Looking to make more power! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 06-05-2010, 12:46 PM Thread Starter
jturmanator's Avatar
Guys been running my same set up for over a year now on 10lbs. Looking to really turn it up a bit. I'd like to make 500 to the wheels on 110 octane. What needs to be done in order to turn up the boost and what gains do you think I will see from switch from 10-14 lbs?
I know I need the Blue (14) spring for my wastegate, what about the BOV?
Anyone got a 14lb spring laying around for a TIAL 38mm?
jturmanator is offline
post #2 of 29 Old 06-05-2010, 01:11 PM
Do u have a boost controller? If so u don't need the 14lb wastegate spring all that does is that's the lowest level boost u can run... Usually on a 10lb wastegate spring u can run around 20lbs of boost.... For example: i had a built eagle talon with the 38mm tial wastegate... Had a 12lb spring... My boost controller was an electronic greddy... My low boost setting was 12 highboost was 21... Never saw boost creep just tightned my BOV screw....
93coupee is offline
post #3 of 29 Old 06-05-2010, 07:20 PM
Trader Feedback: (43)
Put some real heads on the car and you'll get what you want.
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #4 of 29 Old 06-05-2010, 08:21 PM Thread Starter
No boost controller, and no money for real heads!
post #5 of 29 Old 06-05-2010, 09:09 PM
water meth kit, electronic boost controller, an crank up the timing an boost. done.
sceviours197 is offline
post #6 of 29 Old 06-05-2010, 09:56 PM
conbread's Avatar
Trader Feedback: (60)
i bet you can add a lil timing with the race gas and pick up plenty of power on the same 10psi
conbread is offline
post #7 of 29 Old 06-06-2010, 04:39 AM
1995gtCPE's Avatar
Trader Feedback: (34)
Just turn it up via a manual boost controller and have it retuned. You can make 500 easy on pump gas.
1995gtCPE is offline
post #8 of 29 Old 06-06-2010, 11:49 AM Thread Starter
I have a 110 octane tune which is around 21 deg timing. How much boost would you guys throw at it?
How much HP will I pick up from adding 4lbs of boost?
post #9 of 29 Old 06-06-2010, 02:49 PM Thread Starter
How much would removing the small K&N air filter help? I heard up to 25HP? Is this accurate?
post #10 of 29 Old 06-06-2010, 03:38 PM
Put a 10-12" air filter on the turbo
Swap out to 1bar spring (14.7psi)
Re-tune
Done
r.barn is offline
post #11 of 29 Old 06-06-2010, 04:22 PM Thread Starter
How much HP per lb of boost do you think it will make?
post #12 of 29 Old 06-06-2010, 07:03 PM
18.6352 per psi
r.barn is offline
post #13 of 29 Old 06-06-2010, 09:31 PM Thread Starter
That much? I thought it would be closer to 10?
post #14 of 29 Old 06-06-2010, 09:36 PM
cesna150's Avatar
Trader Feedback: (29)
im not sure but i think he was joking.
1993 notch 302 and c4
quicktime turbo system
9.986 @ 136.84
cesna150 is offline
post #15 of 29 Old 06-06-2010, 09:41 PM Thread Starter
Yea, I sensed the sarcasm! If I had the money I'd just drop a set of TF Heads on it. But, being as I'm broke I'm looking for the cheapest gains possible. I'm guessing I will make around 460-480 @ 14lbs.
Or, I could add meth and shoot for 20lbs? Don't know of too many guys on here running that much boost.
post #16 of 29 Old 06-06-2010, 09:48 PM
cesna150's Avatar
are you still running 122mph and 12's? thats enough to run 10's. why dont you keep that engine in one piece and work on the suspension? you have the power.
9.986 @ 136.84
cesna150 is offline
post #17 of 29 Old 06-06-2010, 10:03 PM Thread Starter
No, have not been back. I am in need of front coil overs. The front Mach 1 springs I cut killed my 60's. Been roll racing from time to time. Don't drive the car that all that much anymore.
post #18 of 29 Old 06-07-2010, 06:51 AM
what can a stock bottom end handle boost wise?
RIPPED OFF BY stroked_snake <---dead beat alert
sc13mw is offline
post #19 of 29 Old 06-07-2010, 07:06 AM
vbstng's Avatar
X2 on the suspension
91 MUSTANG GT
99 EXPLORER DAILY DRIVER
vbstng is offline
post #20 of 29 Old 06-07-2010, 10:47 AM Thread Starter
I have Maximum Lower adjustables, Baseline uppers and adj shocks. Putting off track for the time being. Right now I'm looking to run from a roll. 430 feels slow so its time to up the boost.
post #21 of 29 Old 06-08-2010, 06:29 PM
Check out my link for more info on the setup..
https://forums.corral.net/forums/show....php?t=1207791
My Car Made 408whp 424ftlbs @ 8psi. 93octane with stock e7 heads & stock cam.. Lifted a head & popped a gasket on the first day. I blame the thin deck on the iron heads.
I switched to thick deck aluminum heads and a different cam while i was in there and went back on the dyno..
My Car Made 529whp 474ftlbs @ 13psi. 110octane with AFR185's & F cam
Die-Laughing is offline
post #22 of 29 Old 06-08-2010, 09:24 PM
Rich G's Avatar
Trader Feedback: (35)
alot!
Rich G is offline
post #23 of 29 Old 06-08-2010, 09:26 PM
Rich G's Avatar
To make more power just up the boost and keep an eye on your a/f ratio.
Rich G is offline
post #24 of 29 Old 06-08-2010, 09:44 PM
Originally Posted by Rich Gill View Post
alot!
lol thanks so 14lbs should be fine
sc13mw is offline
post #25 of 29 Old 06-09-2010, 01:06 AM
ratedz's Avatar
Yeah I run 14lbs and beat the dog snot out of my car, for the past few years now.
Considering upping it some more while it's on the dyno - maybe 16lbs or so.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #26 of 29 Old 06-09-2010, 04:21 AM
cesna150's Avatar
be a man and go to 20lb!
9.986 @ 136.84
cesna150 is offline
post #27 of 29 Old 06-09-2010, 10:00 PM Thread Starter
Would I be wasting my time porting the GT40's? Going to be awhile before I can afford decent heads.
post #28 of 29 Old 06-09-2010, 10:22 PM
Yes that would be a waste. Just save your money for some alum heads. For now just up the boost alittle and have fun.
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #29 of 29 Old 06-10-2010, 03:13 AM
slo5.0.'s Avatar
I vote MBC, METH, More boost, low timing. Contact AIS here on the forums, good people.
slo5.0. is offline
How much power will this make? cerecke Superchargers 1 08-30-2009 10:33 AM
Dyno shop's "make a quick buck or make big power" untamed 5.0 Superchips Custom Tuning 6 03-14-2007 05:41 PM
Does an SQ make more power than a V1? Daniel Mitchell Superchargers 6 06-26-2005 06:53 PM
Where can I look to make more power? VIPERBLUELX SVT & DOHC 8 11-20-2003 08:08 AM
how much power will i make mosstang 5.0/5.8 Engine Tech 5 10-09-2003 04:04 PM
