Motors out, what to put on it while its out - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-25-2009, 04:07 AM Thread Starter
jonyboy107's Avatar
Trader Feedback: (15)
Im getting ready to start putting my mustang back together with the new turbo setup. What can I do while the motor is out to help ease the turbo installation?
Thanks.
DAILY DRIVEN: 92 GT
306,9,5:1,AFR 185s,RPMII,xe264hr,ProMagnum rockers,turbonetics 66S,bg kit,METH,Flowmaster catback,Accufab race 75mm,pro tube,60lb injectors,255lph walbro BAP,ac delete,no smog,full MSD ignition,mark fan,3G alt,TKO600,spec stage 3,alum flywheel,3.55s
jonyboy107 is offline
post #2 of 15 Old 08-26-2009, 11:13 AM
Angry_Man's Avatar
Is it the combo in your sig?
Angry_Man is offline
post #3 of 15 Old 08-26-2009, 02:07 PM Thread Starter
jonyboy107's Avatar
Nope, 306 9.3:1 same cam heads intake though. garrett t76 .96 ar ptrim wheel with a bg cold and hotside turbonetics wastegate, hks bov, hks evcez bc, 60lb injectors, labonte stage 3 meth kit, blah blah blah.
DAILY DRIVEN: 92 GT
post #4 of 15 Old 08-27-2009, 12:16 AM
An aftermarket block
LowboostinT76 is offline
post #5 of 15 Old 08-27-2009, 11:09 PM Thread Starter
jonyboy107's Avatar
only looking ot make 500whp...
DAILY DRIVEN: 92 GT
post #6 of 15 Old 08-27-2009, 11:20 PM
Then why a t76 with a .96 hotside? For future growth?
post #7 of 15 Old 08-28-2009, 01:55 AM Thread Starter
jonyboy107's Avatar
That, and it was a good deal.
DAILY DRIVEN: 92 GT
post #8 of 15 Old 08-28-2009, 04:04 PM
Erich's Avatar
ARP head studs. Maybe cut receiver grooves in the heads.
Definately mock up your setup on the engine stand and take pictures of it. You will thank yourself later.
Erich
Erich is offline
post #9 of 15 Old 08-28-2009, 04:10 PM
#### o-ringed head gaskets! Thats old tech and I would never use them.
Run some cometic or felpro mls gaskets.
post #10 of 15 Old 08-28-2009, 05:16 PM
Erich's Avatar
Then you can have both your block and heads resurfaced to accept them.
Erich
Erich is offline
post #11 of 15 Old 08-28-2009, 05:39 PM
Haha, as if you don't need any machining for a lock wire gasket!
Reciever grooves suck.
I only had my heads machined for the surface and have held over 20psi no problems.
Resurfacing a head doesn't remove as much material as cutting reciever grooves. Also if I did ever lift a head all I'd have to do is get them decked, you would need to deck and recut your grooves. And putting a reciever groove in the block would be the dumbest thing to do if you ask me.
Keep running your crap lockwires cause your heads already have the grooves, but don't influience people to do it cause you think its the way to go since you do it that way.
post #12 of 15 Old 08-29-2009, 03:18 PM Thread Starter
jonyboy107's Avatar
in asking questions as far as the turbo install goes... I already have the motor put together.
DAILY DRIVEN: 92 GT
post #13 of 15 Old 08-29-2009, 03:24 PM
Then put in nothing, I install my whole turbo system only once the engine is in.
post #14 of 15 Old 08-29-2009, 03:48 PM Thread Starter
jonyboy107's Avatar
yeah/ What about the hotside?
DAILY DRIVEN: 92 GT
post #15 of 15 Old 09-07-2009, 02:02 PM
I would install the headers if you can get it back in with them on. It will help a little. The rest really needs to be done after the motor is in.
While its out a custom ground turbo cam would be something to consider.
JasonT is offline
what heads were put on 94+ 351w motors? wldtang 5.0/5.8 Engine Tech 2 04-27-2007 12:48 AM
Forgot to put exhaust crossover gaskets when I put lower intake on, will it be ok? 87gt5.1 5.0/5.8 Engine Tech 3 05-22-2002 05:49 AM
4 V motors Dennis Reinhart GT & SOHC 39 05-07-2002 06:41 PM
I forgot to put this on as I put the lower intake on...do I REALLY Need it?? J-Dawg 5.0/5.8 Engine Tech 2 03-11-2002 02:05 PM
Why do turbo motors 'last longer' than blower motors? rammer GT & SOHC 47 12-30-2001 11:53 AM
