Turbo guys...come on in!!! Need some advice. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-21-2010, 07:21 PM Thread Starter
I need a few ideas on what route I need to go with fuel/pumps/MAF etc.
Car Specs:
2004 GT
Tremec 3650
Motor specs:
99 Teksid Block .20 over
03 Cobra Stock heads
99 Cobra front cover
Maximum Motorsports solid motor mounts
JE 17cc Pistons
Manley H Beam Rods
ARP main and Head Studs
Cometic Head Gaskets
Canton Oil Pan
New HV oil pump w/new Triangle Speed Billet Gears
Romac Aluminum SFI Balancer
Chicago head cooling mod
Billet Trigger wheel
So on to the questions...
I plan on running a 76mm turbo and don't know what to do with fuel injectors, fuel pump and MAF sensor.
I'm going to be over 650 rwhp and need the fuel to support it.
Keep in mind that I'm currently running the factory GT tank & pump/fuel lines(returnless) and the stock MAF.
So let me know what I need to get.
Thanks,
Daniel
2004 Mustang GT (Built 4v and turbo coming soon)
DanielP is offline
post #2 of 11 Old 04-21-2010, 09:30 PM
2002mustanggt's Avatar
You will need 03-04 cobra with gt supercar pumps and bap, as for injector 60lb min to 80lb , returnless is giving me too much problem so I will say go return style. Maf I got Pmas blow thru.
2002mustanggt is offline
post #3 of 11 Old 04-21-2010, 10:10 PM Thread Starter
What problems are you having with the returnless set-up?
DanielP is offline
post #4 of 11 Old 04-21-2010, 10:20 PM
Fuel spike after shift, going for dyno tomorrow to fix that and get 21 psi dyno #
post #5 of 11 Old 04-22-2010, 12:00 AM
Gearhead559's Avatar
we was having the same issue with the white car we just did. my tuner got it figured out tho.
Gearhead559 is offline
post #6 of 11 Old 04-22-2010, 12:18 AM
cool!! I hate it when I shift I have no power for 2-3 second then it hit hard, hope mine get's fix tomorrow.
post #7 of 11 Old 04-22-2010, 12:23 AM
04Ryan's Avatar
At this point I'd also suggest return style...either sump your GT tank or buy a Glenns Performance sleeper tank. Or you could run a Fore hat with internal Walbro pumps...either way you will need feed and return lines. A external regulator and depending on where you wanna go with the power. 80lb injectors sounds like what you need...although I'm at 672rwhp with my 60lb injectors. I'd recommend the HPX slot style MAF...mine has plenty of room left in it even at my hp level.
On a side note...is this a drag car? If not why the solid motor mounts?
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #8 of 11 Old 04-22-2010, 09:51 AM
I will be in the 600-650 range and I'm doing a fore hat, duel pumps, either 72 or 80 lb injectors, lines, fore rails, all return. It will be a little overkill, but I will have room to go.....
I came, I saw, I gave her a towel......
bigd3077 is offline
post #9 of 11 Old 04-22-2010, 04:13 PM Thread Starter
What car can I get these parts from? 03/04 Cobras? What exactly is a fore hat and fore rails?
DanielP is offline
post #10 of 11 Old 04-22-2010, 05:09 PM
To run 2 or 3 pumps you need 03-04 cobra fuel tank.
http://www.foreprecisionworks.com/SN...eturnless.html
http://www.foreprecisionworks.com/cobra-fuel-rails.html
Very nice stuff .
post #11 of 11 Old 04-22-2010, 05:29 PM
Blk4V00GT's Avatar
Fore is very high quality but kinda expensive lol deff worth it tho
Blk4V00GT is offline
PRO Turbo Guys need so advice ? GoneBrokeRacing Turbochargers 8 10-08-2003 02:38 PM
Trick Flow guys need advice? Also need advice on UDP's alienninja 94/95 Tech 4 06-28-2003 10:30 AM
