trick flow r series box ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-01-2010, 07:53 PM Thread Starter
builing a 351w roller block took 95 interior out and replaced it with interior out of a 2002 cobra.the stock dash had holes in it and cracks.now she is ready to get painted
so my question is has anyone ran one of these with the kind of combo that i have.its going to be more of a street car just curious how they are.look below for a list of parts i have.
351w roller block with Twisted Wedge Heads, 76mm turbonetics turbo with front mount
trick flow R series box intake
90mm accufab throttle body
PMAS blow through
60lb injectors
Ford Racing SFI Harmonic Balancer
Ford racing aluminum drive shaft
QA-1 K member with A arms
90/10 with coilovers
Real cobra R hood
Cobra front bumper
Cobra rear bumper
rear lower control arms
Tremec Transmission
2002 Cobra Complete interior
MSD6BTM with boost retard
NOS 150 dry kit
AEM Tru boost controller
15x3 and 15x10 welds wrapped in 275/60/15 Mickey Thompson Drag radials
st pete chad is offline
post #2 of 6 Old 05-02-2010, 07:41 AM
Steve O.'s Avatar
We currently have a similar 351 combo together now. Dyno'd the motor with a carb and low profile dual plane intake for simplicity reasons only. We have the box intake and think it should work well.
The box R intake and the Victor are said to be good choices. We decide not to go with the victor because of having to change the cold side piping location and the added cost of the elbow.
Horse Power TV had an episode with a 400" turbo motor with TFS R heads and the box intake that made around 1,300hp.
I think the box R intake is a good choice for your combo.
Steve
Steve O. is offline
post #3 of 6 Old 05-02-2010, 06:43 PM Thread Starter
thanks.anyone here using one nw on there car with turbo?
post #4 of 6 Old 05-03-2010, 08:08 AM
Don 95Vert's Avatar
We use one on our '95 with a 357 and a PT88 turbo - makes great power and drivability is fine. It needed the biggest hood we could find though.
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #5 of 6 Old 05-03-2010, 08:32 AM Thread Starter
damn that sucks about the hood.i just got a brand new real cobra R hood.you think if i got the k member spacers that it would clear.dont forget im running a 351w which it a bit taller.by any chance do you have any pics of your set up so i can see the clearance issue.if you send then to [email protected]
post #6 of 6 Old 05-03-2010, 01:05 PM
Don 95Vert's Avatar
Ours is a 351W based motor too and a convertible - no way would it even come close to closing when we had a Cobra R hood for it. You just need a bigger hood - no pics - sorry!
95 Lightning - Slow
10.5/135 @ 3800#
SCT Tuned
For Sale Trick Flow Box-R-Series Intake Manifold toxicgt Windsor Engine Parts 0 04-11-2010 09:50 PM
Trick Flow Box R Series Intake for 351 (NEW) slowwrx Windsor Engine Parts 5 01-28-2009 02:54 AM
Trick flow R series box intake question. 8yourz28 94/95 Tech 12 04-10-2008 12:44 PM
F/S Trick Flow box upper (R Series) muchos1898 Fuel System & Related 7 02-10-2007 03:51 PM
Trick Flow Box-R Series Intake. Who is running one? 91ConvLX 5.0/5.8 Engine Tech 18 02-03-2006 08:22 PM
