What Size Headers & Crossover For 1000+HP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-05-2010, 02:27 AM Thread Starter
Trader Feedback: (46)
I am wondering on what size headers to get 1 5/8" or 1 3/4", what size crossover 2.5" or 3.0", also if I should increase the size pipe from 3" to 3.5" from the intercooler to the throttle body? I am trying to make 1000 to 1200HP with a 327 and a Precision GT42-76 with a 1.28 A/R. I have heard of guys running 1 5/8" headers and 2.5" crossover over 1000HP is this true? Would the bigger headers and bigger crossover cause it to take longer to spool?
racsirx is offline
post #2 of 6 Old 05-05-2010, 10:25 AM
go big.
1 3/4
3" crossover
5" downpipe
3.5" coldside with big vertical flow intercooler
or an air/water cooler set-up might be better still
and GT42 is not enough turbo. GT45-08R mo-better. 88mm Borg Warner even better
at 30psi you are talking about moving some serious air.
r.barn is offline
post #3 of 6 Old 05-05-2010, 11:06 AM
jturmanator's Avatar
Just curious how much a 3" downpipe will support?
jturmanator is offline
post #4 of 6 Old 05-05-2010, 06:42 PM
danny carvalho's Avatar
http://www.turbobygarrett.com/turbob..._769112_5.html
http://www.turbobygarrett.com/turbob..._769112_1.html
Either one will get you there.
One owner 50,000 miles Dart 363, oliver rods, Karl's East Coast custom Y2k 82mm turbonetics, TW stage 2 Fox Lake, PMS, Victor intake, PMAS custom pipe for 85 lb/hr inj. T56 Magnum 6 speed w/Spec3+,756 rwhp 746 tq (pump gas, 14psi, 20*) 840 rwhp 848 tq (race gas, 16.5psi, 20*) SOLD
-2014GT/CS
danny carvalho is offline
post #5 of 6 Old 05-05-2010, 11:35 PM Thread Starter
This guy is claiming 959RWHP with a 336 and 25lbs of boost, I was told this Turbo was good for 1200+HP
http://www.turbomustangs.com/smf/ind...?topic=33131.0
http://www.theturboforums.com/smf/in...?topic=45171.0
racsirx is offline
post #6 of 6 Old 05-06-2010, 01:52 AM
1 3/4" Primaries on the headers. Good for 1500+rwhp
2.5" Crosssover good for 1000+rwhp
3" Crossover good for 1500+rwhp
The biggest Down Pipe you can fit. I have done well over 800rwhp with a 3" DP. I prefer 4" DP on anything that will see over 15lbs of boost with a single Turbo. It will ease Back pressure issues. Twins and get away with dual 3" DP's.
wickedred is offline
For Sale Brand new B&G turbo headers with crossover.. robby26wi Power Adders 2 02-08-2010 07:58 PM
B&G Turbo headers and crossover (NEW) gt93mustang Power Adders 14 11-18-2008 11:27 PM
94-95 B&G Turbo headers and crossover 86 WINDSOR NOTCH Power Adders 4 10-22-2006 10:19 AM
What size plug for EGR crossover on 460 heads? Bad88GT 351C/Big Block Engine Tech 3 09-08-2005 11:13 PM
NEED HEADERS n CROSSOVER PIPE mattred90gt Power Adders 5 03-24-2005 09:33 PM
