Retarding stock cam with turbo? Who is? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-08-2010, 04:37 PM Thread Starter
Stock cam with 1.7's and a turbo. What are most of y'all doing with the stock cam? Installing straight up or retarding it? Thanks in advance. And if you can explain why that would be great.
91 SSP Coupe
LS1_ETR is offline
post #2 of 7 Old 06-09-2010, 02:08 PM
Only reason you do it is to move some of the power up in the band. We used to do it with any car that had a stock cam and 1.7s regardless of power adder or if a power adder was even there.
post #3 of 7 Old 06-12-2010, 11:17 PM
goatnipples2002's Avatar
Trader Feedback: (22)
I know the stock cam is aight, BUT Fcams and TFS 1 cams are pretty cheap these days.
goatnipples2002 is offline
post #4 of 7 Old 06-13-2010, 10:41 AM
my stocker was striaght-up with 1.7's, powerband for street was awsome, but at the track I was shifting at like 5200 as it ran out up top, only benifit to it was the stock block stayed together longer with out the big revs.
I'd do it agian in a heartbeat!
diesel like torque.
MOOVS is offline
post #5 of 7 Old 06-13-2010, 11:27 AM Thread Starter
diesel like torque.
I was able to find an F cam fairly local for $100 so I think I'll go with that. I plan to shut it down between 5500-5800 and limit the power to about 550. I was making 530+ with my blower without any issues on my old 306 so I'm hoping the turbo puts even less stress on the block.
91 SSP Coupe
LS1_ETR is offline
post #6 of 7 Old 06-13-2010, 12:47 PM
Hell I run mine to 6400rpms. I figure stock redline was 6250.
post #7 of 7 Old 06-13-2010, 12:57 PM Thread Starter
Maybe the stock rev limiter but that's also in a car that's making maybe 200whp from the factory. I'm pretty confident I can still hit 550 without taking the thing to even 6000 rpms.
91 SSP Coupe
LS1_ETR is offline
retarding stock cam, will it pull to 6000 ! boostjunkie 5.0/5.8 Engine Tech 35 06-21-2008 04:22 PM
Anyone have before and after results of retarding their stock cam 4*? Luke87GT 5.0/5.8 Engine Tech 0 10-22-2005 06:33 AM
Retarding Stock Cam macx 5.0/5.8 Engine Tech 0 02-27-2004 11:13 AM
Did Search...Retarding Stock Cam: What's It Worth? 90trunk 5.0/5.8 Engine Tech 17 06-01-2003 12:33 PM
Retarding Stock Cam 4 Degree's Blownup5.0 5.0/5.8 Engine Tech 1 01-19-2003 03:29 PM
