**NON BLOW THRU CARB ON A TURBO SETUP** - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-23-2009, 02:12 PM Thread Starter
Banned Alleged Scammer
CAN YOU USE A **NON BLOW THRU** CARB ON A TWIN 60MM SET-UP. IF SO WHAT SIZE AND HOW MUCH BOOST. IM THINKING OF A NEW MOTOR BUILD AND TRYING TO GET SOME INFO ON THE TURBO BLOW THRU CARB STUFF. OR WHAT ABOUT A NON BLOW THRU CARB FOR A PROCHARGER SETUP??? THANKS IN ADVANCE FOR ANY REPLIES
post #2 of 12 Old 08-23-2009, 02:53 PM
Go to turboforums.com,they can answer all your questions and then some.
Alan VanBuren is offline
post #3 of 12 Old 08-23-2009, 02:58 PM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
vortech sells that whole case you put your carb into for this. i think that is the only way.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #4 of 12 Old 08-23-2009, 03:27 PM
Yep,Eleanor is right.If you want to use a non-blowthru carb,you need a carb enclosure like the the vortech.If you use a carb hat like EVs,you need a blowthru specific carb.Hope this helps a little.
post #5 of 12 Old 08-23-2009, 09:59 PM Thread Starter
thanks guys
post #6 of 12 Old 08-25-2009, 02:40 PM
I have a d1sc blowthrough set up. I used a 675 rs series barry grant carb, that wasn't designed for blowthrough and it works good with a carb hat.
snkklr is offline
post #7 of 12 Old 09-06-2009, 09:22 PM
♥ wendy ♥'s Avatar
The "boxes" are a pain in the but and you do not need a "blow thru" carb. Just about any carb will work. Even on small engines a 750cfm works great. We had a 363ci and a 750 that made over 740rwhp
john
1991 lx turbo notch
♥ wendy ♥ is offline
post #8 of 12 Old 09-07-2009, 02:26 PM
For clarification;Is the carb modified for blowthru?Nitrophyl floats,milled choke horn,brpv,etc?
post #9 of 12 Old 09-07-2009, 02:47 PM
♥ wendy ♥'s Avatar
The floats need to be changed and as far as the brpvs it all depends on the combo. My wagon didn't need them, our mustang did and my buddy's car did not. Vent tubes and homemade brpvs can be made, but you don't need to spend alot of money to make it work.
If you do the box, you still need to change floats and just cause it's in a box doesn't mean it will flow enough fuel on it's own.
1991 lx turbo notch
post #10 of 12 Old 09-07-2009, 03:15 PM
Ok ,it was modified for BT.Way it sounded,you were just sticking a standard holley DP on and boosting it...lol!
post #11 of 12 Old 09-07-2009, 03:46 PM
♥ wendy ♥'s Avatar
you should know better than that...nothing in the aftermarket is bolt on!! lol
1991 lx turbo notch
post #12 of 12 Old 09-07-2009, 04:04 PM
thats true..lol!
blow thru carb/turbo parts biggs92 Power Adders 4 02-11-2009 12:30 PM
Anyone on here running a carb blow-thru setup? blk91coupe Nitrous 1 12-17-2005 07:21 PM
blow thru carb setup mustangman902003 Turbochargers 1 09-08-2005 10:08 PM
Blow-Through Carb, SC Setup. Suggestions please... Kobra4Kris Superchargers 13 05-04-2005 10:10 PM
[B]WTB Carb Hat for Custom Blow thru setup[/B] Cougar232 Power Adders 1 10-15-2004 01:07 PM
