Trickflow headed 4.6 with on3 kit. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 06-20-2010, 09:25 AM Thread Starter
chris'98gt's Avatar
Just fired up the new motor/On3 turbo setup tonight. Sounds real good. The start up tune injected engineering sent me seems to be spot on.
Heres some pics of the last two weekends.
Old motor out and stripped: PI swapped 96 block made 381rwhp with a P1sc.
Uploaded with ImageShack.us
New Trickflow headed .020 over forged 4.6.
I need to install a bumpsteer kit before I can drive it since as it sits the tierod is rubbing on the wrapped hotside piping on the driver side. On the plus side, it sounds real good with the mmr stage 2 turbo cams
98 Turbo GT
chris'98gt is offline
post #2 of 19 Old 06-20-2010, 10:26 AM
Blk4V00GT's Avatar
Looks awesome, nice job getting her all back together.
What comp. Is your new motor?
How muchboost you planning to run?
And what is your fuel system?
Keep up the good work, waiting for some new numbers
1994 Mustang GT Coupe....
Blk4V00GT is offline
post #3 of 19 Old 06-20-2010, 12:04 PM Thread Starter
chris'98gt's Avatar
I don't know the exact c/r but I'm running -18cc dished manley pistons with the 44cc trickflow heads. However much boost it'll hold safely on 93 octane is the plan, and I'm waiting on an 03 cobra tank with twin 255's and fore fuel hat with -8 feed and -6 return on the fuel system with 60lb injectors.
98 Turbo GT
post #4 of 19 Old 06-20-2010, 04:17 PM
y2k02's Avatar
Looks nice!
Your c/r is around 9.4 to 1.
Did you get the high load springs?
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
post #5 of 19 Old 06-20-2010, 04:22 PM
04Ryan's Avatar
Looks good...have you thought about a 6061.com plenum? You could sell your BBK to help offset the cost. The stock style plenums are restrictive on that Edelbrock intake. Just a thought thats all....
How long till she runs on the street?
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #6 of 19 Old 06-20-2010, 04:27 PM
2002mustanggt's Avatar
Very nice, keep coming .
2002mustanggt is offline
post #7 of 19 Old 06-20-2010, 04:57 PM
y2k02's Avatar
I switched from an accufab and adapter plate to the 6061 and noticed nothing. I don't see the stock style and adapter being restrictive in a turbo setup.
y2k02 is offline
post #8 of 19 Old 06-20-2010, 07:27 PM
Thanks for clearing things up cause Ryan is the only one thinks stock style will restrictive. Any one have done testing on that ???
post #9 of 19 Old 06-20-2010, 10:23 PM Thread Starter
chris'98gt's Avatar
Thanks for the info on the c/r. I was under the impression that the stock springs were pretty good in these heads? I have thought about the 6061 setup, and would like to get it, but it just didn't happen before I was ready to put this thing together. I did take it for a spin today, just clearanced to hotside a little just can't make a sharp left hand turn. Had the wideband a/f guage hooked up and it all looks good and safe. Got an exhaust leak to track down though. Seems to be after the turbo though it spools nice even under part throttle.
98 Turbo GT
post #10 of 19 Old 06-21-2010, 08:27 PM
y2k02's Avatar
The stock tf springs are not strong enough.
y2k02 is offline
post #11 of 19 Old 06-21-2010, 08:46 PM
Very nice man I'm jealous
Caleb03GT is offline
post #12 of 19 Old 06-21-2010, 09:45 PM Thread Starter
chris'98gt's Avatar
That's strange, back when I asked mmr they said they were good for most apps.
http://www.modularmustangracing.com/...8&p=2787#p2787
If they are in fact too weak, do the tf heads require a special spring? I've got a set of comp cams springs mmr sells in my pi heads, but never thought anything about it since I thought the stock tf springs were good.
98 Turbo GT
post #13 of 19 Old 06-21-2010, 10:08 PM
y2k02's Avatar
"most apps"
You need the 125lb comp springs.
When will you have it on the dyno?
y2k02 is offline
post #14 of 19 Old 06-21-2010, 10:23 PM Thread Starter
chris'98gt's Avatar
Well I kinda laid my setup out there for them. I woulda thought they would have said a yes or no . Either way It'll be a month probly before I get it to the dyno. I need to get the fuel feed/return setup, fore hat and a second pump, then save for the dyno tune. Right now it's running on the stock tank, one 255 pump, 60lb injectors and stock lines. Any word if the tf heads require special springs?
98 Turbo GT
post #15 of 19 Old 06-22-2010, 08:00 PM
What Fuel Reg are you running? Im trying to get my fuel together for my 98 and need to do fuel rails and such so just wondering what reg you were running.
THanks
boostedstang98 is offline
post #16 of 19 Old 06-22-2010, 09:01 PM Thread Starter
chris'98gt's Avatar
The aeromotive compact efi regulator.
http://aeromotiveinc.com/products-pa...efi-regulator/
98 Turbo GT
post #17 of 19 Old 06-23-2010, 06:05 PM
awesome thanks. and are you just running regular 255 intank pumps?
post #18 of 19 Old 06-23-2010, 06:29 PM Thread Starter
chris'98gt's Avatar
Right now I've just got one of the 255lph vortech pumps in the 98 tank. I've got a 04 cobra tank and I'm waiting to get the fore hat and another vortech pump with new lines. Then I'll be all set, I hope.
98 Turbo GT
post #19 of 19 Old 06-23-2010, 06:52 PM
cool. Im doing the Cobra hat with twin 255s, lines and need to do rails with the regulator thats why i was asking and i have a 98 as well so just wanted input on what someone with a 98 has done.
Stock cammed Trickflow headed 306..bigger MAF? joshstang 5.0/5.8 Engine Tech 28 02-12-2010 03:38 AM
Are we headed downhill like a snowball headed for hell? scott9050 Lounge 5 11-05-2008 09:50 AM
Headed to Dyno with Small Headed 408w xsvstang 5.0/5.8 Engine Tech 14 10-06-2008 10:26 AM
Trickflow Street intake, 65mmTB, 1IN Trickflow Spacer, EGR delete tw3aK Windsor Engine Parts 5 07-03-2008 12:52 PM
trickflow track heat heads forsale and 1.7 trickflow rockers racinjason393 Windsor Engine Parts 0 11-09-2004 05:45 PM
