BOV question. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-20-2010, 12:47 PM Thread Starter
BOV question.
Is there a way to spring, or run the vac lines on a blow off valve, so that it doesnt vent so much boost, and or is less sensitive to throttle closing?
Everytime I shift my car, it falls down far, and takes too much time to come back up, IMO.
I have two springs a soft and a hard one, and have the line ran to my vac tee on the firewall.
thx.
JBIGBOOTSY is offline
post #2 of 2 Old 06-21-2010, 05:37 AM
Not sure what your problem is. Boost should return instantly unless you are shifting way slow and loosing the same amount of rpms each shift. I will assume thats not it.
Maybe The BOV isn't closing back up after opening right away. I run a 50mm Tial BOV and I believe that one if not the biggest out there, and I dont have a problems.
Is the BOV closed at idle?
88lx Conv. 200K mile stock longblock. Trickflow intake, 42lb inj, Pmas protube,TKO500, 3:27, pypes muffs, Pa Racing tubluar K-member, DIY single turbo setup. Summit aluminum rad, Crane Hi-fire ign, subfames, 17" sc saleen's, Saleen ground effects, SCT tune by Dynosport. 380HP 435ftbs.
71swing is offline
FMU question, power pipe question, and pulley size question 4 eyed mustang Superchargers 5 04-23-2009 07:12 AM
??QUESTION for 96-04 GT owners w/ a roots/screw blower -- gear question 3.73 or 3.55 MyBlueSaleen GT & SOHC 9 07-24-2004 06:58 PM
Painting/sanding metal question, and electric fan sealing question> BLOWNFIVOH General Mustang Tech 8 09-16-2003 09:53 AM
Question on milled heads and intake manifold sealing question nickster 5.0/5.8 Engine Tech 7 05-18-2003 11:24 AM
Question About Tires: If You Guys Answer It I Promise Not To Ask Question For 2 Days ArcaneParadise SVT & DOHC 7 11-09-2002 01:59 AM
