How good are these turbos? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-21-2010, 09:03 PM Thread Starter
# .57 compressor wheel trim mapped for low & high boost setups
# Oil fitting gaskets & mounting studs included
# Capable of producing over 450 horsepower
# wet float bearings & properly balanced
# 3" inlet diameter with a 2" outlet
# .50 A/R compressor housing
# .63 A/R turbine housing
# 1/8 NPT oil inlet
# T3/T4 hybrid
Twin set-up
paxton50mustang is offline
post #2 of 3 Old 05-22-2010, 05:32 PM
04Ryan's Avatar
Ebay turbo? If so stay away...they are junk. The oil seals will go quickly even with a restrictor. The thrust bearings are junk...so soon as you put some boost on them it the thrust bearing gives way which puts too much side load on the oil rings.
If it's a Garrett or Precision then yea good turbo's! I personally think the T04E 50 trim has a better map.
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #3 of 3 Old 05-22-2010, 07:54 PM
You need to know what kind of T4 cold side
and Stage trim the hot side has.
and what he ^^^ said
r.barn is offline
New to turbos? is this one any good? Blown364ford Turbochargers 0 05-04-2005 03:35 AM
Turbos, Turbos, Turbos / Video From U.S. Nats @ Bradenton Mr. Fordman Turbochargers 0 02-08-2005 10:20 AM
T-61 turbos? Any good? gt23 5.0/5.8 Engine Tech 0 04-08-2002 12:09 AM
T-61 turbos? Any good? gt23 Turbochargers 0 04-08-2002 12:07 AM
