Head Gasket Recommendation? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-13-2010, 04:27 PM Thread Starter
I had this thing on the road for 1 day before it popped a head gasket.
Now, Im switching cylinder heads from stock E7's to AFR185's.
If i understand correctly, the Cometic head gaskets dont quite seal properly on undecked surfaces? Is this correct?
I would like to know which head gaskets would be best for my application.
Also, can you guys help me with some Cam Recommendations? I'd like to do a cam while its apart.
And.. Can i use the same style spark plug with the AFR heads?
OK..Heres some info on the setup..
Purpose:
85% Street
15% Drag
Reliable Daily (In Season)
The Car Made 408whp 424ftlbs @ 8psi & 11.5:1 AFR
On stock heads & cam. I cant wait to find out what the AFR185's & new Cam will do!
Setup consists of..
Engine:
-Stock 90k Mile 302 (Going to notch pistons)
-Stock heads (Now #1387 AFR185's)
-Stock Cam (Now__________?)
-1.7 roller rockers (Now 1.6 roller rockers)
-9333-pt1 Head gaskets (Now___________?)
-ARP Head Studs
-FMS 50oz balancer
-ES Poly Motor/Trans Mounts
Transmission:
92' T5
CenterForce DF
3:73 screw (want 3:27 but, gonna try this first)
275/40/17 street tire out back
Air/Fuel:
-Truck/Systemax Lower Intake
-Jegs Max Box upper / Die-Fab systemax flange
-Die-Fab 75mm EGR Delete Plate
-Stock fuel rails
-Aeromotive 1:1 FPR / Marshall Gauge
-FMS 42lb injectors
-Pro-M Blow thur meter
-TFS 75mm Throttle body
Ignition:
-Autolite 23's (.029gap)
-FMS 9mm Plug wires (taylor fire boots)
-MSD 6AL
-MSD Cap & Rotor
-MSD Coil
Power Adder:
-On3 5.0 Turbo Kit
-On3 46mm Wastegate
-On3 50mm BOV
-Master Power 70mm Turbo (.68ar)
Tuning:
Kurgan Tune April 2010
AEM Wideband / Analog Readout
Autometer boost gauge
Exhaust:
-Mild steel 1.625 headers
-Mild steel crossover (wrapped)
-3" SS Downpipe (wrapped)
-3"to3.5" reducer
-3.5 bullet muffler
-3.5" straight thru race muffler
-3.5" dump
Cooling:
-Mishimoto Aluminum Radiator
-Dual Electric Fans / Controller
-3" SS Coldside piping
-large front mount intercooler
Misc:
-alternator and PS relocation
-Moroso Oil Catch Can
Thanks Guys!
Die-Laughing is offline
post #2 of 11 Old 05-13-2010, 05:51 PM Thread Starter
Well, after doing some research.. Most people on the forum are saying to use the Felpro 9333 gaskets.
Thats what i was using. I guess the blame is going 100% to the stock iron heads.
I hope that the AFR's .750" Deck and a new set of Felpro 9333's will do the trick.
We will see.
Im going to have Kurgan re-tune it.. maybe even throw a couple more pounds of boost at it? It made 408whp @ 8psi, stock heads, stock cam.
What do you think i can get out of it with a set of AFR 185's and a cam @ 8psi? 10psi?
what do you guys think?
post #3 of 11 Old 05-13-2010, 08:04 PM
522
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #4 of 11 Old 05-14-2010, 09:53 AM Thread Starter
Thats Crazy Talk!
post #5 of 11 Old 05-14-2010, 03:29 PM
PowerAdder Solutions's Avatar
Trader Feedback: (230)
9333's if you have any more problems, concider MLS set. Yes, even with a stock block I know the tune will be right, so no worrie's.. I have a couple guys running MLS's with there stock block combo and doing great!
post #6 of 11 Old 05-15-2010, 03:49 PM
89slowgt331's Avatar
Trader Feedback: (22)
alot of my friends like fel pro mls, if you go that route, when i was supercharged, i sanded the deck surface to help with sealing, a ford f303 is a very good cam for that set up, you will need new plugs, i ran ngk fr5's on a NA car, ask your tuner what to use, good luck
89slowgt331 is offline
post #7 of 11 Old 05-15-2010, 08:50 PM
pkstang's Avatar
Trader Feedback: (161)
Thumbs up
x2
although for your setup i would keep the stock cam with 1.7s, and maybe retard it by 2 degrees if at all. other than that start saving money for a stronger trans.
pk
pkstang is offline
post #8 of 11 Old 05-16-2010, 02:41 AM
WhiteLX's Avatar
I've had good luck with the Ford Racing graphite head gaskets. They appear to be made by FelPro, does anyone know the FelPro part number?
1992 5.0 coupe - TTI single turbo
1986 Merkur XR4Ti - 2.3L turbo
WhiteLX is offline
post #9 of 11 Old 05-16-2010, 10:32 AM
pkstang's Avatar
why are you upping your exhaust to 3.5" after your 3" downpipe?
pkstang is offline
post #10 of 11 Old 05-16-2010, 10:21 PM Thread Starter
why are boobs good?
They just are!
post #11 of 11 Old 05-16-2010, 10:43 PM
pkstang's Avatar
you do realize that you're gaining absolutely nothing by doing that, waste of time and money, and that 3"dp is more than enough for your setup. i would focus your efforts more on the intake (need a long runner), gears (need less), tranny (bye bye T5 with the torque of a turbo setup) unless you stick to a standard aka non drag radial aka no traction type of tires. pk
pkstang is offline
Need Head Gasket Recommendation for my Turbo 94CobraGermany Turbochargers 16 10-28-2009 10:42 PM
Head Gasket Recommendation Luke87GT 5.0/5.8 Engine Tech 12 07-05-2007 01:56 PM
Head gasket recommendation GT Dan 5.0/5.8 Engine Tech 6 04-21-2006 01:02 PM
Head Gasket recommendation steve90pos 5.0/5.8 Engine Tech 8 02-05-2005 06:03 PM
Head Gasket recommendation?? collins8 GT & SOHC 1 02-15-2003 04:16 PM
