Do you have an O-ringed block? come on in - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-09-2009, 02:43 PM Thread Starter
95stangsvt's Avatar
my new motor build is currently in an O-ringed block and im trying to decide what head gaskets to run i have got many diffrent opinions from local shops but im trying to see whats working for people out there currently running O-ringed blocks. I've hears to leave the wire in use a copper gaskets with lots of RTV,or to just leave the groove in the block pull out the wire and run a cometic.i dont want anything im gonna have rip back apart for leaks so im trying to stay away from copper and really dont want to get my heads machined with a receiver groove but i heard thats an option you dont have to with an Oringed block
9.5:1 333 ci Boss block
Dart Pro 1 heads
Precision PT70 16-18 Psi
95 Mustang-Let's just say it's a stock 302 with some bolt on's who really needs all the details
"racing from a roll is like masturbation, its good but it's just not the real thing."
95stangsvt is offline
post #2 of 5 Old 09-09-2009, 09:00 PM
94cobra2615's Avatar
O-ringed block here. I did it myself.
I *think* if you run copper gaskets with an o-ringed block you will need a receiver groove in the heads.
I run o-ringed block with stainless wire and use regular old felpro gaskets #8548 pt-2 (about $30 for em). My o-ring is directly on the fire ring and is crushed up into it when the heads are bolted down.
Since o-ringed I haven't had any problems. Some say it's old school, but it WORKS.
94cobra2615 is offline
post #3 of 5 Old 09-10-2009, 07:35 AM Thread Starter
95stangsvt's Avatar
i was thinking that too just leave the wire in and use like a MLS headgasket or cometic thats thick enough so the Oring dont cut all the way through the gasket just enough to bite into it when torqued...i really dont want to O-ring my new heads to use copper gaskets plus copper gaskets leak to much no matter how much RTV you use and you always have to retorque them
post #4 of 5 Old 09-10-2009, 07:25 PM
The felpro gaskets i use are just graphite.
You'll need to measure how high the o-rings are above the deck surface. That'll probably determine what gasket you use.
post #5 of 5 Old 09-12-2009, 01:07 AM
I run an o-ringed block. It's all about who did the work and where they cut the groove. I had mine setup to run 1011-2 felpro gaskets. Do yourself a favor and stay away from the cooper head gaskets for street use. I have seen too many of them that seap. As stated above, just checkand make sure the o-ring is crushing the fire ring on the gasket.
93 Lightning t-trim @15psi a/a intercooled,Windsor sr heads, tfsr intake, 75mm tb,full fuel sys 72lb, Fast xfi, be trans controller,built E4OD 2800 stall,1-3/4 longtubes 3" exhuast Auburn pro 87 Lx coupe (in progress) 393 stroker coated pistons/bearings built 4r70w. Rusertmachine.com
gpz 750 is offline
O-ringed heads w/ a non O-ringed block? Satan Jamez 5.0/5.8 Engine Tech 2 07-14-2007 01:51 AM
when a block is O-ringed? madmaxin22 5.0/5.8 Engine Tech 5 10-31-2005 12:40 AM
O-Ringed heads w/ O-Ringed Block? RedNotch1991 5.0/5.8 Engine Tech 8 08-13-2004 09:10 PM
anyone have an o-ringed block??? bdhollie Superchargers 4 10-05-2003 04:53 PM
Can you run o-ringed heads without the block being o-ringed? EvinH 5.0/5.8 Engine Tech 5 05-28-2002 10:41 AM
