ok going turbo in new project and this is what i have to Work with. Need Advice!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-27-2010, 11:20 PM Thread Starter
Ok, So i know little to nothing about turbos and what route to take.
just picked up an SN95 and i have the following to put in the car.
This is the motor out of my fox (its getting a big motor with spray)
351w .030 over 10.8:1 static compression
Ross Flat tops, eagle h beams, scat cast crank, 94 hyd roller block.
SCE ICS gaskets, Victor Jr heads, Victor EFI intake
Tranny is a tko 600
First Item on the list... get the compression down!!
Either change out the flat tops to dished pistons, or change heads to a 70cc combustion chamber and a
.060" gasket would give me 9.2 static compression
after all said and done it would probably cost about the same.
Which should i do?
Second Item and more important....
What turbo should i go with i dont knwo the first thing about picking one out...
I want streetability.... and the potential to make about 700+ RWHP
i want to keep the factory computer and put a chip on it also.
Just from what i have seen i think a 76mm would be good but i know nothing about the AR or the types of turbos or what brands, etc.
Any opinions/facts would be very appreciated!
91 coupe 65k miles - 428w 9.5:1 compression, TFS 225cnc HP, Accufab Midlengths 3 inch Mac exhaust. FTI Cam, super victor EFI, 60lb injectors - TKO600
94 cobra...Cobra R clone with stock 302cobra motor.
red93notch is offline
post #2 of 2 Old 04-27-2010, 11:54 PM
Just swap heads, forget the .060 head gaskets
T-76 turbo should get you what you want.
Might want to go ahead step up to a 78-80mm turbo though.
GT-42 or GT-45 turbo would be good choice as well.
run biggest a/r you can find.
Master Power, Garrett, Precision, Turbonetics ........ all good brands
r.barn is offline
project advice? sn95slow 94/95 Tech 2 02-06-2010 05:50 PM
my 93 vert turbo project, on3 turbo kit ahurl90 Turbochargers 47 07-01-2009 10:09 AM
new project and need advice 86windsorstang 5.0/5.8 Engine Tech 10 10-05-2007 03:11 AM
Need Advice For Project....... sircory 5.0/5.8 Engine Tech 11 06-06-2006 10:05 PM
Any turbo Stangs on here? My junkyard Carbd turbo project.. TommysCarbd86 5.0/5.8 Engine Tech 8 03-03-2004 08:43 AM
