turbo combo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-14-2010, 10:01 AM Thread Starter
turbo combo?
Does this look like a combo I could make 800 plus hp with
89 Coupe
393 shp dart block
205 AFR heads
custom cam
trick flow R box intake
T-56 Transmission
76mm Garrett turbo from hp performance
Upr K member kit
No A/C
Not sure what gears i want to do yet
And do you think the Turbo will hold me back or would i be putting to much on it?
89COUPE/ 93HATCH
t.wells is offline
post #2 of 8 Old 04-14-2010, 10:45 AM
Yes, you will be going pass the choke line on T-76 = not good
80-88mm would be much better. maybe a Precision GTS78
or twin 62-1's
r.barn is offline
post #3 of 8 Old 04-14-2010, 02:27 PM
You could make 800hp with that combo. But I would agree with going to a bigger turbo. Id go with an 88 if I had your setup. The 76mm would begin to hold you back if you want more power.
Originally Posted by JSZ03 View Post
pretty interesting...although I knew a guy whose son chewed through the backseat of his new Chevy Blazer on a vacation once....the guy asked the kid why, and the kid said he was just bored....
pete85fox is offline
post #4 of 8 Old 04-14-2010, 10:29 PM
king cobra 2003's Avatar
subscribing
king cobra 2003 is offline
post #5 of 8 Old 04-15-2010, 08:42 AM Thread Starter
Thanks for the help guys, im going to try and sell the 76 and buy a 88
89COUPE/ 93HATCH
t.wells is offline
post #6 of 8 Old 04-15-2010, 09:48 AM
T-88 plots out perfect. Lots of room to crank up the boost too.
GT-4508 would be a good turbo as well or a Borg Warner S488
r.barn is offline
post #7 of 8 Old 04-25-2010, 10:17 PM
Could some please explain to me why his 76mm turbo will hold him back ??
a turbnetics 76mm is good for 800 HP and that is all he is asking for
Please help me learn
1952
lonnie1952 is offline
post #8 of 8 Old 04-26-2010, 05:33 PM
1952
Im no expert but a lot of the time they rate those turbo's to engine hp not rwhp. Also he said he wanted 800+ hp. And another thing, you dont want to be maxing out the turbo and making it work a lot harder. A slightly bigger turbo would make the same power but spin a lot less.
New PB with turbo/auto combo Rich G Turbochargers 2 11-14-2009 11:19 PM
Low Comp 427 Turbo motor and Twin Turbo kit combo badass86coupe Windsor Engine Parts 7 10-23-2007 07:40 AM
turbo combo help power hungry Turbochargers 5 10-06-2006 06:51 AM
Is this turbo combo possible on a 302? Cougar232 Turbochargers 1 09-10-2004 03:20 PM
Need help with turbo combo! 2FAST4U2C Turbochargers 7 11-19-2003 11:29 AM
