Tuning after installation etc. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-14-2010, 04:02 PM Thread Starter
Turbo99svt's Avatar
What do you most guys do about the first start up after installing turbo?
I was kinda thinking of seeing if anyone does like mail in tunes so i can actually drive it b4 i get it tuned so i can make sure everything goes smooth at the dyno. And with all the changes i was told the car would not even start with 60lbs. I could def use some advise with some people with experience.
My set up is a on 3 performance 4v kit, turbonetics 60-1, turbosmart wastegate, 60lbs, 03 cobra pumps.
Any info would be great
1999 Mustang Cobra
On your own performance (on3) turbo kit TC78, Diamond pistons, Manley h beam rods, Forged Crank Kurgan tuned 580hp 605 tq on 76mm, 01 cobra heads, Built Th400 trans, Straight axle
Turbo99svt is offline
post #2 of 8 Old 05-14-2010, 11:06 PM
I run 60's and a pmas hpx mass air and it started up after 2-3 tries and after that would start right up and idle perfectly... now my tuner said not to drive it that way so I didnt I just towed it to his shop.
1loudsuv is offline
post #3 of 8 Old 05-15-2010, 02:00 AM
i just got my flash tune by email on my 4.6 after putting my turbo on with 60lb injectors, 05+slot style MAF, cams, etc. and it started fine now, still fixing small things, but my tuner told me its fine to drive, just dont go into boost all crazy and stuff just to get it to his shop to dyno. call him and ask. his name is Justin at VMP tuning. plus you wanna fix all the leaks and issues before you take it to get tuned. that will make it less stressful for your tuner to have to deal with.
jaxboostedGT is offline
post #4 of 8 Old 05-15-2010, 10:24 AM Thread Starter
Turbo99svt's Avatar
Ya I just wanna start with a real light spring so I can make sure everything is good b4 I tow it all the way to a dyno and like u said make it stress full on my tuner. Vmp is where I ordered my maf from how does the flash over email work?
1999 Mustang Cobra
post #5 of 8 Old 05-15-2010, 10:38 AM
y2k02's Avatar
Your tuner ld be able to send you a tune to get it running. You would need a xcal to load the tune.
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
post #6 of 8 Old 05-15-2010, 12:08 PM Thread Starter
Turbo99svt's Avatar
I have a predator tuner? would i be able to do it with that
1999 Mustang Cobra
post #7 of 8 Old 05-15-2010, 08:55 PM
y2k02's Avatar
You will have to find a tuner that uses that software.
y2k02 is offline
post #8 of 8 Old 05-15-2010, 09:07 PM
i know that VMP is SCT dealer, but im not sure about predator tuners. just call and ask him. its yes or no. what will it hurt.
MMP HAS IN HOUSE TUNING & INSTALLATION AVAILABLE....LOOK WITHIN!!!! Muscle Motors Performance Advertiser's Showcase 1 09-21-2005 07:28 PM
MM coilover fine-tuning after installation Irish1 Road Racing/Auto X 4 07-28-2003 10:01 PM
FMU Installation and Tuning FAQ Cartech Preston 94/95 Tech 1 07-08-2002 05:08 PM
FMU Installation and Tuning FAQ Cartech Preston GT & SOHC 0 07-08-2002 02:16 PM
