What transmission to use 600lbs torque - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 40 Old 09-02-2009, 10:17 PM Thread Starter
Trader Feedback: (43)
302 HCI turbo 525 rwhp and 531 lbs of torque.
Burned up a centerforce in a month and shreaded 3rd gear in my tremec tko 3550 on street tires no hard shifting.
What should I do now.....I would sorta like to keep stick but a nice 4 speed auto would be very temtping.
Car has a 3.27 gear and its mainly street. I would like to use the highway too.
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #2 of 40 Old 09-02-2009, 10:30 PM
Lentech AOD time.
Get good shifter and you can still bang gears, just no pedal work
r.barn is offline
post #3 of 40 Old 09-02-2009, 10:35 PM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
TKO600 here. yet to bang gears on stickies. but i will find out in time.
i would put an Auto in that. more of a smooth rush of power and not as much boost drop between shifts cuz they shift so damn fast.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #4 of 40 Old 09-02-2009, 10:48 PM
Originally Posted by r.barn View Post
Lentech AOD time.
+1
Joyrider564 is offline
post #5 of 40 Old 09-02-2009, 11:16 PM Thread Starter
I would like to get a new lentech, anyone know a way to get a good deal on one?
post #6 of 40 Old 09-03-2009, 05:51 AM
Rich G's Avatar
Trader Feedback: (35)
PA Supercomp AODE
Rich G is offline
post #7 of 40 Old 09-03-2009, 07:20 AM
fred50stang's Avatar
A built th400 and you'll wished you done it sooner.
fred50stang is offline
post #8 of 40 Old 09-03-2009, 12:34 PM
Automatic...
I love my 4r70w. I'm on the original 87k mile trans that came in the car, ( 01 GT) and have been putting down well over 600 ftlbs for the two years of daily use/abuse, and just lately over 700 ftlbs. It's still together and acting as it should. They are stout transmissions, if you want to have overdrive.
poostang is offline
post #9 of 40 Old 09-03-2009, 05:01 PM
331merc's Avatar
AOD or 4R70W. Built right they hold a lot of torque. Most local shops can build you a version to hold 600tq for much less than Lentech. You can also check out www.clickclickracing.com. There is a lot of info and tech articles over there. They can tell you what to do and where to get the parts for wholesale.
Your not terribly far from me. I can give you the name and number of the guy who does my AOD. Very reasonably priced and mine has been in the 9's, put over 600tq to the tires through it with the turbo and hope to throw more at it once the combo gets dialed in. I want to run 8's with it.
If OD is not a concern the TH400 is a great choice. Can get costly when you add the conversion parts into the cost as well. But you can get a STRONG th400 if you need one.
Good luck.
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
post #10 of 40 Old 09-03-2009, 05:16 PM
pennex1's Avatar
+2. You will never look back and with plenty of room for future growth!
Dart 347, High Ports, FAST XFI, TH400, Precision 78GTS,E85, 836hp 714tq.
pennex1 is offline
post #11 of 40 Old 09-03-2009, 06:39 PM
Rich G's Avatar
yea until your on the highway and the motor is turning 4500 rpm... if your doing any street driving get an OD tranny
Rich G is offline
post #12 of 40 Old 09-04-2009, 09:16 AM
ssj50driver's Avatar
There is always a t56 if you wish to keep it stick. With an upgraded input shaft 600 lb-ft torque is easily harnessed. Matched up with a twin disc clutch and you are good to go. There are some other single clutches that will hold up as well. Clutch dynamics (I think that is the company) comes to mind. They have good prices as well from what I hear millhouse likes them. If your car is mostly drag I say go auto but mostly street, I personally like a stick. Everyone is different, get what YOU want. GL.
ssj50driver is offline
post #13 of 40 Old 09-04-2009, 03:57 PM
Built TH400 here as well.... I LOVE it
Nothing but slow chebby's right now.....
OrangeSVT03 is offline
post #14 of 40 Old 09-04-2009, 09:15 PM Thread Starter
I have a clutch dynamics clutch and so far its holding up fine.
I do not want to put a another stick in and have issues.
You think a tremec tko 600 will hold up?
Damn turbos
post #15 of 40 Old 09-04-2009, 09:22 PM
Moderator
eleanorfox's Avatar
tko600 can take a crap ton of abuse. people complain about its notchy shifting and high rpm shifts. but i don't think it is tat big of a deal.
2015 Chrysler 300 S
post #16 of 40 Old 09-04-2009, 09:51 PM
Centerforce DFX
T56
www.ccimotorsport.com
tommygun is offline
post #17 of 40 Old 09-05-2009, 04:14 PM
If you go auto would you want a lock up or non lock up converter?
got9lbs is offline
post #18 of 40 Old 09-06-2009, 05:38 PM Thread Starter
took the trans apart and only the 3-4 gear slider is hurt, the rest looks great.
So i think we are going to fix her up and put it back in for the time being.
post #19 of 40 Old 09-06-2009, 10:16 PM
♥ wendy ♥'s Avatar
We had a tko 600 and switched to a glide, should have done it a long time ago. As far as the street without an od ?? with the 3.27 gear it was great. 2200/2500 at 65ish doesn't get much better than that.
john
1991 lx turbo notch
♥ wendy ♥ is offline
post #20 of 40 Old 11-28-2009, 01:06 PM Thread Starter
Any thoughts on this transmission holding up and being a fun machine on the street?
https://forums.corral.net/forums/show....php?t=1180289
post #21 of 40 Old 12-19-2009, 12:31 PM Thread Starter
Nevermind, 3rd gear was stripped off the woodruff key and my new AOD is sitting here.
Merry xmas.
post #22 of 40 Old 12-19-2009, 01:50 PM
Rich G's Avatar
Merry xmas.
woot auto !
Rich G is offline
post #23 of 40 Old 12-19-2009, 07:30 PM
331merc's Avatar
If it is built right you will really like it.
331merc is offline
post #24 of 40 Old 12-19-2009, 07:36 PM
cammincoupe's Avatar
that is why i went auto the 5 spd just wasnt cutting it..lol
cammincoupe is offline
post #25 of 40 Old 12-20-2009, 02:43 AM
Djstorm100's Avatar
I'm at 2,900 rpm at 75. c4. 3:27 275/60/15
Djstorm100 is offline
post #26 of 40 Old 12-20-2009, 07:27 AM
Rich G's Avatar
k
Rich G is offline
post #27 of 40 Old 12-20-2009, 09:35 AM
millhouse's Avatar
I'm turning a touch over 2000 rpm at 75 with a LOCKED converter. 4r70w 3.27 235/60/15
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #28 of 40 Old 12-20-2009, 09:57 AM
Rich G's Avatar
+1 lol
Rich G is offline
post #29 of 40 Old 12-22-2009, 12:36 AM
mob
mob's Avatar
Trader Feedback: (15)
I have an old stock C4 out of an older (60's) mustang. If that is rebuilt can that hold a lot of power? As for the 4r70w, can you get one from a junkyard and have them hold a lot of power or do you need to rebuild them? Also what about the stock mustang 5.0 AOD's?
GT40P Heads / B303 Cam / Explorer Intake / FMS Shorty headers / KC Clutch / OR H pipe / 3.73
Street Tires
[email protected] 2.2 60'
mob is offline
post #30 of 40 Old 12-22-2009, 01:22 AM
Djstorm100's Avatar
my c4 uses the rear drum out of a 4r70w. has to machine it but holds tons of power
post #31 of 40 Old 12-22-2009, 02:12 AM
The 1970 and later c4 is the one to use and if you can get a c5 it has some stronger parts and all the lube mods that you would do to a c4. it is very hard to find a really good valve body for a 1969 or earlier c4 and it also has a smaller input shaft. You can pick up a used c4 or c5 really cheap to build up
Drew5.0 is offline
post #32 of 40 Old 12-22-2009, 10:16 AM
a firend is running a promotion tko600 that puppy will go in gear at 8200rpm if we want it to old 347 was reving this hight granted there no more syncro in the trans but it still can be driven on the street
331 laid down 415whp n/a whit the old combo know probably more like 425-440whp shifting at 7200-7600 its been holding running between a 250and 350shot right off the line
dont get a to agressif of a clutch go look on promotion web site where running the 750hp set up but its slipping bad now on the 350shot its about the limit of the trany and clutch set up but where still pushing it looking for 8.90 out of the car then will call it quits best so fare a 9.18 350shot and 9.30 250shot
lov2xlr8 is offline
post #33 of 40 Old 12-22-2009, 07:13 PM
Trader Feedback: (61)
viper 6 speed 700 rw power thew it
408wd1 is offline
post #34 of 40 Old 12-22-2009, 10:30 PM
mob
mob's Avatar
How is the stock 5.0 AOD?
Street Tires
mob is offline
post #35 of 40 Old 12-23-2009, 02:11 AM
could always do a T56 magnum, it's rated at 700 ft/lbs
karrarararararar is offline
HOW MUCH TORQUE CAN MY 1993 transmission HANDLE svtcobra323 General Mustang Tech 2 11-27-2008 09:54 AM
C-6 transmission torque converter question drkelly General Mustang Tech 3 02-14-2007 11:22 AM
Transmission Specialties torque converters black86notch General Mustang Tech 0 02-15-2004 09:40 AM
Transmission Recommendation - KB 2200 has too much torque Conv89GT Superchargers 11 07-29-2003 10:58 AM
Is my transmission or Torque Conv. going bad? Or what? BlackRein Six Shooter 1 04-26-2003 09:24 AM
