On3 89GT build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 94 Old 05-17-2010, 10:30 PM Thread Starter
On3 89GT build *picture update*
Installing the 70mm ON3 kit with the ON3 70mm turbo
Mods list is as follows
Holley systemax II upper/lower
TFS twisted wedge aluminum heads
FMS E303 cam
PA Super comp C4 trans with brake and reverse V/B
327 gears
Yukon hardened axles
On3 70mm turbo kit
Tweecer RT
AEM wideband
6AL2 box
no smog no a/c
FAST 60# injectors
PMAS blow thru MAF
aeromotive a1000 pump
stock fox tank with sump welded in
-10 feed/-8 return
UPR fuel rails
13101 aeromotive FPR
looking to run around 12-15lbs
stock block and bottom end
pics coming soon
anyone have and HP/TQ estimates and a 1/4 and mph times?
93coupee is offline
post #2 of 94 Old 05-17-2010, 10:43 PM
turbocar's Avatar
530/570 through the auto with 12-15lbs? just my guess. no matter what it should run good, lmk how the tweecer r/t is.
1993 GT 357W T76
turbocar is offline
post #3 of 94 Old 05-17-2010, 10:48 PM
90fiveoh's Avatar
I made 522/488 through a t-5 and a very mild tune on 12psi. Only with Gt40x heads and b cam. Your car would probably be close to 500rwhp with that setup on 12psi. And 1/4 times with that setup should easily do mid high 10's at 125-130mph
90 Turbo GT
90fiveoh is offline
post #4 of 94 Old 05-17-2010, 10:49 PM Thread Starter
Got a friend writing me a tune then once it's running we will do some street tuning also gonna add a meth injection system for a little more powa
93coupee is offline
post #5 of 94 Old 05-17-2010, 10:51 PM Thread Starter
I'm shooting for some 10.2s at around 130-135
93coupee is offline
post #6 of 94 Old 05-17-2010, 11:02 PM Thread Starter
Also using ARP header studs and no oil filter relocation
should I get a catch can and what's the best way to route it?
93coupee is offline
post #7 of 94 Old 05-18-2010, 09:55 AM Thread Starter
And how good do the on3 wastegate and BOVs perform? Thinking bout going to tial products just for my saftey and knowing it will hold up....
93coupee is offline
post #8 of 94 Old 05-18-2010, 09:56 AM Thread Starter
Also my car made 310 n/a so I was just shooting for 450rwhp anything above that is just fine aswell haha
93coupee is offline
post #9 of 94 Old 05-18-2010, 01:23 PM
Cansogo's Avatar
FMS E303 cam
327 gears
On3 70mm turbo kit
Tweecer RT
AEM wideband
6AL2 box
no smog no a/c
FAST 60# injectors
PMAS blow thru MAF
-10 feed/-8 return
UPR fuel rails
pics coming soon
Thats funny...thats what I got -60#'s...I went with 42#'s & a 255 pump. Maybe when we are done we can see who has the best E.T
Late 30's not so fat anymore white guy drivin a Turbo 5.0.....15 years TOO late
09' G8 GT tune & 100 shot 12.2's
67 Nova LS1 MS3 150 shot...11.2's
2003 pink Barbie jeep....Cause the girls LUV it!
Cansogo is offline
post #10 of 94 Old 05-18-2010, 01:44 PM Thread Starter
Same hci setup? Just diffrent injectors and pump?
93coupee is offline
post #11 of 94 Old 05-18-2010, 02:25 PM
90fiveoh's Avatar
Everything has been great so far with the WG and BOV. Held steady boost on the dyno. I've put 200+ miles on the setup since tuned and everything is still good.
90 Turbo GT
90fiveoh is offline
post #12 of 94 Old 05-18-2010, 02:30 PM Thread Starter
How much boost u running?
93coupee is offline
post #13 of 94 Old 05-18-2010, 05:39 PM
Cansogo's Avatar
[QUOTE=93coupee;9805022]Same hci setup? Just diffrent injectors and pump?[/QUOT
Yep.....I was going to go with a SSI intake but I came across a cheap holley so I'll throw that at it & see!
Cansogo is offline
post #14 of 94 Old 05-18-2010, 11:56 PM Thread Starter
Haha that's weird on same combo.. Even tranny?
93coupee is offline
post #15 of 94 Old 05-19-2010, 12:17 AM
90fiveoh's Avatar
12lbs
90 Turbo GT
90fiveoh is offline
post #16 of 94 Old 05-19-2010, 03:35 PM
Cansogo's Avatar
Same except it's not a PA A friend did it for me
I'm trying to do it all for 12K including car....& I also am going to run 12-13 PSI
Cansogo is offline
post #17 of 94 Old 05-19-2010, 04:29 PM
1992Hatch's Avatar
subscribed
2007 Ford Escape XLT - DD
1992 Mustang LX - Weekend toy
4cyl to 5.0 - auto to 5 speed - 4 lug to 5 lug with 18" FR500's - BBK shorty headers, BBK catted X pipe, MAC flowpaths with Flowmaster 3" tailpipes
1992Hatch is offline
post #18 of 94 Old 05-19-2010, 08:09 PM Thread Starter
Dang big baller! Haha I won't even get close to 12k even with price of my car because I've bought damn near everything used haha
93coupee is offline
post #19 of 94 Old 05-20-2010, 04:44 PM
Cansogo's Avatar
BaaaHaaa..........You got anything laying around I might need?
Remember I'm in Canada everthing is twice as much!!
Cansogo is offline
post #20 of 94 Old 05-20-2010, 07:08 PM Thread Starter
Heck I dint even hve everything for mine yet still lacking all my fuel hose
ends and fittings and msd box and few other things
93coupee is offline
post #21 of 94 Old 05-22-2010, 12:56 AM Thread Starter
started install today...got pretty far in the 5hrs i worked on it... have a few issues...my coldside pipes on passanger side is way outta wack...already know im gonna have to cut it to fit my PMAS 3" flowtube..but the two tubes arnt lining up correctly.. anyone have pics of inside passanger side fenderwell of their kits?
93coupee is offline
post #22 of 94 Old 05-22-2010, 01:17 AM Thread Starter
Got ALOT done today,, took front clip off, installed all cold side.. most hot side... etc
93coupee is offline
post #23 of 94 Old 05-22-2010, 11:50 PM Thread Starter
Bump
93coupee is offline
post #24 of 94 Old 05-24-2010, 09:22 PM Thread Starter
Anyone? Need pics of the inside passanger fenderwell
93coupee is offline
post #25 of 94 Old 05-25-2010, 08:23 PM Thread Starter
Guess no one can help
93coupee is offline
post #26 of 94 Old 05-25-2010, 08:45 PM
90fiveoh's Avatar
I can see if I can dig up any pics of inside the fenderwell. I cant take any now because I have the liners back in and they are a PITA to take in and out with all the wiring in the fender.
I know that the pipes arent perfectly lined up, one is cocked slightly
90 Turbo GT
90fiveoh is offline
post #27 of 94 Old 05-25-2010, 09:13 PM Thread Starter
Mine is WAY off BUT... My tranny isn't in the car so motor leans forward which i know helps none and I also enlarged the hole in fender where the pipe comes out cause i know that needed to be done
93coupee is offline
post #28 of 94 Old 05-25-2010, 10:33 PM
Question what brand and size convertor you running? How much does it stall?
Tobacco barn5.0 is offline
post #29 of 94 Old 05-25-2010, 11:00 PM Thread Starter
Dynamic 9" converter
Stall is 4200-4500
custom turbo converter
93coupee is offline
post #30 of 94 Old 05-25-2010, 11:41 PM
Fast87FiveO's Avatar
dang same exact motor i went with but my botoom end is a 306... and i ran 42's with a 255 in-line and a 255 in take pump
Brake Racing
Fast87FiveO is offline
post #31 of 94 Old 05-26-2010, 06:31 AM Thread Starter
Yea seems to be a popular H/C/I combo
93coupee is offline
post #32 of 94 Old 05-26-2010, 08:30 PM
Stall is 4200-4500
Thanks, Just bought a used c-4 setup with what i thought was a 10" dynamic converter called them up and they recommended a 9" to stall what yours does. The one i bought is suppose to stall 3500, plus they dont recommend using a 10" convertor with a transbrake. My setup is a little different to where i am using gt-40 p heads, also going to use the stock cam.
post #33 of 94 Old 05-26-2010, 09:00 PM
Trader Feedback: (55)
92 Hatch On3 Turbo, T56
92 Vert 349 Lunati Stroker T5
87 Gt Eddy HCI T5
87 Notch in progress
fmyth is offline
post #34 of 94 Old 05-26-2010, 09:24 PM Thread Starter
Looks like urs fit pretty straight on the 2 pipes where they meet
93coupee is offline
post #35 of 94 Old 05-26-2010, 11:21 PM
Yeah, well it took a little wrestling to make it work. Had to enlarge the inner fender hole to let the discharge move towards the firewall. It was definatley the worst part of the install followed by fitting the innercooler behind the nose.
87 Gt Eddy HCI T5
fmyth is offline
My On3 3v Turbo Build Thread Lowvez Turbochargers 129 08-05-2013 02:18 PM
My On3 Build vorga Turbochargers 172 09-10-2012 10:05 AM
A 5.0L On3 Turbo build 90fiveoh Turbochargers 53 11-10-2011 01:35 PM
92 On3 Turbo Build fmyth Turbochargers 214 11-20-2010 07:24 PM
my on3 turbo build up jaxboostedGT Turbochargers 205 08-13-2010 10:42 PM
