Got back to work - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-11-2010, 06:22 PM Thread Starter
Got back to work
Ok, well after I while of not working on my cougar and went back to work. I managed to wire correctly the scavenge pump and turns on when key is on and off when key=off. My question still remains, of the two turbos, only one barely spins, the other one does not even move, now I know that car is just idling, is it normal? Shouldn't be there a little more movement?
Also, what happened last time was that oil accumulated because pump was not on. No smoke whatsoever. Should I be worried that my newly refreshed turbos need another rebuild? What do you guys recommend me to do?
It is a DIY setup, each turbo is mounted to a separate header. Both turbos were rebuild. Problem I had at the beginning was that the pump was not working (not wired right) and had the car running for about 5 mins and after that haven't turned it on again! Car does not smoke and yes, turbine could be spin freely. I am guessing I will have to get the passenger turbo off (the one that doesn't spin) and inspect it. I hope that I don't need to rebuild it again! Pics are as follows.
This is the passenger turbo when turned on the pump, there is oil coming from the exhaust
*Not Fast Enough*
"It doesnt matter what it looks like, just as long as you can beat the guy in the other lane"
Tx_Cat is offline
post #2 of 2 Old 06-11-2010, 07:18 PM
Need welding instructor? Lol... How long it take u to fab up all the piping?
93coupee is offline
will a 99gt cat back work on my fox? mrjay1979 General Mustang Tech 1 10-02-2008 12:12 AM
Hillary to Union: Get Back to Work, I Need the Money Daywalker Politics 24 10-04-2007 11:14 PM
back up lights do not work 93Svt331 General Mustang Tech 3 05-24-2007 04:22 PM
Will This Cat Back Work? AG87BlkLX GT & SOHC 3 07-31-2006 12:37 AM
after all this work, putting stock cam back in . . . phil a 94/95 Tech 46 08-26-2004 08:50 PM
