throttle bodies that will fit on3 foxes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-15-2010, 04:39 PM Thread Starter
89slowgt331's Avatar
Trader Feedback: (22)
Hey, alot of people have already run into this but i thought it might help some guys just starting there turbo build, the 90 degree coupler from the charge pipe to the throttle body has an inlet diameter of 3" and many aftermarket tb's have an inlet casting of 31/4", there are ways to solve this if you aready have a TB that dosnt fit. here is the inlet diameter of the tb's I've had it might help someone looking
3" Throttle Bodies= factory, ford racing 65mm, mac 70mm, accufab street 65mm and 70mm
3 1/4" throttle Bodies= BBK/Edelbrock 65mm-75mm, professional products 65-75mm,
if anyone would like to add to this list feel free
89slowgt331 is offline
post #2 of 10 Old 05-15-2010, 06:04 PM
Easy fix, just lube the outta ring of t/b and it will fit nice and tight
93coupee is offline
post #3 of 10 Old 05-30-2010, 10:43 PM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
boiling them makes them nice and flexible also.
after it gets used to being on the car it will come on and off easier.
mcj50 is offline
post #4 of 10 Old 05-30-2010, 10:50 PM
Trader Feedback: (55)
Couldnt get mine to fit on my 75mm tb so I installed a coupler between the elbow and the TB. Bought it at Autozone for 12 bucks or so. It was a thinner/cheaper silicone and was easier to stretch. If I had it to do over I'd buy a 90deg silcone elbow from siliconeintakes.com with a 3 and 3 1/2 ends. I used this on my last car and the 3 1/2 fit the 75mm TB.
http://www.siliconeintakes.com/produ...e59e3085ff27d3
92 Hatch On3 Turbo, T56
92 Vert 349 Lunati Stroker T5
87 Gt Eddy HCI T5
87 Notch in progress
fmyth is offline
post #5 of 10 Old 05-30-2010, 10:50 PM
WHITEMACH's Avatar
Trader Feedback: (23)
got a 75 mm just a little vasoline she goes right on.
2012 GT AUTO
bbr tune ,bbr x-pipe,jlt cold air
[email protected]
WHITEMACH is offline
post #6 of 10 Old 05-31-2010, 12:23 AM
Yup just get a flathead screw driver some wd40 and it goes right on
93coupee is offline
post #7 of 10 Old 06-04-2010, 01:33 AM
wd40 is not silicone friendly it will actually break it down over time, an cause it to degrade, leading to a air pocket in the coupler or complete failure, &/or leaks. highy suggest vasaline or water. or any other neutral pertoleum by product.
sceviours197 is offline
post #8 of 10 Old 06-04-2010, 01:03 PM
Well I didn't soak it in wd40 lol just put a little on my finger rubbed it on tb ring and slid coupler on and used flathead to get other side on and nice tight fitment
93coupee is offline
post #9 of 10 Old 06-05-2010, 08:08 AM
Rich G's Avatar
Trader Feedback: (35)
I always use dish soap
Rich G is offline
post #10 of 10 Old 06-05-2010, 10:08 AM
Trader Feedback: (41)
Don't forget to talk dirty to it as it is going in.
stangjumper is offline
caster camber plates....will foxes' fit on SN's? bolt-on-bandito 94/95 Tech 15 06-01-2009 07:24 PM
Are these throttle bodies the same? capritoms 5.0/5.8 Engine Tech 2 02-23-2007 04:48 PM
1995 Cobra wheels Fit Foxes? PoorMan Wheels and Tires 29 11-21-2006 07:10 PM
throttle bodies Schef SVT & DOHC 7 01-13-2005 01:12 PM
lost some throttle response..Ques. about throttle bodies 89COUPELX 5.0/5.8 Engine Tech 7 12-05-2002 01:12 PM
