start up help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-16-2010, 03:05 PM Thread Starter
start up help
Getting ready to install my new motor along with my new turbo set up ..
Iam gona be going with 83lbs injectors ,and a chip, My question is should i start the car with stock injectors just to get some idle run time on the motor before taking it to the dyno?
mikeextrafast is offline
post #2 of 5 Old 05-16-2010, 03:52 PM
Rich G's Avatar
Trader Feedback: (35)
If your mass air meter is calibrated for those injectors I would say no.
Rich G is offline
post #3 of 5 Old 05-16-2010, 08:05 PM Thread Starter
should i put the stock mass air and stock injectors for the start up ? or should i put the 83s and its mass air ,dont want it so rich that it washes the bearings....
post #4 of 5 Old 05-16-2010, 08:58 PM
Rich G's Avatar
If the mass is calibrated then it wont be too rich..thats the point of the calibration.. dont worry about the 19's
Rich G is offline
post #5 of 5 Old 05-17-2010, 12:38 PM Thread Starter
so what you are saying is if i use the mass air for the big injectors it will ok to start up ?
Car will not start,let sit then wiil start -runs great while driving wedge-mo GT & SOHC 2 12-04-2009 11:07 PM
New heads and stuff - start then no start - code 96 - fuel pump - help Hi-Po 5.0/5.8 Engine Tech 4 06-15-2009 09:47 AM
cold start is perfect. start-up slow when hot. starter going south? stanger maniac 94/95 Tech 8 09-05-2007 03:05 PM
Car bogs hard after cold start. Start is tough. Chris_Red_V6 94/95 Tech 2 07-14-2005 10:55 PM
Cold start problem: Start, stall, Start Whiterag 5.0/5.8 Engine Tech 2 11-30-2001 06:53 PM
