maf/injector limits - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 09-03-2009, 09:23 AM Thread Starter
maf/injector limits
OK, couples questions:
1. What is the max hp level supported with 42# injectors? what about 60# injectors?
2. Can a Lightning MAF be used in a turbo application or no? What about like a Procharger or Vortech (centrifugal) application?
3. what HP levels can a 90mm Lightning MAF support?
4. How much HP can a SVT Focus pump REALLY support by itself? How about a SVT Focus pump with a KB Boost-a-pump?
5. Can cobra pumps or Ford GT pumps just drop i nthe stock 99-04 GT fuel tank or will they need modifcations to the tank? wiring?
6. How much power will the STOCK 99-04 returnless factory Fuel Line support? what size AN line is a good replacement to step up from that?
7. What injector rails are good out there? How far can the stock rails go before maxing out?
OK, so it wasn't a few . And Im sure I could sift through pages upon pages of search. But honestly, Ive looked and seen a bunch of mixed responses and dated information. Im wanting what the guys USING this stuff are, well, USING lol.
Thanks in advance!
2002 GT 4V swapped
2008 G8 GT Stock
CamFox is offline
post #2 of 9 Old 09-03-2009, 09:26 AM
smurfmobile8586's Avatar
Wink
making 620hp with the 60's no clue about the 42's
the l meter can be used in suck through
i dunno much bout the newer stuff , however there will be an army here shortly to help ya out
smurfmobile8586 is offline
post #3 of 9 Old 09-03-2009, 09:32 AM Thread Starter
I have no idea how much power I plan on making but honestly, I don't want to buy 2 setf o injectors. Kinda dumb lol.
I just wanted the opinion because theres an L-maf for sale locally cheap. if its not any good ill just save for like a SCT big air or something.
2002 GT 4V swapped
2008 G8 GT Stock
CamFox is offline
post #4 of 9 Old 09-03-2009, 09:33 AM
huafist's Avatar
I don't know about the MAF stuff - a good boosted setup will be running Speed Density instead of MAF anyway.
As far as injectors go, you can figure it out yourself using this formula:
IFW = (HP * BSFC)/(n * IDC)
where:
IFW = injector flow, in lb/hr
HP = target horsepower
BSFC = Brake Specific Fuel Consumption, typically between .55 and .60 for a boosted car
n = number of injectors
IDC = Injector Duty Cycle; I don't like going above 80%.
Knowing that, you can rearrange it to extract HP from a known flow #.
Same with the fuel pump ; you can figure how much fuel your pump needs to supply using the formula:
FC = (HP/740)*60
Where:
FC = Fuel Pump Capacity (gph)
HP = Projected Horsepower
GPH to LPH conversion:
LPH = GPH * 3.78
huafist is offline
post #5 of 9 Old 09-12-2009, 02:04 PM
made 832rwhp through an AUTO T400 trans with 60lbs inj and 60psi base fuel pressure.. this is equivalent to over 1000fwhp.
PLEASE EMAIL --->
<--- DO NOT PM for prices or tuning!
815-669-RACE (7223) <--- Sales
Please visit our e-store --->
Chicagolands largest Vortech dealer since 2006!
We stock many parts! If you dont see it, just ask!
Before you buy ANY mustang part, give us a chance. We accept mastercard and visa.
Authorized SCT, AEM, Diablosport, Vortech, Paxton, BS3, FAST, UPR, PA Racing, Harland Sharp, Team Z, GMS, Trickflow, Kooks, and MANY MORE!
flyin_hawaiin is offline
post #6 of 9 Old 09-12-2009, 06:02 PM
Thats a lot of pressure assuming 1-1 boost referenced regulator.
How much injectors will handle depends on the pump you run too.
Would def. want to make sure you run a high pressure pump.
So that it will still flow right at those higher pressures.
r.barn is offline
post #7 of 9 Old 09-12-2009, 09:50 PM
i would think if you are asking how much hp a 60lbs injector can handle, you will probably have the pump part of it covered..
PLEASE EMAIL --->
post #8 of 9 Old 09-12-2009, 09:58 PM
ratedz's Avatar
48lb Accell injectors
Walbro 255 pump
stock lines
stock rail
SCT BA2800 Maf
Any ideas on what that will support?
1986 Mustang GT
525hp/626tq
ratedz is offline
post #9 of 9 Old 10-08-2009, 11:46 AM
Radrick50's Avatar
Trader Feedback: (60)
Walbro 255 pump
stock lines
stock rail
SCT BA2800 Maf
approx. 500rwhp
93 Notch 347 twin 66s TH400...8.54 @ 162 Radials
91 Notch 410W Novi 2000 5 speed...10.99 @ 136
Radrick50 is offline
lightning maf limits? slo895.0 5.0/5.8 Engine Tech 5 02-28-2007 10:37 PM
Limits of stock MAF meter 93Krwy 94/95 Tech 9 03-23-2006 06:14 PM
C&L MAF 80 mm for 42 lbs injector + 92 PRO M 92mm for 75 lbs injector MatStAnG2k Fuel System & Related 1 05-11-2005 08:52 PM
WTB: 24# injector/MAF, FS: Bosch Injectors/Maf 88sc_gt Electronics and Entertainment 1 11-05-2004 10:39 PM
19 lb injector and 94/95 maf 92rohcp Fuel System & Related 3 08-28-2004 01:29 AM
