strong 347 with twins - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-01-2010, 12:33 AM Thread Starter
BBFrocket's Avatar
i have a well built 347 and was wondering what kinda power i should excpect out of it with a set of t3 twin turbos has gt40 heads with alot of work done 6lbs of boost
going to tune it real soon
just wondering i want to change the heads asap but if it will make enough now i may keep it like it is for the summer
BBFrocket is offline
post #2 of 9 Old 06-01-2010, 01:01 AM Thread Starter
BBFrocket's Avatar
http://i134.photobucket.com/albums/q...t/93turbo2.jpg
post #3 of 9 Old 06-01-2010, 10:59 AM
The heads certainly are not going to be helping power numbers although at that boost level not sure it will be a significant issue. What do you mean by "well built 347" and any more specs on the T3s?
post #4 of 9 Old 06-01-2010, 02:24 PM Thread Starter
BBFrocket's Avatar
well its scat crank and rods 4340
with trw pistons
9-1 compression
cam was cut for turbos so its not rad at all
cant remember what the size are on turbos i think 50s will have to look at them
post #5 of 9 Old 06-01-2010, 02:48 PM
Trader Feedback: (15)
You are going turbos and only wish to use 6lbs of boost?
94CobraGermany is offline
post #6 of 9 Old 06-01-2010, 04:50 PM Thread Starter
BBFrocket's Avatar
no i havnt tuned the car yet was just wondering what kind of power i should expect out of set up thats all if it will go 12 lbs then im going to use it or more but heads will kill it after so much boost they arent big enough
post #7 of 9 Old 06-01-2010, 04:53 PM
Not like you need great heads but those probably don't flow enough for the cubes plus GT40s don't have the best of decks for sealing.
post #8 of 9 Old 06-01-2010, 05:45 PM
Still need more specs on the turbos too.
T3 with Stage I trim .48 a/r is going to flow a lot less than a
T3 with Stage III and .83 a/r
You're probably in the low 400's rwhp though with lots of low end torque.
r.barn is offline
post #9 of 9 Old 06-03-2010, 12:15 AM Thread Starter
BBFrocket's Avatar
update on the hsp and trq i dynoed it today and it wouldnt make any more than 5.4 and it made 440 hsp and 460 trq im happy and thats a good safe mark to be a good daily driver with air and cruise so if i want more out of it atr this point the heads have to go thats a good winter project single turbo with set of heads
o yea its a aode tranny to not a stick
strong 347 95redstang Windsor Engine Parts 6 09-22-2008 11:46 PM
How strong are cast pistons with a good tune? Apparently strong enough !!!!!!!!! OneBadFox 5.0/5.8 Engine Tech 105 01-27-2005 01:11 AM
Coast cast steel 347 crank as strong as a stock 302 Crank???? SKYWLKR 5.0/5.8 Engine Tech 8 05-23-2004 12:41 AM
want advise for strong street 347 sgmtino 5.0/5.8 Engine Tech 6 11-02-2003 01:07 PM
