$10 Voltage booster...will this work? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-06-2009, 11:29 PM Thread Starter
goatnipples2002's Avatar
Trader Feedback: (22)
Cheap Voltage booster...will this work?
I was posting about a cheap step up voltage transformer, but then I looked at the amp rating and it was too low. Since the Kenne Bell units are 20/40 amps I know I need atleast 40a continous for bigger pumps.
I have seen people use the boost a pump as a "boost a spark" could any ignition box be used as a BAP?
goatnipples2002 is offline
post #2 of 4 Old 09-07-2009, 01:36 AM
my8950's Avatar
Might help to explain what you are trying to do....
I personally don't really understand what you're after.
my8950 is offline
post #3 of 4 Old 09-07-2009, 11:30 AM Thread Starter
In case you didn't know BAP = boost a pump made by Kenne Bell or the MSD unit called fuel pump voltage booster. You boost the voltage to the fuel pump and it doubles in flow. So your stock pump now flows like a walbro unit.
post #4 of 4 Old 09-07-2009, 12:55 PM
my8950's Avatar
Yes, but your original post just said BAP, I assumed you meant Barometric Air Pressure, or whatever the Ford sensor is, baro sensor...
I have a Boost a pump, so I know what you're talking, but you're gonna need some big amps which is gonna cost a few bucks...I think the boost a pump is probably the best deal you're going to find...I'm curious about the MSD one though, I think it gives a few more options. i.e. ramping in voltage rather then just digital.
Are you looking for a BAP?
my8950 is offline
Voltage Booster Turbo98 General Mustang Tech 8 03-31-2006 12:31 PM
Anyone use an MSD Fuel Pump Voltage Booster or a Kenne Bell Boost a Pump???? 1993-306-GT Superchargers 5 02-21-2006 11:08 AM
F/S CHEAP:NEW NITROUS KIT: EDELBROCK 99/04 4.6 GT W/FUEL PUMP VOLTAGE BOOSTER streetstang95 Power Adders 0 06-09-2005 10:38 PM
FOR SALE: NITROUS KIT: EDELBROCK 99/04 4.6 GT W/FUEL PUMP VOLTAGE BOOSTER streetstang95 Power Adders 0 05-12-2005 03:20 PM
fuel pump voltage booster 91blowncoupe Superchargers 1 05-28-2003 01:02 PM
