turbo cam help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 04-05-2010, 09:24 PM Thread Starter
Mustangspeedx89's Avatar
turbo cam help!
i have a 1991 5.0...it has older trick flow heads..race ported..typhoon intake..ported..75mm t/b..42lb injectors...1.6rr..and an all stock block..and a 70mm ball bearing cermic wheel turbo..need to know whats the biggest lift came i can put in the car...not worried about the duration i know what i need there its just the lift..o if somebody knows a good secert they can let me in on..i keep hearing that the E or F cam works good but the duration is 114 and i have read in mm&ff when they ran a big spread on how to cam a turbo they the most power from a 110 duration cam but most of there test were dont on 347's and dished pistions so i just kind of didnt look at the lift..thanks
No more 1989 GT....1991 LX now,70mm bb turbo,treadstone hot parts,typhoon intake,80mm tb, stock block,stock heads(for now),3.73's,M.S.D 6al & boost retarter & coil & wires.
Mustangspeedx89 is offline
For Sale 86 xr7 turbo motor w/a231 cam .60/.63 MINT turbo TURBOSTANG88 2.3L Engine Parts 7 04-29-2012 01:37 PM
351w BG CUSTOM TURBO Turbo headers carb, turbo cam,pistons,gaskets,waste gate stang1986 Power Adders 8 03-25-2008 10:55 AM
Cam Motion Turbo Ford 302/351 Solid Roller Cam TurboDR Windsor Engine Parts 1 03-12-2008 04:12 PM
FS: Jesel S/S Rockers & Cam Motion Solid Turbo Cam - NIB! boostedfoxbody Windsor Engine Parts 3 04-06-2005 02:19 AM
