Turbo Build 92 GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 44 Old 05-13-2010, 08:27 PM Thread Starter
Rich G's Avatar
Trader Feedback: (35)
Turbo Build 92 GT
So the build has been done for a while but looking for a place to put all the info, basically a log for myself, and hope others enjoy it along the way.
Current Mod List as of 05/13/10
Mod List
Engine
Stock Shortblock
Trick Flow Heads
Trick Flow Stage 1 Cam
Ford Racing 1.6 Rockers
Ford Racing 42lb injectors
Holley Systemmax Intake
Accufab 75mm Throttle Body
PMAS 80mm Blow Through Mass Air
Ford Racing Spark Plug Wires
Accufab Adjustable Fuel Regulator
B & G 70mm Turbo Kit
Magnaflow Cat-Back Exhuast
Trick Flow Valve Covers
Summit Racing Radiator
MSd Blaster Coil
Mark 8 Fan
MSD 6AL-2 ignition
Drivetrain
PA Supercomp AODE, Manual VB with TransBrake
Hurst ¼ Stick Shifter
PI Converter, stalled by FTI Triple Disc Lockup 3800 Stall
Ford Racing Aluminium Driveshaft
Ford Racing 31 Spline cobra Trac-Lok Diff
Strange 31 Spline Axles
9" Style Housing Ends
T/A Performance Rear End Girdle
Ford Racing 3.27:1 Gear
UPR Double Adjustable Upper Control Arms
UPR Subframe connectors
Granatelli Rear Lower Control arms
Jamex Springs
Wild Rides Battle Boxes
Team Z Anti-Roll Bar
Strange 10 Way Adjustable Struts
Strange 10 Way Adjustable Shocks
Interior
Autometer Shift Lite
Autometer Water Temp Guage
Autometer Oil Pressure Guage
Autometer Boost Guage
Autometer Fuel Pressure Guage
Autometer Wideband
Exterior
Weld Prostars 15x3 & 15x8 w 5.5bs
Cervinis 4' cowl Hood
Mickey Thompson 275/50/15 Drag Radials
Misc.
NOS External 255 Fuel Pump
255 In-Tank Fuel Pump
Taylor Battery Box
Moroso cut-off Switch
Moroso Coolant Overflow
Moroso Breather Tank
130amp 3g alternator
Turbosmart two stage manual boost controller
Overview of build
Stock 1989 302 HO Shortblock
Trick Flow Twisted wedge heads
Trick Flow Stage 2 Camshaft (still debating if I want to revert back to stock)
Holley Systemax Intake
BG Custom Turbo Kit (http://bgturbokits.com/store/index.p...products_id=43)
42lb Injectors
80MM Blow Through Mass Air Meter
It all started here
One I started undoing the headers I decided to myself I would never deal with that hassle ever again.
So goodbye Headers and cats
Yanked the heads and I found this
Didnt feel like cleaning the block,heads,intake right now so I decided to start prepping for the turbo install.
Made a bit more progress, got the motor ready for the heads... I should really do something about the ugly ass engine bay
These babies are going to Mosler in the morning, found a few pits and stuff gonna have them deck them just enough to clean em up
Moved my breather tank
Ready to put my cam in
TFS Stage 1
Started rearranging my gauges, made the fuel gauge visible for tuning, never was able to see it and have to open/close the hood just to make small changes
Got the new wideband in, by the way anyone looking to buy one a few sellers on ebay have the widebands for more than 100 bucks cheaper than summit
Well I finally got some stuff done.
Rich G is offline
post #2 of 44 Old 05-13-2010, 08:27 PM Thread Starter
Rich G's Avatar
Stopped at Murrays and picked up some goodies
Installed the heads
90ft lbs on the top, 80 on the bottom using moly
Just waiting on the kit
kit arrived
Started fitting the kit
Had to trim the passenger side swaybar mount a bit
Well I finally got around to doing some other things, seems like everyday I have to wait till I can go to work and get stuff I need.
Got majority of the hotside done and mounted the IC
Wrapped the downpipe
More fitting but almost there
Rich G is offline
post #3 of 44 Old 05-13-2010, 08:28 PM Thread Starter
Rich G's Avatar
Just gotta throw the bumper back on and throw the radiator in but im gonna wait till it runs to make sure I have no major leaks or anything.
I had to buy a 3.25x 3.0 reducer to come off my tb, besides because my egr is deleted the pipe didnt even come close to reaching.
Only thing I am a bit worried about is how close the intake pipe is to the downpipe. I will get a bit more clearance I think once the tranny goes in and picks up the back end of the motor.
Also the piping on the inside of the fender is close to rubbing and I am afraid its going to rattle once the engine is running
Well I had my exhaust done today
Magnaflow mufflers
3.5" - > dual 2.5"
its amazing how quiet it is, in the car you can barely hear it running.. well until the wastegate opens up and it sounds like a dumptruck.
Might have to put a muffler on it or something.
On a side note alot of you guys were right, the dropoff between gears is horrible.. almost feels like the car shuts off between shifts.
Car is runnign abotu 10pi of boost, feels slightly slower than it did with the blower on it though, might have to up the boost.
http://s724.photobucket.com/albums/w...t=MOV02681.flv
Spent some time on the Dyno
http://s724.photobucket.com/albums/w...t=MOV02702.flv
Well shes running, I just took her out for the first time... its a weird feeling driving the auto. I ended up having to mount the 1/4 stick into the ashtray.
I had to fill in the stock shifter hole so I figured it would be a good place to put the tranny controls.
No one makes a shifter delete plate unfortunatly
Here is what I came up with..
Digging around at work I found a piece of plastic, not sure what kind.
Here it is mounted, I dont really like the way I used the screws but it works for now
Made it to the track
new pb
http://www.youtube.com/watch?v=Fyrirst3T7E
http://www.youtube.com/watch?v=PSgThFEeyd4
http://www.youtube.com/watch?v=Q-7ONZKIWx0
Well I decided I want to route my wastegate back into the exhaust.. tired of the #### sounding like a dumptruck under boost.
I called up Darin @ RPS and got a bunch of pipes and the fitting to go to the wastegate.
I am not the best welder by any means and I dont have a pipe bender so I am gonna do what I can, I will prolly take it to a pro welder when done and have them tig weld all the seems nicely.
I am still looking for a good way to separate it from the DP because I cant find a 1.75" band clamp... but for now I will probably just weld it in place and then cut it when the time comes.
The pipe will run under the k-member and connect into the exhaust.
More pics to come as I get further along
Finished
I decided I didnt like how the intake pipe was, the problem was my EGR delete spacer made it so the pipe didnt reach, and no one makes a 3.25-3.00 right angle long reducing silicone elbow so I redid the pipe, I also cleaned up the engine bay quite a bit.
So I wanted to redo my wastegate routing
Version 3.0!
Exhaust runs through the k-member now, used wastegate flanges for the joints
Rich G is offline
post #4 of 44 Old 05-13-2010, 08:28 PM Thread Starter
Rich G's Avatar
Added a V-Band to mt downpipe
I decided to move my MSD into the car, so I made a bracket for it to sit behind the glove box, once the glove box is closed you dont see it, i can easily adjust the msd and the glove box is still 100% functional
I went to a N2S Track Rental and the local photographer got these pics for me!
The way the car sits right now
Rich G is offline
post #5 of 44 Old 05-13-2010, 08:29 PM Thread Starter
Rich G's Avatar
Reserved for Future Use
Rich G is offline
post #6 of 44 Old 05-13-2010, 08:29 PM Thread Starter
Rich G's Avatar
Rich G is offline
post #7 of 44 Old 05-13-2010, 08:38 PM Thread Starter
Rich G's Avatar
Rich G is offline
post #8 of 44 Old 05-14-2010, 12:51 AM
EL-CUCUY's Avatar
Awesome #'s !!! i like the fact that its still the stock block. What else do you have planned for the car?
EL-CUCUY is offline
post #9 of 44 Old 05-14-2010, 04:44 AM Thread Starter
Rich G's Avatar
Not sure to be honest, looking into getting into four wheeling so the car has just been sitting recently.
Rich G is offline
post #10 of 44 Old 05-14-2010, 09:25 AM
Djstorm100's Avatar
how do you like riding around with no heat/a/c?
Djstorm100 is offline
post #11 of 44 Old 05-14-2010, 09:49 AM
TimP's Avatar
Trader Feedback: (89)
Great thread. I've been a casual follower of your car, for the past few months.
Electric Currant Red 93 LX Hatch: July 98 MM&FF Feature Car, 9.39 @ 144.
Dark Grey Metallic 87 LX Notch: gears, exhaust, shift kit.
TimP is offline
post #12 of 44 Old 05-14-2010, 09:59 AM
Nice car. This thread reminds me of my own!
Good job.
Die-Laughing is offline
post #13 of 44 Old 05-14-2010, 10:11 AM Thread Starter
Rich G's Avatar
no a/c sucks.. dont really need heat in S. Fla
Rich G is offline
post #14 of 44 Old 05-15-2010, 04:17 PM
89slowgt331's Avatar
Trader Feedback: (22)
good thread rich, i ran into the throttle body inlet issue, i have a list of tb's with 3" inlets and tb's with 3 1/4" inlet i argued with a local performance parts shop owner on this, he owns 2 mustangs and thought all 65 to 75mm tb's had the same inlet diameter
89slowgt331 is offline
post #15 of 44 Old 05-15-2010, 05:50 PM
jturmanator's Avatar
Rich, how much boost you running and whats your car weigh?
jturmanator is offline
post #16 of 44 Old 05-15-2010, 09:40 PM
Whats up rich, (flewbyu) from N2S. Just wanted to ask you what timing are you running, locked or not and how is your pcv system set up? Thanks
ds9182 is offline
post #17 of 44 Old 05-15-2010, 10:09 PM Thread Starter
Rich G's Avatar
Running 20degrees of total timing, tuned through a diablosportchip, I deleted my PCV and put a breather tank
Really? Thats pretty frigging sad... I mean what does he think the numbers mean then? Are you sure he didnt mean the same Outside diameter?
My 10.4 pass was about 15psi and the car weighs 3280 without me and I weigh about 280
Rich G is offline
post #18 of 44 Old 05-15-2010, 11:16 PM
how hard is it to change spark plugs in a turbo car
chaddy187 is offline
post #19 of 44 Old 05-16-2010, 08:52 AM Thread Starter
Rich G's Avatar
Passenger side is a pain in the nuts, drivers side is super easy
Rich G is offline
post #20 of 44 Old 05-16-2010, 02:03 PM
Thanks for the info, I can't wait to build another turbo stang.
ds9182 is offline
post #21 of 44 Old 05-17-2010, 12:45 AM
EL-CUCUY's Avatar
What options did you get with the BG turbo kit??
EL-CUCUY is offline
post #22 of 44 Old 05-17-2010, 09:58 AM
I have a B&G kit and I have to take the whole passenger side off including the header just to change the plugs. Are you able to get the plugs off with the header on?
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #23 of 44 Old 05-17-2010, 10:44 AM Thread Starter
Rich G's Avatar
I used to just unhook the downpipe and get it as high as I could (which isnt very high) and then change them roughly.. now I added the v-band halfway which makes it sooooooo much easier
Rich G is offline
post #24 of 44 Old 05-17-2010, 12:37 PM
Yeah taking the downpipe off takes about 5min b/c I am running it open. Just unbolt it and pull it out of the engine bay. But having to pull the header is the part I hate. I can barley get a spark plug boot on the #3 plug with header on. Anyways no more hijacking the thread from me. Car looks good man. I def feel you on the no a/c. Here in Houston it gets really hot!
post #25 of 44 Old 05-17-2010, 02:15 PM Thread Starter
Rich G's Avatar
That sucks, my plugs and wires fit really easily on my headers.. how old is your kit?
Rich G is offline
post #26 of 44 Old 05-17-2010, 04:07 PM
I bought it last August. I have the whole kit off now just so I could close the gap. The driver side is great but passenger side sucks. I even had to make a custom allen wrench so that I could get the header bolts in and out. I had to dent in some of the primarys just to get the bolts to go in.
post #27 of 44 Old 05-17-2010, 04:14 PM Thread Starter
Rich G's Avatar
yea I had issues with the bolts also
Rich G is offline
post #28 of 44 Old 05-17-2010, 04:21 PM
I read that you are interested in 4x4's.... If you loose focus on the car would you be willing to sell it?
boostcrutch is offline
post #29 of 44 Old 05-17-2010, 04:40 PM
Nice build...that radiator looks like it was making milkshakes
1991 GT, Bolt ons and some suspension mods, currently gettin rid of the slushbox
'91GT is offline
post #30 of 44 Old 05-17-2010, 05:34 PM Thread Starter
Rich G's Avatar
for the right price of course!
Rich G is offline
post #31 of 44 Old 05-17-2010, 08:47 PM
90fiveoh's Avatar
nice setup. how is it with the manual vb? I was debating getting a baumannator or just going with the manual vb.
90 Turbo GT
90fiveoh is offline
post #32 of 44 Old 05-17-2010, 11:47 PM
EL-CUCUY's Avatar
EL-CUCUY is offline
post #33 of 44 Old 05-18-2010, 03:13 PM Thread Starter
Rich G's Avatar
The only upgrade I got was the 3" aluminum cold side, I went with the MP turbo, turbo concepts wastegate, and tial BOV
Rich G is offline
post #34 of 44 Old 05-19-2010, 01:19 AM
EL-CUCUY's Avatar
Cool thanks for the info
EL-CUCUY is offline
post #35 of 44 Old 05-19-2010, 01:28 AM
Turbo SN's Avatar
awesome build. i am hoping mine goes that fast. i've got tfs heads with a 5 angle valve job, box intake, precision 76 mm,built turbo 400, 83# injectors with a complete fuel system, and a fast system. only real difference is my car should weigh around 2750 without me in it. find out in a couple more weeks when car comes back from getting a 10 point.
Turbo SN is offline
The Turbo Chassis School 2000 Mustang GT turbo build. [email protected] GT & SOHC 10 06-06-2010 01:23 PM
For a turbo build: Better to build bottom end or get HCI demarsjcd Turbochargers 9 05-05-2010 06:57 PM
Looking to build a turbo 2V street car. Need help on turbo setup!!! milleniumGT Turbochargers 11 01-13-2008 01:35 PM
New Turbo Build Up SlwGT Turbochargers 2 10-16-2007 12:43 PM
build me a turbo liftedford17 Turbochargers 1 09-20-2004 01:03 PM
