doin a twin turbo setup on sn95 need advice - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 04-27-2010, 05:03 PM Thread Starter
i am currently building a 347 with forged internals in my 95 mustang gt. engine is gonna be estimated to be about 425 to 450 to flywheel. i just recently bought a twin turbo setup and is needing some headups or advice on doin this deal. also i am not sure how much pain is involved and how much money ill be looking at to throw into this twin turbo setup. any help will be greatly appreciated
Ray_95mustangtwinturbo is offline
post #2 of 13 Old 04-27-2010, 10:55 PM
Not sure what you are asking but I would say go ahead and open up your wallet. If the motor alone is going to make 425hp then adding a twin setup is really going to make some great power. Obviously this will depend on the twin turbo's size and piping. You have to think about fuel to support it and ignition and then some kind of tuning aid. Give us the details on the twin setup and the motor combination?
Turbo Matthew is offline
post #3 of 13 Old 04-29-2010, 06:54 PM Thread Starter
as far as motor i have crower h beam rods, diamond -20 cc dishtop pistons 40 over. crower forged crank, main girdle and arp bolts on bottom end. set of alumunim trickflows with 2.02 valves. edelbrock rpm performer 2 upper and lower intake. having custom grind cam made for my setup. best detail for twin turbo i got is i have a/r 63 on exhaust side and a/r 50 on beauty side. my pipin is 3 inches in diameter. i plan to run msd timing control module for the turbo setup and have the fuel delivery fig out as well at least i believe lol.
post #4 of 13 Old 04-29-2010, 07:42 PM
Alex in Houston's Avatar
If it's a stock block all you list above is "fluff" at best.
A stock 302 motor will make just as much power and last just as long as the motor you describe above.
Mr. M. M. Alexander
Originally Posted by Stopsign32v View Post
Stop crying, its just the internet. Life gets alot harder than some screen name on a message board not liking what you do to your car.
Alex in Houston is offline
post #5 of 13 Old 04-29-2010, 08:44 PM Thread Starter
not sure how that would be an advice. . the bottom end is for to handle more power which is a no brainer. the upper is where im getting the power which isnt gonna be the same as a stock motor unless you go thru it which ur better off to get alumunim heads versus stock heads when it comes to getting more reliable power and having an aftermarket upper intake and lower for better flow which again stock isnt gonna beat unless you tamper with it. but the main point of this thread is to see what i gotta do to get the turbo setup goin on this motor. this is my first time dealing a setup like this. im wanting to get 10 psi out of the setup for now.
post #6 of 13 Old 04-30-2010, 11:10 AM
millhouse's Avatar
The bottom end on the stock shortblock is perfectly capable of handling more than the block itself can handle. Adding all of this...
as far as motor i have crower h beam rods, diamond -20 cc dishtop pistons 40 over. crower forged crank, main girdle and arp bolts on bottom end. having custom grind cam made for my setup.
... is just pissing away your hard earned money. If the stock short-block has good compression, just use it as is. At the most I'd throw in some moly rings and get the block cleaned/checked as well as honed. Throw in some new cam bearings while your at it and that's it! There is no need to stroke it, no need for new rods/pistons, no need for a girdle and no need for a custom cam. A stock short-block with the top end you plan on throwing on it will lay down an easy 500+rwhp at 10psi.
The 347 you plan on doing will not last long with 10psi and the likely 600-650rwhp it will lay down. To top it off, when the block splits....you are going to possibly trash that rotating assembly (yes, even with the girdle).
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #7 of 13 Old 04-30-2010, 11:52 AM
Keep your plan.
Just add a $1,300 Dart SHP block + machining cost to the bill and do NOT use
the stock block.
r.barn is offline
post #8 of 13 Old 04-30-2010, 06:41 PM Thread Starter
the plan of doin the dart block with the setup was actually planned just down the road. i came across a buddy on the deal with all the bottom end #### i just said cept the piston for 600 bucks includin the block as well. so... as far as pissin my money away i would say i didnt piss too much lol. i would like to see the darn thing out this year so i was gonna push the block but not enough to cause damage once again on the turbo setup i am not quite familiar on it. if i have to run 6-8 psi to be pushing the limit and not over ill do so. im sure ill be happy with that if i can pull it off. let me know if im talking stupid lol. anyone done the TT on a 94 or 95 mustang? if so let me know the pain or things i need to do that you wont know till you did one. thanks
post #9 of 13 Old 04-30-2010, 06:51 PM
millhouse's Avatar
I'm thinking more along the lines of 4-6psi if you are looking at keeping things somewhat safe. Again, 8psi on a stock shortblock with that top end will lay down an honest 500rwhp.
post #10 of 13 Old 04-30-2010, 07:00 PM
It might hold together for a while ....... it might blow on the 2nd dyno pull.
if blows you may trash the block, the new stroker kit you just bought,
your cam, your heads ...... everything might get trashed.
Just have to be realistic on what might happen, if you're willing to risk it
thats fine, its just a huge gamble with some expensive parts, due mainly
to impatience with "getting it running"
We all do it. Just trying to warn you away from past mistakes and wasted money
others have done. ........ I also had a buddy make 750rwhp on stock block and has not blow.....
With Pilots its called "get there itis" ....... tends to work out as well for them
as it does for our engines. ......
r.barn is offline
post #11 of 13 Old 04-30-2010, 07:10 PM Thread Starter
lol yikes didnt know the true power of doin a TT. darn thing been sitting getting a paint job done and now its in the front of my house just staring at me waitin to be running lol. like mistreatin favorite pet or something. i guess the smart thing would be to wait but heck you guys have been in my slight impatience shoes im sure lol. got ppl to shut down and shut up haha
post #12 of 13 Old 05-02-2010, 04:18 PM Thread Starter
ok so im gonna be a smart fella and hold off till i get a dart block. im not so sure about running the turbos i have seein that they have no brand to them. ive heard alot about the precision turbos and was wondering which one i should do for my setup if i go off and change turbos. also i dont want to risk the "boost creep" and heard those are commonly caused by the wastegates being too small. i dont have a clue what size or even how to tell what the ones i have are. any advice?
post #13 of 13 Old 05-10-2010, 11:29 AM
Heres the bottom line.............you really need to find someone preferably locally..who has the ability to put a tune on this car.... and guide you the rest of the way.......if you dont then you are gettin way over youre head......turbos are definately the way to go .......if youre using a stock block keep the power to 450ish at the rear wheels...you will be fine with using the stock computer with a chip no more than about 12 psi... bigger injectors and fuel pump and lines......try not to use any FMU .......anymore and youre looking at full standalone engine management ie FAST ....BIG STUFF.....more than 450ish RWHP on a stock block and youre driving a real time bomb.....................AND NO YOU DO NOT HAVE TO WITH TWINS....THEY ARE TWICE THE FUN BUT FOR YOURE SITUATION YOU WOULD BE BETTER WITH A SINGLE TURBO....PREFERABLY FROM HELLION OR TTI...BOLT ON KIT.....STICK WITH GARRET OR PRECISION TURBOS
hope this helps!
GT4788mm is offline
Twin turbo SN95 project.... slowly in progress Looking for SN95 turbo pics J_Rod Turbochargers 26 11-24-2009 08:47 PM
Anyone running a twin fuel setup on sn95 4rcfed95 General Mustang Tech 2 05-14-2008 09:02 AM
Twin Turbo Setup for SN95 with a 408 EFI matthewx Turbochargers 17 03-15-2004 02:14 PM
JY Twin Turbo and AC? (SN95?) DarkMesa8 Turbochargers 4 06-24-2003 09:30 PM
