Too much turbo shaft play?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-26-2009, 03:22 PM Thread Starter
Radrick50's Avatar
Trader Feedback: (60)
Question Too much turbo shaft play??
I just picked up a used B&G turbo kit for my fox. It has the standard MP T-70 with it. The impeller and the turbine appear to be perfect, and if I spin the shaft it spins freely with no noises. BUT, I can gently push the impeller to the side of the housing and cause enough interference that you cannot freely turn the shaft anymore. As soon as I release the easy side pressure, I can spin the shaft freely again with no noise.
I know that there needs to be some play (clearance) allowed for the oil, but I've never seen the play cause interference.
Will this thing be OK once oil is fed to it during normal operation or is this a ticking time bomb?
Let me know what you think.
93 Notch 347 twin 66s TH400...8.54 @ 162 Radials
91 Notch 410W Novi 2000 5 speed...10.99 @ 136
Radrick50 is offline
post #2 of 3 Old 08-27-2009, 12:07 AM
El_Diablo's Avatar
time for a rebuild or a new unit.....
El_Diablo is offline
post #3 of 3 Old 08-27-2009, 09:28 AM Thread Starter
Radrick50's Avatar
Question
Is it worth the cost to have a MPT-70 rebuilt? Where do you get them rebuilt at and how much does it cost? Can I do it myself?
steering shaft play uchi General Mustang Tech 5 06-14-2008 03:38 PM
Distributor Shaft Play RED95GTCOUPE 5.0/5.8 Engine Tech 7 05-07-2007 07:11 PM
Shaft play 03BlackWidow Turbochargers 2 01-25-2006 01:15 PM
Axle shaft....why is there play in it? fiveohfanatic General Mustang Tech 6 11-28-2003 08:47 PM
SHOULD A T-70 HAVE ANY SIDE PLAY IN THE SHAFT?? MINN50 Turbochargers 3 02-17-2003 02:07 PM
