Listem if you gottem looking for Sbf turbo with stock block - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 08-24-2009, 09:07 PM Thread Starter
Louis Rowe's Avatar
Like the title says i am looking for stock block turbo combos mainly 302 based
stock or aftermarket heads fi or carbed.
I am thinking of doing this but i wanted to look in to it more
I postd this once but in the wrong section
sorry
Louis Rowe is offline
post #2 of 29 Old 08-24-2009, 11:13 PM
jturmanator's Avatar
You can see my numbers in my signature.
jturmanator is offline
post #3 of 29 Old 08-25-2009, 07:23 AM
millhouse's Avatar
Siggy
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #4 of 29 Old 08-25-2009, 05:07 PM
stock 5.0 with arp hardware, [email protected] mpt70
Turbomustang
Mesarina is offline
post #5 of 29 Old 08-25-2009, 05:39 PM
procomp 210cc 2.02" 64cc heads, typhoon intake f-cam, 30lbers, fmu, no tune, 70mm single. mid 10's.
JBIGBOOTSY is offline
post #6 of 29 Old 09-02-2009, 07:05 PM
Coupe8893's Avatar
Bone stock 93 ssp car with a hp turbo 66mm made 385hp and 490 at the tires, I tuned with the tweecer and 10psi. 2500 miles later I broke 3 pistons but they didn't have forged pistons in 93. when I say stock I'm saying throttle body to oil pan.
93 347 t76 C4
89 5.0 5spd upgrading soon
Coupe8893 is offline
post #7 of 29 Old 09-02-2009, 11:04 PM Thread Starter
Louis Rowe's Avatar
Thanks guys keepum coming
post #8 of 29 Old 09-03-2009, 05:50 AM
Rich G's Avatar
Trader Feedback: (35)
sig
Rich G is offline
post #9 of 29 Old 09-03-2009, 08:37 AM
blackbob's Avatar
331 Short block
GT40P heads
E303 cam
On3 Turbo kit ( yeah yeah yeah whatever )
Qaurter Horse Tuning
No numbers as of yet since we have yet to make it to the track.
05' GTO - M6 Impulse Blue/Blue
98' WS6 Racecar Project
sosmotorsports.com
blackbob is offline
post #10 of 29 Old 09-03-2009, 09:08 AM
huafist's Avatar
306ci, stock rods/crank, cast .030" overbore pistons, GT-40P heads with dual springs, X-303 cam, 1.6 Roller/Rockers, twin 50 trims, 72# injectors, stock intake & throttle body. Tuning with Megasquirt II v3 running ms2 extra code.
As soon as I get a couple of 2.5" VBand clamps, it's going on the dyno.
huafist is offline
post #11 of 29 Old 09-06-2009, 12:39 PM
How well are the stock longblock turbo cars holding up, head gasket wise, with the stock E7's?
mustanggreg is offline
post #12 of 29 Old 09-06-2009, 12:41 PM
brian15's Avatar
all in the tune! ive only had to replace mine once due to a boost controller malfunction.
im using arp head bolts and some cheap fel pro gaskets too.
brian15 is offline
post #13 of 29 Old 09-06-2009, 05:05 PM
goatnipples2002's Avatar
Trader Feedback: (22)
stock bottom 302
Garrett TP38 (Damn near same map as a 62-1)
ms1 v2.2 extra
f303
72 351w heads
Cartech upper
Holley lower
C.A.T. Shaft rockers
I have arp head bolts and ROL head gaskets
About to try E85
goatnipples2002 is offline
post #14 of 29 Old 09-06-2009, 05:28 PM
ManicMike's Avatar
Stock '90 bottom end (56k miles), GT-40 heads, E-Cam, explorer u/l intake and 70mm TB. Currently the Master Power T70 is being put on. Power should be in the neighborhood of ~450whp, should be enough to haul the coupe into the 11's.
'88 LX -New mill coming soon.
ManicMike is offline
post #15 of 29 Old 09-06-2009, 09:10 PM
♥ wendy ♥'s Avatar
We had 140k stock shortblock with tw trackheat heads and a f-cam. With a carb and 15psi with no intercooler made 577rwhp. That was with a vecco style cheap kit and a 62mm turbo
john
1991 lx turbo notch
♥ wendy ♥ is offline
post #16 of 29 Old 10-02-2009, 12:00 AM
Trader Feedback: (46)
Stock block,306, stock cam, TFS heads, Hogan box intake, Master Power T70 turbo with 14lbs, with a C4 made 531RWHP & 534RWTQ
racsirx is offline
post #17 of 29 Old 10-02-2009, 10:43 AM
Can you post picks of the Hogan?
post #19 of 29 Old 10-02-2009, 03:52 PM
john
good times . . . I was always wondering what I was giving up by keeping the e7s.
my combo:
stock shortblock
ported e7s
ported x-celerator
f-cam
Holset H1E (roughly 62-1)
505rwhp and 559rwtq on 15psi
streetfalcon is offline
post #20 of 29 Old 10-04-2009, 12:32 AM
bossjb50's Avatar
331 stroker using Mexican block 302 as a starting point
ported twisted wedge heads, spyder style intake, custom grind solid roller cam
PT6776 turbo running 9 lbs. Makes 570 hp and 580 tq at the wheels with a crappy tune.
bossjb50 is offline
post #21 of 29 Old 10-04-2009, 02:30 PM
gt5Ostang86's Avatar
101k stock block,stock heads,stock rockers,stock crank pulley,trickflow stage 1 cam,trickflow street upper and lower with a cartech kit(66mm) i made 387 rwhp and 435rwtq on 8 pounds with a safe tune. I'd say my #s are pretty damn good
06 S281 Saleen-pulley,catless x,cai,gt500 dual pumps,injectors,tune
92 notch-4banger-DD
91 Gt turbo'd-Sold
gt5Ostang86 is offline
post #22 of 29 Old 10-05-2009, 01:07 PM
Radrick50's Avatar
Trader Feedback: (60)
2-bolt 306, stock crank & rods, Eddy performer heads, GT-40 intake, cartech T-66 kit, 42s...I don't know the rwhp, but It ran 9.94 @139 with a braked C-4...It lasted for 5 years before I cracked the block.
I'd say the stock block can handle some decent power if you take your time with the tune.
I never had a dyno tune...just timing and fuel pressure adjustment to get it right at the track.
93 Notch 347 twin 66s TH400...8.54 @ 162 Radials
91 Notch 410W Novi 2000 5 speed...10.99 @ 136
Radrick50 is offline
post #23 of 29 Old 10-05-2009, 01:12 PM
Radrick50's Avatar
That is a sweet, simple combo...I love it!!!
post #24 of 29 Old 10-05-2009, 08:24 PM
thanks Im gonna try and break the 400rwhp barrier with a under drive crank pulley
92 notch-4banger-DD
91 Gt turbo'd-Sold
post #25 of 29 Old 10-05-2009, 08:59 PM
ManicMike's Avatar
Using a stock '90 bottom end (56k miles), GT-40 heads, E-Cam, explorer u/l intake, 70mm TB and a custom 70mm single kit. Car made 360rwhp/390rwtq on 5 psi.
She goes back next week to up the ante and shoot for 14psi. If my calculations are correct, it'll be over 500whp.
post #26 of 29 Old 10-05-2009, 09:30 PM
i wouldnt try 14pounds put it up to 9 and youll definitely hit 4ish with the heads,im bumping mine up to 13 when i meth her. I just wanna see how much power i can get with completely stock heads and rockers
92 notch-4banger-DD
91 Gt turbo'd-Sold
post #27 of 29 Old 10-05-2009, 10:43 PM
ManicMike's Avatar
10/12 will be for the street tune, then ramp it up to 13/14 for the track. It'll handle it, I have full confidence in this tuner.
post #28 of 29 Old 10-05-2009, 10:51 PM
billyNOTnice's Avatar
Trader Feedback: (80)
I ran 14psi all day for 2 years.... stock non forged 93 cobra bottom end.. edelbrock H,I, F cam.... ####ty pass 11.0 @ 131.8 ....
----------Dart 363 Turbo 93 Cobra #3193----------
--------------Magnum T56--------------
billyNOTnice is offline
post #29 of 29 Old 10-05-2009, 11:11 PM Thread Starter
Louis Rowe's Avatar
very nice times guys i know i am putting up my money now untill i can get a kit and i hope it does as good.
Listem if you gottem looking for Sbf turbo with stock block Louis Rowe 5.0/5.8 Engine Tech 17 08-25-2009 08:38 PM
SBF Turbo/Blower short block Forsale/Trade... BK50 Windsor Engine Parts 34 04-21-2009 08:10 PM
Stock block + Turbo GASVT Turbochargers 15 03-15-2008 09:37 AM
twin turbo on stock block slow5 0 Turbochargers 15 08-16-2003 03:06 AM
