E303 cam & turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 43 Old 04-21-2010, 01:31 AM Thread Starter
E303 cam & turbo
im building a 351w with trick flow heads ported. holley systemax intake with a turbonetics 78mm i know the E 303 cam is good for a turbo set up but im wondering what kind of power it will make.im going to habe 3 tunes on the car.street 550 625 and final tune with race gas 700+ just wondering if anyone know what kind of power that cam will make or if its to small....i know some people use the stock cam so i know the E303 cam cant be to bad.
st pete chad is offline
post #2 of 43 Old 04-21-2010, 10:42 AM
lechols155's Avatar
i not sure how good the e cam will do in your 351.
might cost a little more but the best thing to do is call up comp cams and tell them exactly what you have and what you want to make and they will give you the best cam for your car.
92 gt
Old setup: 100% stock w/ turbo 10.80 @ 126
lechols155 is offline
post #3 of 43 Old 04-21-2010, 10:56 AM
Re: E303 cam & turbo
I too say go custom in this situation. It is not the E will be horrible, it is just that it works so well with less cubes.
post #4 of 43 Old 04-21-2010, 02:27 PM
your going to spend all that money on a 351 and a turbo kit and not run a custom cam?
TWIN TURBO!! Because bottles are for babies and superchargers blow
megasquirt, 331, twin 66s, ported 205cc head, efi spyder intake, 160# injectors, e85
luckythirteen13 is offline
post #5 of 43 Old 04-21-2010, 03:56 PM Thread Starter
i never said i was not going to buy a cam.im just asking i know a few people have have used the stock cam and made 600 so i figured i would ask around.i might buy anderson motorsport turbo cam i have heard alot of good things about the cams
post #6 of 43 Old 04-21-2010, 09:14 PM
ratedz's Avatar
I wouldn't run a custom cam unless I had a Dart/Boss/WP block. Just pick up a used F cam and call it a day.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #7 of 43 Old 04-21-2010, 10:04 PM
Alex in Houston's Avatar
Thumbs up
Co-Sign
Mr. M. M. Alexander
Originally Posted by Stopsign32v View Post
Stop crying, its just the internet. Life gets alot harder than some screen name on a message board not liking what you do to your car.
Alex in Houston is offline
post #8 of 43 Old 04-22-2010, 12:51 AM Thread Starter
wll the f cam be much better then the E303 cam?
post #9 of 43 Old 04-22-2010, 03:27 AM
goatnipples2002's Avatar
Trader Feedback: (22)
F cam is the better choice when you consider price, performance, sound and feedback. I run 1 too.
goatnipples2002 is offline
post #10 of 43 Old 04-22-2010, 06:52 AM
The F cam is the cam from FMS for boosted applications. I am not sure why the E cam seems to keep coming up as the one to get because if buying a letter cam for a boosted car then it should be a no brainer to go with the F. But you are talking about running one in a engine with ~50 more cubes so it becomes far from the optimal cam. Sure they will make power, heck people with 302s and B cams make good power numbers even though it is far from optimal for that application.
post #11 of 43 Old 04-22-2010, 11:51 AM
lechols155's Avatar
the biggest question is what do you want the car for. is it a street car that you want to see how much hp it makes on the dyno. or is it a race car that you plan on taking to the track and going fast.
92 gt
post #12 of 43 Old 04-22-2010, 11:59 AM
I think the stated HP goals in the first post give a decent idea of what the car will be used for. No one else has asked this but is this 351 block even one that will work with a hydraulic roller cam without special lifters?
post #13 of 43 Old 04-23-2010, 01:17 PM Thread Starter
yes it is.its F4TE block which is a roller block.its not going to see alot of track time just because i hate the track.lol but it will be something that i want to make [email protected] the wheels with race gas.so like i said before 550 street tune then 2nd tune around 625 or so and 3rd tune race gas around 700.
post #14 of 43 Old 04-23-2010, 02:30 PM
If you already have the E and want to save some money then go for it. But in the grand scheme of things you are talking what a $200 savings? Personally I'd rather have something spec'd for boost and for my combo in general.
post #15 of 43 Old 04-23-2010, 02:39 PM
ANY cam will "work" with a turbo, but what cam works best is another thing.
post #16 of 43 Old 04-25-2010, 02:21 PM
lechols155's Avatar
if you just want hp on the dyno then use what ever cam you have and turn up the boost. then set it at 8 to 10psi for you normal tune
92 gt
post #17 of 43 Old 04-25-2010, 07:42 PM
pkstang's Avatar
Trader Feedback: (161)
didn't know that they make a holley systemax intake for a 351W?
pkstang is offline
post #18 of 43 Old 04-25-2010, 08:33 PM
If they don't then could he not use the upper from one and bolt it onto a ford truck lower?
post #19 of 43 Old 04-25-2010, 08:37 PM
pkstang's Avatar
nope because the 5.8 truck is more like the 5.0 car setup and not the 5.0 truck which is like the holley/saleen setup
pkstang is offline
post #20 of 43 Old 04-26-2010, 04:55 PM Thread Starter
they dont make a lower for the holley systemax
post #21 of 43 Old 04-26-2010, 04:56 PM Thread Starter
nope the ford truck 302 lower is like the systemax but the lower will not work on a 351w
post #22 of 43 Old 04-26-2010, 04:57 PM Thread Starter
the lower from a 351w is like a stock mustang ports.but it can be used with a holley upper some bolt pattern.so yea you can use a 351w truck lower
post #23 of 43 Old 04-26-2010, 07:35 PM
pkstang's Avatar
the ports are still totally different shape...
pkstang is offline
post #24 of 43 Old 04-27-2010, 02:22 PM
intake adapter
http://www.pricemotorsport.com/html/..._adapters.html
lonnie1952 is offline
post #25 of 43 Old 04-27-2010, 02:36 PM
pkstang's Avatar
Originally Posted by lonnie1952 View Post
http://www.pricemotorsport.com/html/...e_adapter.html
pkstang is offline
post #26 of 43 Old 04-27-2010, 02:38 PM
pkstang's Avatar
you might wanna start thinking of a different intake as $300+ for the adapters is lot as he can sell his existing intake and buy something like the victor 5.8
pkstang is offline
post #27 of 43 Old 04-27-2010, 03:22 PM Thread Starter
haha i dont need that spacer kit to make the holley systemax work on a 351w
post #28 of 43 Old 04-27-2010, 03:30 PM
pkstang's Avatar
pkstang is offline
post #29 of 43 Old 04-27-2010, 03:33 PM
Donovan's Avatar
I would worry about matching your cam to your valve springs before anything. Seat pressure and open pressure should be matched so that you dont end up having top end problems down the road.
The E303 will work, but you are leaving power on the table especially is you are not concerned with smog testing or making a low rpm motor. You can run 1.7 RRs to get more lift, but really that cam is a pretty mild cam and isn't even a dual pattern grind so you could probably match up a better cam for your setup. 498" lift is not much at all IMHO. Here are the full specs:
http://www.fordracingparts.com/download/charts/85.pdf
I actually switched from a E303 to a Stage 2 TFS cam which has a grind that is designed specifically for our heads. Without a doubt a much better cam for the TFS heads especially with added displacement. I cannot remember which Comp springs that I used but I got the springs perfect with some shims and this thing has next to no valve train noise! Just sounds like a motor should. It was worth all the time and effort to get it dialed in.
94 GT Vert - R347 - B&G w/PT76GTS - T56M - AEM w/LS2 Coils - 575/601tq @ 10Psi
Donovan is offline
post #30 of 43 Old 04-27-2010, 05:10 PM Thread Starter
look at the truck 5.8 lower and the holley lower and let me know if you figure it out
post #31 of 43 Old 04-27-2010, 05:12 PM Thread Starter
my springs are good for a 600 lift.im thinking about a anderson b41 HR cam.well i think thats the part # they gave me
post #32 of 43 Old 04-27-2010, 05:17 PM
PowerAdder Solutions's Avatar
Trader Feedback: (230)
Yeah, the F Cam is perfered but, I bet you the E or F will both actually do well compared ..I have seen both scenario on the dyno.. For your setup I would go custom..
http://www.bennettracing.com/
http://www.flowtechinduction.com/
post #33 of 43 Old 04-28-2010, 03:04 PM Thread Starter
i know they are not the same shape.does not mean you cant port them to the same shape.someone tell me how to post pics and ill show you that you can use the systemax on a 351w with a truck lower
post #34 of 43 Old 04-28-2010, 04:45 PM
pkstang's Avatar
you need a better intake as that truck lower has no business on a 351W with a 78mm shootimg for that type of power. you can fit 315s on a 8" wheel doesn't mean its the thing to do. pk
pkstang is offline
post #35 of 43 Old 04-28-2010, 09:07 PM Thread Starter
bro you have no clue what the ports are like.the ports are bigger then the port on a trick flow R intake
e303 cam on turbo stang vbstng Turbochargers 14 07-16-2008 08:49 PM
FS/FT E303 CAM & 1IN EDELBROCK PERFORMER RPM SPACER jhoward5.0 Windsor Engine Parts 22 03-28-2008 06:48 AM
E303 cam & Ported E7's SilverFoxbody Windsor Engine Parts 9 10-19-2006 10:48 PM
FS E303 cam & stuff stangersteve Windsor Engine Parts 10 05-01-2006 02:28 PM
5.0 5.8 roller conversion parts & e303 cam customfoam Windsor Engine Parts 0 05-27-2005 10:54 PM
