how much power can an A1000 pump and 8AN/6AN return support with turbo??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 04-29-2010, 03:24 PM Thread Starter
I have a 428w going in, 9:1 compression and a lentech AOD. and i think it needs a turbo...
The fuel system i have right now is rear sump tank with A1000 pump and 8AN lines and 6an return lines.
Can i get by with 700-800 Rwhp with turbo application and this fuel system??
thanks
91 coupe 65k miles - 428w 9.5:1 compression, TFS 225cnc HP, Accufab Midlengths 3 inch Mac exhaust. FTI Cam, super victor EFI, 60lb injectors - TKO600
94 cobra...Cobra R clone with stock 302cobra motor.
red93notch is offline
post #2 of 18 Old 04-29-2010, 08:14 PM
Rich G's Avatar
Trader Feedback: (35)
Subscribing
Rich G is offline
post #3 of 18 Old 04-29-2010, 08:31 PM
629RWHPstang's Avatar
no i had to upgrade my pump from the A1000 and im at 629RWHP so i doubt 800 man
90GT,R Block 347,Brodix Heads,D1-sc=629WHP/599TQ 14LBS laracca tuned
Daily driver 08 STI
629RWHPstang is offline
post #4 of 18 Old 04-29-2010, 08:43 PM
The Eliminator pump would be a little better at those levels.
The A1000 might keep up
r.barn is offline
post #5 of 18 Old 04-29-2010, 09:40 PM
Djstorm100's Avatar
thanks
do -10 to y block and run 2 -8 to the rails and -6 return and you will be pretty close to your target (say 750ish)
Djstorm100 is offline
post #6 of 18 Old 05-02-2010, 11:23 PM
j86stang's Avatar
The a1000 will never keep up. I had an eliminator pump but the noise was awful and it had issues when hot from day one. I replaced it with a fuellab pump and so far very pleased much quieter and no over heating issues.
86 gt T-top, 438,Ysi with a t56
j86stang is offline
post #7 of 18 Old 05-27-2010, 07:28 PM
Bdubya's Avatar
You didn"t say if it was carbed or injected. Makes a big difference.
Bdubya is offline
post #8 of 18 Old 05-27-2010, 08:00 PM
^ i agree, carb / FI is a big difference, regulator is going to be different especially if your going to boost it.
jaxboostedGT is offline
post #9 of 18 Old 05-27-2010, 08:31 PM
I say it can on a carb motor I have a a1000 pump and a a2000 return style regulator with -8lines behind my Camaro which has a F1-r procharger running 22lbs of boost. 1030hp/896ft lbs. will be switching to another pump soon but runs great just going to add more boost and i know it cant keep up
wild95 is offline
post #10 of 18 Old 05-27-2010, 11:37 PM Thread Starter
its fuel injected
post #11 of 18 Old 05-28-2010, 12:00 AM
A1000 with -10 feed -8return is good up to 850-900
93coupee is offline
post #12 of 18 Old 05-28-2010, 06:41 PM
SlowTA98's Avatar
I made 672whp. Through a th-400. I changed to a bigger blower and just added another a-1000. Mine was not quite maxed either with just one a-1000.
SlowTA98 is offline
post #13 of 18 Old 05-28-2010, 07:14 PM
wow, i bet thats makes allot of noise.
post #14 of 18 Old 05-28-2010, 10:46 PM
331D1SCGT's Avatar
weldon pumps FTMFW. be done with it.
http://www.weldonracing.com/product/...outlet%29.html
95GT: 302, TEA TFS heads, systemax, jay allen cam, t-70, 60lb inj, moates quarterhorse, dynamic c4, and so on...
best so far (only pass on the car) 10.72 @ 123 (needs 3.27's)
331D1SCGT is offline
post #15 of 18 Old 05-28-2010, 11:40 PM Thread Starter
Thanks for input
If i go with the weldon pump should i run 10an lines or should i keep it with 8an lines
The pump says it is for 8an.
Thanks for the link by the way.
post #16 of 18 Old 05-29-2010, 02:21 AM
Purple Haze's Avatar
Hard to beat Weldon. Their controller is a worthwhile investment for cruising.
Purple Haze is offline
post #17 of 18 Old 05-29-2010, 12:51 PM
Or use ur a1000 u have sell ur -6 return modify the -8 to run as a return and buy -10 for feed
93coupee is offline
post #18 of 18 Old 05-30-2010, 01:16 AM Thread Starter
I think i am definately going to try that first. Thanks, it is definately the simplest solution and most cost effective.
For Sale 8an and 6an Braided Hose skritt Fuel System & Related 5 04-29-2010 06:06 PM
For Sale 6AN braided hose line/6an&8an fitting sn95mustang86 Fuel System & Related 6 02-28-2010 12:07 AM
Fuel System(NEW Sump Fox Tank, All Braided Lines, 8an send, 6an return,Etc For Sale 91svtcoupe Fuel System & Related 2 02-14-2009 05:04 PM
A1000 pump and return system GRKSTL2 General Mustang Tech 0 05-16-2006 08:27 AM
