Quicktime fella's! What A/F? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 32 Old 06-07-2010, 10:53 AM Thread Starter
jturmanator's Avatar
Looking to sqeeze every oz of HP out of my current combo. I have seen guys claim they picked up as much as 25HP by removing the air filter. Is this true?
I'd like to run a bigger filter. Any of you guys change your filter set-up?
Uploaded with ImageShack.us
jturmanator is offline
post #2 of 32 Old 06-07-2010, 11:26 AM
ratedz's Avatar
Weird you posted this - i'm heading out the door in just a bit to make a screen for mine. It's at the shop right now getting the tune cleaned up so I may be able to get actual real world numbers out of the switch.
Small 3 year old filter vs DIY turbo screen
1986 Mustang GT
525hp/626tq
ratedz is offline
post #3 of 32 Old 06-07-2010, 08:17 PM Thread Starter
That would be awesome!
post #4 of 32 Old 06-08-2010, 01:05 AM
Trader Feedback: (43)
is that your original air filter j?
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #5 of 32 Old 06-08-2010, 01:25 AM
I'm jealous! I got the same turbo blanket as you but i have no room in my engine bay to put it on
Lowvez is offline
post #6 of 32 Old 06-08-2010, 03:24 AM
cesna150's Avatar
Trader Feedback: (29)
im taking my filter off tomorrow and installing a screen to see what kind of difference it makes at the track. the filter on our quicktime kits is very small and it has to be restricting airflow a little. im also going to remove the headlight and see what happens. at 130mph its got to help a little.
1993 notch 302 and c4
quicktime turbo system
9.986 @ 136.84
cesna150 is offline
post #7 of 32 Old 06-08-2010, 09:24 AM Thread Starter
Yes, this is the filter that came with the kit.
post #8 of 32 Old 06-08-2010, 10:21 AM
I dont need a dyno to tell you that your going to pick up hp if you take that filter off. As small as it is you could pick up some decent power. There was a guy on turbomustangs.com that removed his screen that you could easily see thru and he picked up alomst 40hp. I thought it was crazy. Also I seen that you wanted to pick up more power in another thread: have you tried removing your exhaust and running an open downpipe? Should see some gains.
Pete
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #9 of 32 Old 06-08-2010, 01:48 PM Thread Starter
What are you guys using for a screen?
post #10 of 32 Old 06-09-2010, 10:06 AM
I went to a local hardware/feedstore and bought some 50/50 SS screen.
post #11 of 32 Old 06-09-2010, 10:02 PM Thread Starter
Is a screen recommended on the street?
post #12 of 32 Old 06-09-2010, 10:16 PM
I prob wouldnt do it on a daily driven car. Also depends on where you live. If their is alot of road construction or poor roads around where you live I wouldnt. Just have a filter for on the road and take it off when you go to the track or run someone on the street.
post #13 of 32 Old 06-10-2010, 06:14 AM
Rich G's Avatar
Trader Feedback: (35)
I picked up 2mph by removing the filter on my BG kit
Rich G is offline
post #14 of 32 Old 06-11-2010, 02:41 PM
For those that picked up with the screen, did you pick up boost as well?
'91LX Vert- Stock Shortblock, Stock Cam, Cobra Intake, Edelbrock Performer 1.9's, 42#er's, PMAS 3", AOD, 3.27 gears, B&G 70mm Single, 3500lbs w/ me
Best 1/8- [email protected] with a 1.64 60'
Best 1/4- [email protected] with a 1.66 60'
Funniest 1/4- [email protected] LOL
Doug Hatton1 is offline
post #15 of 32 Old 06-12-2010, 11:29 AM
jixxer's Avatar
Will removing the filter affect the a/f ratio?
1990 Titanium Frost Coupe, Quicktime Turbo Systems, Silverfox 700 AOD, Dirtydog Converter, TFS Heads, 42lb Injectors, E 303 cam, 501 RWHP
jixxer is offline
post #16 of 32 Old 06-12-2010, 11:43 AM
Rich G's Avatar
I doubt it since the filter is before the maf
Rich G is offline
post #17 of 32 Old 06-13-2010, 11:07 AM
I wonder why my filter has sucked itself dry with the same psi.
post #18 of 32 Old 06-17-2010, 07:14 PM Thread Starter
Anyone know what filter set up would be good for the street?
What about adding a pipe to extend the filter elsewhere? Or would this hender performance? I'm not sure how I to run a bigger filter with the tight fit.
post #19 of 32 Old 06-17-2010, 07:49 PM
Rich G's Avatar
Why do you need a bigger filter on the street, is the extra 20hp really gonna make or break you?
Rich G is offline
post #20 of 32 Old 06-17-2010, 11:11 PM
goatnipples2002's Avatar
Trader Feedback: (22)
Aside from the HP it might help spool and overall efficiency. A screen is not going to hurt anything on a daily.
goatnipples2002 is offline
post #21 of 32 Old 06-18-2010, 07:20 PM
ratedz's Avatar
Sorry never got to update my status - I was unable to dyno the car minus the filter because it already made more power than what I expected 525/626 so I left the filter in place.
Reputable friends advised me against running a mesh type filter because they lost 30rwhp on average by using them. They now all run around completely filterless - no screen, no chicken wire type. I was going to try the chicken wire type but what's it going to stop smaller than a limestone rock?
1986 Mustang GT
525hp/626tq
ratedz is offline
post #22 of 32 Old 06-19-2010, 10:27 PM Thread Starter
Rich, you even said it yourself. Why wouldnt any of us wanta pick up an extra 20-30 HP by simply removing a filter?
Id like to see some pics of any screen set ups. Car is only driven about 2k miles a year.
post #23 of 32 Old 06-19-2010, 10:52 PM
Rich G's Avatar
Because on the track where the ground is sticky and you can put down all the power its useful, on the street where you have to modulate the throttle its pointless.. Just push the pedal down a little further.
Rich G is offline
post #24 of 32 Old 06-19-2010, 10:54 PM Thread Starter
It hooks from a 40 roll just fine.
post #25 of 32 Old 06-20-2010, 01:02 AM
Are most of your races from a roll? That is how I prefer to race.
post #26 of 32 Old 06-20-2010, 01:30 AM
smurfmobile8586's Avatar
it made no difference on my car between filter and screen have the 1/8 mile time slips not the buttometer testing have not tried it with no screen yet
smurfmobile8586 is offline
post #27 of 32 Old 06-20-2010, 10:47 AM Thread Starter
Yepper, I'm set up for drag racing but it aint gona hook from a dig on the street.
post #28 of 32 Old 06-20-2010, 01:21 PM
1995gtCPE's Avatar
Trader Feedback: (34)
That sux. My car hooks like a son of a gun on the street. Maybe focus on the suspension before adding more hp. Wont do you any good if you spin. Spinning aint winning!
1995gtCPE is offline
post #29 of 32 Old 06-20-2010, 08:01 PM
Roll racing takes less skill and is more about the motor than the driver. Plus I get traction from a roll.
post #30 of 32 Old 06-20-2010, 08:20 PM
NoSloCoupes's Avatar
Trader Feedback: (53)
Might as well remove the headlight also(for track purposes only of course).
NoSloCoupes is offline
post #31 of 32 Old 08-15-2010, 01:53 PM
629RWHPstang's Avatar
i picked on 2lbs of boost when removing the filter on my procharger
90GT,R Block 347,Brodix Heads,D1-sc=629WHP/599TQ 14LBS laracca tuned
Daily driver 08 STI
629RWHPstang is offline
post #32 of 32 Old 08-23-2010, 07:20 AM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
With the PT78 my car wouldn't make more then 12 or 14 psi on the dyno, I don't remember exactly what it was. That was with a small K&N from summit, not the filter that came from B&G, I couldn't get that thing to fit with the turbo on the car.
Pulled the filter, would make 28 psi.
My car is mostly strip, some street and I agree with the comments regarding daily drivers.
I keep a screen on it now but remove that when in competition.
mcj50 is offline
Ok fella's tomorrow is the big day...wagers on the pwer it will make?? Turbo Matthew Superchargers 42 03-27-2010 10:12 PM
quicktime blackgt40notch Lounge 5 09-03-2008 08:51 AM
quicktime bowtie killer Classifieds Feedback Area 0 12-10-2004 03:32 PM
Fella's, i need help..got it running today...BUT whistling91stang 5.0/5.8 Engine Tech 24 09-04-2003 07:11 AM
What's goin on with my car fella's?? SMKD YA General Mustang Tech 3 07-15-2003 12:12 PM
