Fox lx intercooler help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 04-15-2010, 12:01 AM Thread Starter
I have been on here lurking looking and finding nothing on this.
I have a 1993 lx coupe with AC.... I am about finished up with the installation of a BG turbo kit and have run into a bit of a snag with the mounting of the intercooler. Brian of BG recommended tilting out the top of the intercooler into the bumper itself so that I could get a bit more room to play with, and that has seemed to help quite a bit. However, I am trying not to trim the bumper cover as I am trying to keep this car looking like a somewhat stock 66000 mile lx coupe.
Any photos or insight would be very much appreciated at this point. I have been mounting and remounting the damn intercooler and the front bumper for the last two nights and want to get this damn thing finished up!!!
Thanks in advance,
Sean
hackster is offline
post #2 of 29 Old 04-15-2010, 12:15 AM
I felt this way also on my 28000 mile coupe but to I face the facts that intercooler is huge and the bumper is not! I did exactly what bryan said too and it did help but trimming is necesary! I used blue masking tape with a dremel tool and cutoff wheel and it worked great!
mr_hahn73 is offline
post #3 of 29 Old 04-15-2010, 03:53 PM Thread Starter
Any chance that you have any final photos of the front of your car after the intercooler install?
Thanks for the kind words......
hackster is offline
post #4 of 29 Old 04-15-2010, 03:54 PM Thread Starter
I couldnt help but notice that you are in Oregon......where about are you located?
Sean
hackster is offline
post #5 of 29 Old 04-15-2010, 04:33 PM
Rich G's Avatar
Trader Feedback: (35)
Every LX I have every see always looked pretty chopped up, if looks are of key concern and you dont wanna cut up your bumper cover than maybe get a smaller intercooler.
Rich G is offline
post #6 of 29 Old 04-15-2010, 04:48 PM Thread Starter
That is exactly what I am thinking about doing.
I am running a stock motor other than the turbo and fuel. I am thinking that a much smaller intercooler will be fine for my 500 hp goal.
I agree, there is not a whole lot on the bottom of the front bumper and when it is cut up it can look pretty poorly performed.
Sean
hackster is offline
post #7 of 29 Old 04-15-2010, 07:05 PM
♥ wendy ♥'s Avatar
I cut our 91 coupe to make ome fit and i couldn't stand it. I would run meth before i cut another bumper. I ended up with a A/W cooler in the left front fender, no cutting.
john
We also mad over 570whp with no intercooler at all.
1991 lx turbo notch
♥ wendy ♥ is offline
post #8 of 29 Old 04-15-2010, 07:53 PM
MY 93 GT's Avatar
Is a intercooler really needed for a street car looking to make around 400 rwhp with a stock short block,GT40 heads and 42lb injectors and a 255lph pump?..Also does B&G offer a kit without an intercooler?..Also i always see turbo's with intercoolers if you dont run one how is it then piped??
Turbo installed!!!!
MY 93 GT is offline
post #9 of 29 Old 04-15-2010, 08:10 PM
You can get away without an intercooler but you typically make a lot more power with one. You would just run a pipe directly from the turbo to the intake if you chose not to run one.
I think you may have more trouble with detonation without it though.
Turbocharged 87 GT T Top
XBL Tag: Mikemachine812
MJs89GT is offline
post #10 of 29 Old 04-15-2010, 09:07 PM
♥ wendy ♥'s Avatar
We removed the intercooler because the car ran too hot with it, air flow to the radiator was a problem, we also had working a/c and live in Florida. You do have to change your tune for it. Plus on the street heat soak is a problem with a/a coolers. That's when a meth kit would be the best of both. Unless you want to...
john
1991 lx turbo notch
post #11 of 29 Old 04-16-2010, 07:41 AM
We had to trim ours but I didnt hack it all up if you don't know Mustangs you really would not know it was done.
Turbo 306,How fast will it go that depends on who is around.. Local parts pimp.. Things for sale most stuff is OBO https://docs.google.com/document/d/1hvqaA8aKICIw6BBj3IU2KCwiv86TtWXmxmvrsd8lw1A/edit?hl=en_US&pli=1#
wvstangdriver is offline
post #12 of 29 Old 04-16-2010, 07:47 AM
cant get pics. to post
post #13 of 29 Old 04-16-2010, 08:50 AM
Erich's Avatar
I cut out the little "teeth" things that hold the LX bumper opening together. Then I screwed the top part of the opening into the bumper and then drilled a few small holes in the inside part of the bottom and zip tied the inside edges together. This created a bigger mouth for the intercooler and made more space. Came out looking nice.
Erich
Erich is offline
post #14 of 29 Old 04-16-2010, 09:00 AM
Erich's Avatar
Here is a pic.
Erich
Erich is offline
post #15 of 29 Old 04-16-2010, 10:17 AM Thread Starter
Thanks for all the input!!! It is great to hear I am not the only one with this problem. I really would like to stay air to air. This is a street car, that I will commute with on nice days and maybe run down the track a couple of time s a year. The car is very understated and showing a giant intercooler is just not in the cards for me. I am trying to keep the engine compartment as original as I can without cutting or modifying too much. I want people to look in there and other than the turbo, not be able to tell the difference if they dont know what they are looking for.
Erich, thanks for the pics!!! I like your idea and the bumper itself looks good, not all hacked up lie a lot of them I have seen. One question though, is your intercooler offset to the driver side?
I picked up the evo intercooler last night and mocked it up in there. The end caps tilt in where the piping hooks up just enough that I think it is going to be much less cutting. The core is almost the exact same size as the one that I got with the kit, its just a bit narrower and much much nicer!!
Ill post some pics if I ever get the damn thing put together =)
Thanks again
hackster is offline
post #16 of 29 Old 04-16-2010, 10:28 AM
MY 93 GT's Avatar
Dumb Question...does the GT have the same problem or just the LX's
Turbo installed!!!!
MY 93 GT is offline
post #17 of 29 Old 04-16-2010, 10:31 AM
Rich G's Avatar
no
Rich G is offline
post #18 of 29 Old 04-17-2010, 08:22 AM
Erich's Avatar
It is offset to the drivers side. I think that is to allow for outlet onthe top to have a little more room. This IC is two in from the bottom, one out from the top passenger side. Made by HP in New Mexico.
Erich
Erich is offline
post #19 of 29 Old 03-23-2012, 12:15 PM
Erich, can you give details about your A/A intercooler? core dimensions and inlet/outlet tube size? power/airflow rating?
jkost is offline
post #20 of 29 Old 03-24-2012, 02:02 AM
nasty92lx's Avatar
I cut my bumper cover then cut it some more. I don't mind though, I think it looks awesome.
nasty92lx is offline
post #21 of 29 Old 03-26-2012, 08:28 AM
Lmao I want it to be stock looking and not cut up the bumper don't put the turbo kit on then... Keep the ic work around it
SKooBY is offline
post #22 of 29 Old 03-26-2012, 04:46 PM
Trader Feedback: (25)
are u guys running into problems because the core is too thick or because the intercooler is too large overall? i was planning on running a 4 inch core behind my lx bumper. Is that a pipe dream, even with an aftermarket bumper support?
2slow93gt is offline
post #23 of 29 Old 03-26-2012, 06:43 PM
john
DETAILS on the a/w please!
nyctony is offline
post #24 of 29 Old 03-26-2012, 06:47 PM
MY 93 GT's Avatar
^^^^^^^ That looks cool what kit is that your running?...
Turbo installed!!!!
MY 93 GT is offline
post #25 of 29 Old 03-26-2012, 07:03 PM
B&G custom turbo kit.... I always hate saying custom cuz it isn't but whatever
Sent from my EVO 4G 3D...sluts!
nyctony is offline
post #26 of 29 Old 03-26-2012, 07:40 PM
MY 93 GT's Avatar
Very nice!!! What are the mods?...whats it run? My Turbo build is in progress as we speak...
Turbo installed!!!!
MY 93 GT is offline
post #27 of 29 Old 03-26-2012, 08:07 PM
BG kit with Mp t70 and precision 44mm wg
FYI (Ed Curtis) ported, tw heads valve work blah blah blah the works.
FTI Fully ported Victor efi 5.0
FTI Custom big na cam (what a mistake)
Stock block
Hanlon built tko 600
Team z uppers lowers anti roll
Strange coilovers on all 4 corners
Mm plates
Reinforced torque boxes
Some old subframes
8lbs for now. Will let you know times after April 21st.
Might go auto soon.
nyctony is offline
post #28 of 29 Old 03-26-2012, 09:07 PM
Trader Feedback: (41)
I am running a 24x12x4.5 intercooler core (not including end tanks) on my lx with Saleen body kit.. I am only running the front after market bumper bar. No problem.
stangjumper is offline
post #29 of 29 Old 03-26-2012, 09:09 PM
MY 93 GT's Avatar
Stock block
Mm plates
Some old subframes
Might go auto soon.
Nice cant wait to see some times!!!! Good luck
Turbo installed!!!!
MY 93 GT is offline
D1 WITH INTERCOOLER FOR FOX BODY 85bigtireranger Power Adders 7 06-16-2008 12:24 AM
procharger 600b with intercooler for fox roofer Power Adders 4 08-24-2007 05:07 PM
FS:Fox Body Intercooler KKKKatmandu Power Adders 14 10-08-2006 09:07 PM
FS: Fox Body Intercooler KKKKatmandu Power Adders 7 10-05-2006 03:41 AM
Intercooler Kit for FOX DFWStangs-Turbostang Power Adders 2 09-19-2005 12:44 PM
