Timing control question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-06-2009, 03:38 AM Thread Starter
jonyboy107's Avatar
Trader Feedback: (15)
I have an sct chip that can hold up to 4 tunes. I was wondering, can timing be contolled through the chip? Both timing and the advance? Or do I still need something like the msd btm or the timing lock pro?
Also, I would like to drive the car before I get it tuned a little on like 8psi off the boost controller... what should I set the timing at?
Thanks.
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #2 of 4 Old 09-06-2009, 06:43 AM
Trader Feedback: (36)
Yes the chip will and can control timing. As for now set the timing to 8* to 10* max (spout out) and listend for any signs of detontation. Should be fine
scotng is offline
post #3 of 4 Old 09-06-2009, 10:45 AM
Chip changes all parameters of the tune. Fuel/timing/idle, ect ect.
MSD multi spark is nice on boosted engines cause gives you the extra umf
on your spark, but you dont need it boost retard feature with a "chip"
r.barn is offline
post #4 of 4 Old 09-07-2009, 03:40 AM Thread Starter
jonyboy107's Avatar
okay... but is the car going to be REALLY sluggish with the spout out? How noticble will it be..
DAILY DRIVEN: 92 GT
MSD BOOST TIMING MASTER/Adj TIMING CONTROL slowpoint0 Electronics and Entertainment 7 05-21-2007 10:33 AM
what does everyone use for timing control ?? Strub1975 Turbochargers 3 07-31-2006 03:29 PM
MSD adjustable timing control box with dial control silrossi46 Electronics and Entertainment 3 10-02-2005 01:45 AM
Control arm bushing question- mac control arms Qwiketz General Mustang Tech 0 03-21-2004 06:45 AM
