new member turbo question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 04-23-2010, 09:55 AM Thread Starter
mr99svtcobra's Avatar
hi guys new to the forum im looking to get a kit for my 99 svt cobra ive been lurking everywhere to see the right kit for my car .......i go to school and work only 3 days a week so its hard for me to get a kit at 6k ...soo i was looking at 0n3 performace kit for the 4v.....ive checked countless forums and every one is bashing this kit finally i found a forum that has members who actually used this kit and enjoy it.....
here is my question this kit will not work or mount with the stock k member on my 99 cobra? ...that part always has me lost some people say yea some say no
mr99svtcobra is offline
post #2 of 15 Old 04-23-2010, 09:58 AM
Erich's Avatar
As far as I know, every kit out there uses a tubular K. Some home builders have routed pipes under the stock K or cut holes in it. If it was not for the tubular K business, I would have built a turbo set up for my 97.
Erich
Erich is offline
post #3 of 15 Old 04-23-2010, 10:44 AM Thread Starter
so if i order a turbular k member it should bolt right up?
Granatelli turbular k member kit 94-01 cobra ????
post #4 of 15 Old 04-23-2010, 10:48 AM
nicecj7's Avatar
I dont have first hand knowledge but i dont think it will fit w/ the stock k-member i know its based around the QA1 kmember and i know some of the pipes route through it and there is no room w/ the stocker. I just purchased the kit and QA1 k-member and it would be awsome if it worked w/ the stock k-member but i dont see it happening w/ out alot of pipe modifications but its possible if you were a good welder and fabricator.
1999 Rio Red/ Black Cobra . Manley Pistons, Scat rods Arp hardware.... On 3 Performance Kit w/Master power 70mm Turbo, 03/04 cobra tank and pumps , 60lb injectors ,HPX Mass air, 4:30 gears 03/04 axles & diff & SCT tuned by EFI logics
nicecj7 is offline
post #5 of 15 Old 04-23-2010, 10:49 AM
nicecj7's Avatar
I purchased my Qa1 k-member, coilovers and arms from UPR it was the cheapest i found
By the way is your car 2 toned red/black its hard to tell from your pic
nicecj7 is offline
post #6 of 15 Old 04-23-2010, 11:58 AM Thread Starter
yes two tone red and black with a gold stripe down the center .....i would post pics but its says im trying to spam ...
qa1 k member kit are too expensive its like $1500?
post #7 of 15 Old 04-23-2010, 12:03 PM
Erich's Avatar
Ask whoever makes the kit what they recommend. You don't want to buy one and have it not work right with your set up.
ERich
Erich is offline
post #8 of 15 Old 04-23-2010, 12:06 PM Thread Starter
i guess ill call on3 performance ...does any1 on this forum have the 4v kit i would love to see the outcome .....thanks
post #9 of 15 Old 04-23-2010, 04:09 PM
nicecj7's Avatar
The On3 kit is based around a QA1 k-member check upr.. I just ordered the ON3 kit and QA1 k-member kit b/c this is what Chad ( Owner of On3) said to get.. Email him he knows his stuff..
nicecj7 is offline
post #10 of 15 Old 04-23-2010, 04:11 PM
nicecj7's Avatar
Upr sells QA1 stuff
http://www.uprproducts.com/mustang-q...er-kit-96.html
Red and black nice choice!! Its getting to be a popular color..Damn! Heres mine what part of New York are you from?
nicecj7 is offline
post #11 of 15 Old 04-23-2010, 05:08 PM Thread Starter
omg that is my car exactly ...holly ####!!!!!
except i have side scoop and different rims ceck out my avi or pic i cant post anything it says im trying to spam
wow 599 thats a nice price but i need to get a turbo kit first
whats your opinion on the on3 performance kits i hear the headers crack and stuff but thats on alot of boost i plan to run at most 9 to 10 psi
post #12 of 15 Old 04-24-2010, 02:49 PM
I've helped install and driven an on3 kit in a friend's 89 GT... If it's any indicator, this kit is great for the price. Tons of power, install wasn't bad.
Turbocharged 87 GT T Top
XBL Tag: Mikemachine812
MJs89GT is offline
post #13 of 15 Old 04-25-2010, 09:50 AM
nicecj7's Avatar
I will let you know when i get the kit ..It should ship out tuesday if my injectors come in .
nicecj7 is offline
post #14 of 15 Old 04-25-2010, 10:28 AM
Blk4V00GT's Avatar
The kit does deffinatly require a tubular front end with coil overs. The kit was designed around the QA1 so using that K will save you a lot of trouble with fitting everything. The headers cracking story is from a 5.0 kit when tthey first came out but that issue has been corrected, and the modular kits run stock manifolds so you don't need to worry about that. I will be ordering my 4v kit in about a week after a couple ppl on here finish up there builds. Good luck and I have heard nothing but good things from the people actually using the on3 kit at this point
Blk4V00GT is offline
post #15 of 15 Old 04-25-2010, 11:37 AM Thread Starter
yes ill deff order this kit..next week monday
New member with turbo dreams qwkturbo Turbochargers 5 02-16-2010 07:12 PM
What K-member with HP twin turbo set up? Eric93Cobra Turbochargers 4 02-04-2008 01:56 PM
turbo kit for member Newt-Rod Turbochargers 19 03-02-2007 09:13 PM
Stock K member to tubular K member question Todd Edge SVT & DOHC 14 03-05-2005 10:06 AM
Is there a turbo kit that uses the stock K member? scottinhawaii Turbochargers 23 08-20-2003 12:41 AM
