92 On3 Turbo Build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 215 Old 04-21-2010, 02:23 PM Thread Starter
Trader Feedback: (55)
92 On3 Turbo Build
I lifted a headgasket on my last visit to the track on my Procharged 92.
Since I had to tear it down to replace the headgaskets I decided to completely change directions and switch to turbo and a 331 stroker.
Here's the build list:
Eagle 331 stroker kit
Trick Flow Fast as Cast 190 heads
Trick Flow 1.6 rr and 6.7 pushrods
FCam
On3 Turbo kit with upgraded Master Power 70 Turbo
92 Hatch On3 Turbo, T56
92 Vert 349 Lunati Stroker T5
87 Gt Eddy HCI T5
87 Notch in progress
fmyth is offline
post #2 of 215 Old 04-21-2010, 02:24 PM Thread Starter
87 Gt Eddy HCI T5
fmyth is offline
post #3 of 215 Old 04-21-2010, 02:27 PM Thread Starter
Here's the pile from UPS
87 Gt Eddy HCI T5
fmyth is offline
post #4 of 215 Old 04-21-2010, 02:28 PM Thread Starter
Here's the before pic with the Procharger
87 Gt Eddy HCI T5
fmyth is offline
post #5 of 215 Old 04-21-2010, 02:29 PM Thread Starter
The tear down
87 Gt Eddy HCI T5
fmyth is offline
post #6 of 215 Old 04-21-2010, 02:29 PM Thread Starter
87 Gt Eddy HCI T5
fmyth is offline
post #7 of 215 Old 04-21-2010, 02:33 PM Thread Starter
Down to the shortblock. Discovered considerable wear on the cylinder walls. Decided to yank the shortblock and install a 331 stroker I had saved for the future.
87 Gt Eddy HCI T5
fmyth is offline
post #8 of 215 Old 04-21-2010, 02:35 PM Thread Starter
Installed the new 331 with the heads/cam. Then bolted on the hotside. Only took a couple hours to bolt on the hotside with my son helping. Everything fit with no modifications.
87 Gt Eddy HCI T5
fmyth is offline
post #9 of 215 Old 04-21-2010, 02:36 PM Thread Starter
Here's a better view of the cross over w flex joint:
87 Gt Eddy HCI T5
fmyth is offline
post #10 of 215 Old 04-21-2010, 02:39 PM Thread Starter
The On3 Instructions are pretty vague about the installation of the alternator brackets. I searched the forums here and found a couple pictures. After looking at the pics it only took a few minutes to install. After I installed the alternator I installed my Ford Racing AC delete kit. The aleternator relocation bolt that goes through the drivers side of the heim joint wouldnt fit with the ac delete bracket. All I had to do was use the factory bolt water pump bolt, ditch the On3 spacer and use a nut before and after the heim joint.
87 Gt Eddy HCI T5
fmyth is offline
post #11 of 215 Old 04-21-2010, 02:45 PM Thread Starter
So we started to install the cold side. The instructions were a little vague and some pictures of the routing of the pipes would be really helpful. Once again I searched the forums to find pics that other members had posted of their builds. Without the forum I probably would still be in the garage trying to figure the cold side out. Here is a pic of the intercooler while test fitting it. Notice the customized brackets are not attached to the radiator support.
87 Gt Eddy HCI T5
fmyth is offline
post #12 of 215 Old 04-21-2010, 02:45 PM Thread Starter
Here's a shot from the drivers side:
87 Gt Eddy HCI T5
fmyth is offline
post #13 of 215 Old 04-21-2010, 02:46 PM Thread Starter
And one from the passenger side:
87 Gt Eddy HCI T5
fmyth is offline
post #14 of 215 Old 04-21-2010, 02:49 PM Thread Starter
I decided to use my PMAS pro tube maf left over from my Procharger set up. This means I have to cut 6"s from the end of the tube that exits the intercooler on the passenger side. This will locate the MAF 9" from the bend and inside the fender where it can be accessed through the factory airbox hole. The tubing is high quality stuff and my homedepot hacksaw barely scratched it. My son is out driving around looking for a muffler shop to cut it for me now.
87 Gt Eddy HCI T5
fmyth is offline
post #15 of 215 Old 04-21-2010, 03:03 PM
conbread's Avatar
Trader Feedback: (60)
looks good... glad everything has fit good..
conbread is offline
post #16 of 215 Old 04-21-2010, 09:44 PM
90fiveoh's Avatar
Sweet, another 5.0L build. I was scratching my head for a little while on that Alternator relocation kit as well, the directions arent right in the manual. Apparently my kit was missing a spacer too, so I ended up just using the factory bolt for the tensioner on the water pump, with a nut.
90 Turbo GT
90fiveoh is offline
post #17 of 215 Old 04-21-2010, 10:16 PM Thread Starter
Anyone with an On3 kit think my intercooler is in the right place? I am worried that I might have it mounted too high.
87 Gt Eddy HCI T5
fmyth is offline
post #18 of 215 Old 04-21-2010, 10:57 PM
conbread's Avatar
does that alt bracket have a big bolt to the head, so it doesnt flex???
conbread is offline
post #19 of 215 Old 04-21-2010, 11:38 PM
90fiveoh's Avatar
yes
90 Turbo GT
90fiveoh is offline
post #20 of 215 Old 04-21-2010, 11:40 PM
Radrick50's Avatar
We have a Pony Down kit, but it basically uses the same type of intercooler and piping...As long as your IC is even with the bottom of the radiator support or slightly above you should be fine with your nose fitting back on with minimal or no cutting for clearance.
Looks like a real nice setup...should run real nice!!!
Radrick50 is offline
post #21 of 215 Old 04-22-2010, 02:04 AM Thread Starter
Tried to fit the bumper cover on and had to either cut away at the headlight support or lower the IC and push it back toward the radiator. Since this is not a daily driver I removed the AC and the condensor brackets which allowed me to move the IC back and down. Now the bumper cover will fit without trimming the headlight support. The bottom of the bumper cover was already hacked up to fit the procharger IC. I will replace the bumper cover soon and want to intstall it without hacking it up.
87 Gt Eddy HCI T5
fmyth is offline
post #22 of 215 Old 04-22-2010, 02:08 AM Thread Starter
This is the IC after I moved it down 1/2 inch and back 1 1/2 inches.
87 Gt Eddy HCI T5
fmyth is offline
post #23 of 215 Old 04-22-2010, 02:09 AM Thread Starter
Here is a view from the bottom. With the bumper cover on it it is barely visable.
87 Gt Eddy HCI T5
fmyth is offline
post #24 of 215 Old 04-22-2010, 02:12 AM Thread Starter
I had to cut the tube leading from the IC to the intake and install the MAF. The silcone coupler hit the fender brace so I had to "clearance" it a bit.
87 Gt Eddy HCI T5
fmyth is offline
post #25 of 215 Old 04-22-2010, 02:14 AM Thread Starter
I am going to have to enlarge this hole for the intake tubing to fit correctly. This will have to wait til Monday. We are loading up the ATV's to head to Glamis for a little mancation. More pics next week.
87 Gt Eddy HCI T5
fmyth is offline
post #26 of 215 Old 04-22-2010, 02:16 AM Thread Starter
Lower intake finally installed after 2 trips to the machine shop to have it milled down. Damn Edelbrock Victor had to be milled .185 on the mating surfaces and .100 on the ends to get the ports to match up with the Trick Flow 190 FAC heads. Another $120 but who is counting?
87 Gt Eddy HCI T5
fmyth is offline
post #27 of 215 Old 04-23-2010, 10:32 AM
conbread's Avatar
it seems like everyone running the victor 5.0 has to cut it.... i just got rid of one that the rails were cut to fit!! looking good man..
conbread is offline
post #28 of 215 Old 04-23-2010, 11:36 AM
MY 93 GT's Avatar
Looking Awesome!!!! Cant wait to get mine..Please keep us posted..I want to know how the turbo sounds ....And the blow off...Also anything you find that might help other people like me...LOL...thats getting ready to bolt on a turbo...Also can you get some videos when your done?....
Turbo installed!!!!
MY 93 GT is offline
post #29 of 215 Old 04-23-2010, 12:04 PM
mr99svtcobra's Avatar
wow sick build cant wait to see some numbers
mr99svtcobra is offline
post #30 of 215 Old 04-23-2010, 01:20 PM
TimP's Avatar
Trader Feedback: (89)
subscribing... I'm so close to pulling the trigger on this kit, but it's spring, and my car actually RUNS for once. LOL
edit: P.S. great write up, thanks for the pics, and honest eval.
Electric Currant Red 93 LX Hatch: July 98 MM&FF Feature Car, 9.39 @ 144.
Dark Grey Metallic 87 LX Notch: gears, exhaust, shift kit.
TimP is offline
post #31 of 215 Old 04-23-2010, 01:35 PM
Sweet!
I have a similar setup / On3 Kit.. I have a build thread as well.
Going to get tuned next week. Ill update my thread then.
Cool build.
Die-Laughing is offline
post #32 of 215 Old 04-23-2010, 02:38 PM
MY 93 GT's Avatar
Im 100% getting the on3 kit cant wait.!!!!!..can any of you guys get some sound clips up when your done...I would love to hear the sound of the turbo and blow off...LOL....
Turbo installed!!!!
MY 93 GT is offline
post #33 of 215 Old 04-23-2010, 06:39 PM Thread Starter
No problem. I hope it have it complete by Thursday and then take it to the tuner. I will be out of town til the 7th but hope to have it out at Firebird for test and tune on the 7th. If we make it there I will get some videos. They should be entertaining as it's a 6 spd. From what I hear turbos and manuals don't mix too well....
87 Gt Eddy HCI T5
fmyth is offline
post #34 of 215 Old 04-23-2010, 10:33 PM
A big hint for you... Build a brace for the turbo to put less stress on the manifold so it won't crack/break any of the welds... That's why most people have problems with the on3 kits I'm building a brace for mine
93coupee is offline
post #35 of 215 Old 04-24-2010, 12:01 AM
MY 93 GT's Avatar
Nice hint do you have pictures?...so I can see how your bracing it?
Turbo installed!!!!
MY 93 GT is offline
Tags
bad ass
My On3 3v Turbo Build Thread Lowvez Turbochargers 129 08-05-2013 02:18 PM
A 5.0L On3 Turbo build 90fiveoh Turbochargers 53 11-10-2011 01:35 PM
my on3 turbo build up jaxboostedGT Turbochargers 205 08-13-2010 10:42 PM
For Sale 70mm on3 turbo turbocar Power Adders 0 04-20-2010 07:42 AM
my 93 vert turbo project, on3 turbo kit ahurl90 Turbochargers 47 07-01-2009 10:09 AM
