stock motor, which turbo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 04-29-2010, 08:29 PM Thread Starter
Trader Feedback: (36)
long story short, i have a 95 mustang which i have just completed rebuilding a stock motor for. just to put in and play while i save and build my big motor. well i was running a vortech s-trim, but sold that to buy a cartech turbo kit off a buddy. anyway, the turbo he gave me with the kit is a MP 76mm. too big for my little stocker.
so my question is, what would be a ideal turbo to go with? needs to be a t4 flange though.
1995 Mustang GT 5.0
DevaRoh is offline
post #2 of 19 Old 04-29-2010, 08:33 PM
lechols155's Avatar
do you plan on selling that 76mm i have a small garret turbo not sure of the size about a 58mm or so. works great for a stock motor on the street but im stepping up my game and need something bigger.
92 gt
Old setup: 100% stock w/ turbo 10.80 @ 126
lechols155 is offline
post #3 of 19 Old 04-29-2010, 08:45 PM
Turbonetics 62-1 with .81 a/r
Goldilocks size for a stock 5.0 revving to 5,500 rpm
r.barn is offline
post #4 of 19 Old 04-29-2010, 09:13 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Just run the mp76 as long as its a p-trim.
1995gtCPE is offline
post #5 of 19 Old 04-29-2010, 09:20 PM Thread Starter
honestly im not sure...just learning about this turbo stuff
1995 Mustang GT 5.0
DevaRoh is offline
post #6 of 19 Old 04-29-2010, 11:57 PM
I dont think Master power uses anything else but P trim hot sides.
Turbo Lesson for the day:
The "trim" on the hot side of a turbo is how wide of an opening there
is from the big radius of the turbine wheel to the smaller radius.
The A/R is how much the turbine housing itself narrows down into the wheel.
T-60, T-70 or T-76 can all have P trim hot sides and will spool up similarly.
the bigger turbos just have more mass and impeller dynamics on the cold side so they are
a little more sluggish spooling up on the low side but flow more on the top end.
People run 76mm on 4.6L mod motors, they also spin them 6,500+ rpm and 20psi too.
r.barn is offline
post #7 of 19 Old 04-30-2010, 08:30 AM
Just run the masterpower 76. Like R.Barn said Im sure its a P trim. Look on the hotside of the turbo and there will be a number. What does it say? Prob .81, .96 etc. I think the turbo will be fine plus able to give you alittle growing room in the future.
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #8 of 19 Old 04-30-2010, 09:17 AM
Thunder5.0's Avatar
T-62-1 here
Thunder5.0 is offline
post #9 of 19 Old 04-30-2010, 10:03 AM
I've got a 70 trim I will trade ya??!!
93coupee is offline
post #10 of 19 Old 05-01-2010, 02:35 AM
Radrick50's Avatar
Trader Feedback: (60)
While everyone is humping your leg to get your turbo, just put it on and make some good power on the street and be happy...don't waste your time switching to something smaller...when you build a 4-bolt 331 or larger, then worry about a turbo change...your stock-ish motor will work fine with the turbo you have...you'll be be smiling when you mash the "GO" pedal!
Radrick50 is offline
post #11 of 19 Old 05-01-2010, 01:20 PM
1995gtCPE's Avatar
MP makes a Q-trim 76 also, 4bolt flange or v-band.
post #12 of 19 Old 05-01-2010, 11:32 PM Thread Starter
i have it installed right now, but the car is far from running. the problem is, although the coldside is A/R .72......the hotside is A/R .100!!!! im thinking with that much of a turbine, my stocker wont spin it till it hit 5000+rpms and by then my motor will be done.
1995 Mustang GT 5.0
DevaRoh is offline
post #13 of 19 Old 05-02-2010, 07:18 AM
1995gtCPE's Avatar
If its a 1.00 exhaust housing it is a q-trim. Boost may come on a bit slow on a stock 5.0. Early ones had a 4 bolt flange, newer ones have a v-band.
post #14 of 19 Old 05-02-2010, 09:32 AM Thread Starter
Yeah mine must be an early one cause it has the 4 bolt set up.
1995 Mustang GT 5.0
DevaRoh is offline
post #15 of 19 Old 05-02-2010, 09:49 AM
1995gtCPE's Avatar
Let us know how it does on that stock motor.
post #16 of 19 Old 05-02-2010, 01:59 PM Thread Starter
in the middle of a deal now to trade turbos with another member, but if that falls through ill probably sell it and buy what i want. i know down the road ill want something similar to this turbo, but that wont be for a while. so for now, id rather run something that will be a great little combo to enjoy and have fun with my car.
1995 Mustang GT 5.0
DevaRoh is offline
post #17 of 19 Old 05-02-2010, 02:06 PM
Sell it, get a 62-1
coldside a/r doesnt mean anything.
That turbo will spool like a slug on a stock 5.0 with stock cam peaking at 5,500 rpm.
62-1 with .81 a/r will come on line like a raped ape and have massive fat low end torque
r.barn is offline
post #18 of 19 Old 05-02-2010, 02:54 PM Thread Starter
Sell it, get a 62-1
which is what i will need since im staying with my 5speed and not going auto like a lot of people these days
1995 Mustang GT 5.0
DevaRoh is offline
post #19 of 19 Old 05-02-2010, 11:01 PM
red89coupe's Avatar
Trader Feedback: (31)
62-1 with the .81a/r here and love it !! (stock motor/5 speed)
red89coupe is offline
347 n/a or Turbo Stock Motor? Coupester Turbochargers 24 05-30-2009 01:23 PM
what gears on a stock motor w/turbo?? slowblown5.0 Turbochargers 8 09-09-2006 02:07 AM
'02 GT Turbo PSI on stock motor mattdaddym Turbochargers 41 01-26-2004 09:59 AM
what turbo on stock motor? rintin Turbochargers 5 04-02-2003 08:39 PM
turbo the stock motor? rintin Turbochargers 5 03-01-2003 09:03 PM
