head in that area then you will need to get a t fittin and screw that into the hole and screw everything into the t . That might be why On3 sends out the T instead of a 90
vorga is offline
post #27 of 56 Old 07-10-2010, 06:34 PM Thread Starter
Update!!
I finally got the oil pan tapped!!! Found that part at oreily, the oil thanks vorga =)!
Finished up mocking up the hot side and everything went in like butter!! So far no fitment issues =).
I still need the T for the oil feed, hopefully chad has a few laying around.
My next question is, what to do with this sensor(pic). Do I drill a whole on the pipe for it?? Its on the pipe that goes from the tb to the fender.
Random pics.
naza is offline
post #28 of 56 Old 07-10-2010, 07:24 PM
vorga's Avatar
The new MAFs has that sensor built into it . I think you need to splice the 2 wires on that sensor into the MAF harness. i think the outer 2 pins on the MAf harness are for the temp sensor . Your going to want to chek if I am correct cuz i really dont know if im right my car is a 02 so the temp sensor is allready intergrated into the MAF
vorga is offline
post #29 of 56 Old 07-11-2010, 07:26 PM Thread Starter
ahhh ok, hopefully someone can confirm that =).
Does anyone have a diagram or pics of how the WG and BOV is routed???
naza is offline
post #30 of 56 Old 07-13-2010, 08:31 AM
http://www.tialmedia.com/documents/w..._wginstall.pdf
http://www.tialmedia.com/documents/w...bovinstall.pdf
T70Cobra is offline
post #31 of 56 Old 07-13-2010, 12:16 PM Thread Starter
Thanks for the link bro!! I also found a digram of the MAF and it is the two outer pins that i need to splice in the IAT sensor. =)
naza is offline
post #32 of 56 Old 07-16-2010, 10:14 PM Thread Starter
ok guys getting ready to finish everything up( minus maf and inj still looking for a deal).
Is there a way to tell if my turbo is clocked correctly?? I really dont want to mess that up =)...
naza is offline
post #33 of 56 Old 07-16-2010, 10:29 PM
No need to worry , just loosen all bolt in hot side and cold side then turn the center part to make sure oil feed and drain is straight , you will need to clock cold side to make first cold pipe right.
post #34 of 56 Old 07-17-2010, 07:36 PM Thread Starter
Thanks man!! I got pretty much finished all of the hot side, nice and tight, and WG is installed. Everything is going in smooth and no fitment issues so far!!
Im hoping to get the cold side done tomorrow!!
Can I tee from either of these spots for the WG and BOV??..
There is one more spot that is behind the TB, but thats tapped for the boost gague already...
naza is offline
post #35 of 56 Old 07-17-2010, 07:59 PM
Love the cinder block jack stands, lol
r.barn is offline
For a turbo build: Better to build bottom end or get HCI demarsjcd Turbochargers 9 05-05-2010 06:57 PM
Pampa high school build... Show some love....48 gmc rat build.. donniearcher Lounge 7 04-17-2010 09:03 AM
Want to build my first home. Possible to build in increments? First5.0 Lounge 16 11-18-2007 11:17 PM
Build/buy 9" or build my 8.8??? 89missle Drag Racing 18 08-31-2007 11:28 AM
2 build or not 2 build, that is the question.... wht92NotchLX 5.0/5.8 Engine Tech 4 03-09-2004 01:24 PM
