One step colder autolites and crane hi6 what gap? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-11-2010, 11:56 PM Thread Starter
Blazin1320's Avatar
Trader Feedback: (18)
almost have the car back together. the only plugs i could find were autolite platium one step colder. Im going to be running a crane hi6 and need to know what i should gap the plugs at. Thanks.
Current Cars
03 V1'd gt
Previous mustangs 00 gt, 99 gt, 97 gt, 95 cobra, 94 turbo gt, 93 lx, 92 lx, 92 lx vert, 89lx, 3 86 gts, 79 notch
Blazin1320 is offline
post #2 of 11 Old 04-12-2010, 06:04 AM
Rich G's Avatar
Trader Feedback: (35)
I gap em at .028 or so..
Rich G is offline
post #3 of 11 Old 04-13-2010, 07:05 AM
1995gtCPE's Avatar
Trader Feedback: (34)
My car likes .030-.035, run the largest gap possible without spark blowout.
1995gtCPE is offline
post #4 of 11 Old 04-13-2010, 07:27 AM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
Re: One step colder autolites and crane hi6 what gap?
Both heat range and gap are influenced by boost. After a bunch of dyno time I ended up @.024 and a non protruding tip ngk 8. That was at 28 psi. Lower boost levels were ok with a larger gap but would start breaking up as we raised boost increased.
If you are going to the dyno bring a couple extra set of plugs. Don't waste money on high end plugs until the car is tuned, the first couple sets will be end up being swapped quickly.
mcj50 is offline
post #5 of 11 Old 04-13-2010, 12:58 PM Thread Starter
Blazin1320's Avatar
your in wall? we are pretty close im in toms river... where did you get tuned at? im gonna need a tune once the cars up and running.
Current Cars
03 V1'd gt
post #6 of 11 Old 04-13-2010, 02:24 PM
mcj50's Avatar
Psi performance in new tripoli pa, Frank Soldridge did the tuning. Worth the trip. I will send you a pm with more info.
mcj50 is offline
post #7 of 11 Old 04-13-2010, 04:26 PM
Trader Feedback: (41)
DO NOT USE PLATIUM PLUGS!!!
Start with a .028" gap.
stangjumper is offline
post #8 of 11 Old 04-14-2010, 12:22 AM Thread Starter
Blazin1320's Avatar
its all they had that was a colder step... what do you recomend
Current Cars
03 V1'd gt
post #9 of 11 Old 04-14-2010, 06:14 PM Thread Starter
Blazin1320's Avatar
ok i got some 764's one step colder coppers... thanks guys
Current Cars
03 V1'd gt
post #10 of 11 Old 04-15-2010, 12:24 AM
I went two steps colder and gapped to .028 and seems to be great!
mr_hahn73 is offline
post #11 of 11 Old 04-15-2010, 08:09 AM
89slowgt331's Avatar
Trader Feedback: (22)
let me know how the plugs work, got a simalar build with an f cam, and a 70mm on3 kit
89slowgt331 is offline
Crane Hi6 vs. Others dan50 5.0/5.8 Engine Tech 5 03-31-2009 12:36 AM
What spark plug gap with Hi6 and Autolites? blackstallion 5.0/5.8 Engine Tech 15 07-21-2006 08:57 AM
plug gap w/ hi6 93hostang General Mustang Tech 8 05-08-2004 08:12 AM
crane hi6 grippper 5.0/5.8 Engine Tech 3 04-02-2004 12:57 PM
1 step colder plugs and .37 gap for 125-150 dry shot daumustang Nitrous 9 11-16-2003 12:33 AM
