White smoke...but only for a few seconds when stopped at a light? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 04-21-2010, 11:58 AM Thread Starter
CaliNotch n MI's Avatar
Trader Feedback: (15)
I getting some white smoke out of the exhaust, let me paint the picture:
Everything seems to run fine BUT when I'm cruising through town and pull up to a stop light (or after pulling into a parking spot) about a second after the car comes to a complete stop I get about 3 seconds of smoke from the exhaust then it goes away.... overall the car smells on the rich side, could this just be a lean condition at idle??
1993 Notch: Mexican 347 Hellion TFS heads/GT40 intake/Custom Cam Tremec 3550
1992 GT Convert: Green/Blk interior, 10th anniversary cobra's mostly suspension mods.
FB users please, PLEASE click "like" button. Thanks!!
CaliNotch n MI is offline
post #2 of 13 Old 04-21-2010, 01:04 PM
MY 93 GT's Avatar
Could be valve steam seals going bad ...OR valve guides starting to wear....
Turbo installed!!!!
MY 93 GT is offline
post #3 of 13 Old 04-22-2010, 07:25 AM
my buddy's g/n did that and it was the turbo seals
RIPPED OFF BY stroked_snake <---dead beat alert
sc13mw is offline
post #4 of 13 Old 06-06-2010, 12:44 PM Thread Starter
I pulled of my turbo pipe expecting to see oil and it was dry as a bone...
post #5 of 13 Old 06-07-2010, 09:28 AM
Feel free to call me and I will help you figure out what is going on.
231-830-5102
231-830-5102
post #6 of 13 Old 06-11-2010, 06:42 AM
R1ERIC's Avatar
Sent u pm
R1ERIC is offline
post #7 of 13 Old 06-11-2010, 12:31 PM
Steed93's Avatar
I had the same problem a few years ago. Turned out to be a bad piston ring seal on the prior engine rebuild.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #8 of 13 Old 06-11-2010, 01:28 PM Thread Starter
231-830-5102
I'm pretty busy during the week with work/classes are weekends cool??
Originally Posted by R1ERIC View Post
Sent u pm
Thanks.
I think I ruled out being a turbo seal. So I started to think about what changes I made around the time the smoke started and the only thing I did was change my cat-back system from a plain 2.5" flow-master system to a 2.5" mac kit with 3" tips and messed a bit with some breather lines.
post #9 of 13 Old 06-11-2010, 01:38 PM
UJUSTLOST's Avatar
Oil smoke usually has a blue hue to it and a distinct burnt oil smell. Are you sure its oil smoke? White smoke is usually from water, steam discharge. It could be caused by sucking coolant past a leaking head gasket, burning it, and sending it out the exhaust. Just throwing out some other options. Check your coolant for oil in it or coolant in your oil. Perhaps pressure test the coolant system. Good luck with it.
UJUSTLOST is offline
post #10 of 13 Old 06-11-2010, 02:36 PM Thread Starter
I checked the coolant, it looks good and I don't seem to be loosing any.
Any it does have a gas/rich/oil smell..lol
post #11 of 13 Old 06-11-2010, 02:37 PM Thread Starter
If that's the case, I guess it might be 347 Mexican block time...
post #12 of 13 Old 06-12-2010, 05:03 PM
I am always around and if I see a missed call I dial it back. Check your crank case pressure. remove the breather and put your finger over the hole. Does it pull vacum or is there pressure coming out?
Thanks.
231-830-5102
post #13 of 13 Old 06-25-2010, 05:12 PM Thread Starter
I think I've found my smoke, Raw fuel due to a bad regulator?
https://forums.corral.net/forums/show....php?t=1232757
Post #6
Traction Control Light just stopped working mrbeaubo GT & SOHC 0 03-06-2007 06:04 PM
White Smoke vinny89GT 94/95 Tech 17 12-19-2005 11:53 AM
White smoke and low coolant light=trouble? Mysticobra96 SVT & DOHC 16 11-04-2004 06:57 PM
Shift light stopped working - help! Black89Notch GT & SOHC 0 06-02-2002 10:42 AM
check engine light on 98 cobra,stalling out and speedo stopped working.Help!!!!!!! billywallstreet73 GT & SOHC 5 03-27-2002 10:51 PM
