boost question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-13-2010, 10:11 PM Thread Starter
boost question
How big of a difference is 10lbs of boost coming from a t70 compared to 10lbs out of a t76?
- 89 Turbo coupe
-2003 10th Cobra -Gone
-1995 Mustang GT Vert-stock- Gone
forbanger is offline
post #2 of 3 Old 04-13-2010, 11:51 PM
Close to if not Zero, unless either is out of its efficiency range. It's like asking what's heavier 5lbs of cement or 5lbs of feathers.
Blk&Gld 94 GT is offline
post #3 of 3 Old 04-13-2010, 11:56 PM
yep 10psi is 10psi
they would come on different and maybe fall in different efficiency
ranges and maybe make a little less or more heat, but not by much.
Only one would make power over the other is if you messed
with the turbine hot side, change a/r, tims, ect. .... then you change the whole
Ve of the engine by opening up or restricting the exhaust side.
r.barn is offline
Boost question mrbadford S-197 Mustang (2005-2010) 16 03-24-2008 10:59 PM
Boost Question 94GreenMachine Superchargers 11 03-17-2008 12:08 PM
Another Boost Question NIIIIICE Superchargers 6 10-01-2004 06:45 PM
Boost Question NIIIIICE Superchargers 2 09-24-2004 10:21 PM
A/F , Boost Question S-281 GT & SOHC 8 10-26-2002 12:23 PM
