Building 4.6 question? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 08-19-2009, 11:33 PM Thread Starter
How much would it cost me to build the bottomend and refresh just the top. I just want the bottomend to be very strong, so that I can throw the boost to it.
nbatchler is offline
post #2 of 11 Old 08-20-2009, 01:25 AM
2002mustanggt's Avatar
MMR 900 for about 3k when you done. 900hp should be enough for you ?????
2002mustanggt is offline
post #3 of 11 Old 08-20-2009, 11:17 AM
MustangSR330's Avatar
MMR short blocks are definitely the cheapest and easiest route to go.
MustangSR330 is offline
post #4 of 11 Old 08-20-2009, 04:33 PM
sid_02gt's Avatar
Wink
MMR will be the easiest. I got really lucky and pieced together a stroker rotating assembly for $1300. (Kellogg crank, probe pistons, and manley h-beam rods) After machine work and balancing I should have under $2k in my shortblock that will handle 750-800hp. Everything adds up quick. If you want to build it yourself, MMR has some nice rotating assemblies at good prices.
But before all this you need to figure out your horsepower goal, and how your gonna get there. ie.. how much max boost, what compression ratio, what it's going to require for fuel and tuning, what cams (if you need to notch pistons), think about everything before you start spending money. You dont want to buy parts that will only get you so far, and then have to spend extra to make it to your goal.
hope this helps.
Sid
NOT ALL PEOPLE SHOULD HAVE THE RIGHT TO REPRODUCE
Mineral Grey 2002 GT.SOLD
Mineral Grey '02 GT GMS k-member, coilovers, P&P heads, Typoon intake system, magnaflows, 5.0 stroker and On3Performance T-70 turbo kit, Sniper Tuning.
sid_02gt is offline
post #5 of 11 Old 08-20-2009, 05:24 PM Thread Starter
I just dont know how much longer my motor is going to last with the turbo on it.
post #6 of 11 Old 08-20-2009, 05:38 PM
Im in the process of building my 4.6 aswell. I am using 03 cobra rods and pistons and im goin to have my stock crank balanced if i cant find a forged one in good condition. I will be puttin a turbo on my car as well but dont plan on makin much more than 600 so i should be good with what im using. After all said and done with main and head studs, notched pistons and all the machine work i will be under 1500.
cinch02 is offline
post #7 of 11 Old 08-20-2009, 09:06 PM Thread Starter
so if I did just build the bottom end, could I get 600rwhp?
post #8 of 11 Old 08-20-2009, 09:58 PM Thread Starter
hope this helps.
Sid
Do u think I could just get rods and pistons from a cobra for a reasonable price and just install them in my car. Because them cobras will handle 600rwhp all day long. I just wish I knew where to get the rods and pistons, bearings to make this happen.
post #9 of 11 Old 08-20-2009, 10:32 PM
04Ryan's Avatar
http://www.modularmustangracing.com/
Those guys have everything you need...I wouldn't mess with trying to find Cobra parts. Plus your gonna want to bore the block .20 over to get a the best seal possible for the new rings. Especially with boost! Which means stock size Cobra pistons will be useless.
BTW...which K member are you running with your turbo kit?
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #10 of 11 Old 08-20-2009, 11:12 PM
sid_02gt's Avatar
I don't know if i would go with all the cobra stuff. I think the pistons would get you too high of a compression ratio for your turbo set up. The rods and crank should work fine. Do some searches on ebay. I paid $175 for my probe piston brand new in the box. And $290 for manley H-beam rods new in the box. I would at least go with a cobra crank over the stock 6-bolt.
sid_02gt is offline
post #11 of 11 Old 08-20-2009, 11:59 PM Thread Starter
What come in the 03-04 Cobra Mustang far as Pistons and rods?
Question on motor i'm building. soonerbomb 5.0/5.8 Engine Tech 6 12-13-2005 06:04 AM
engine building question, please help fordman1 5.0/5.8 Engine Tech 4 05-13-2005 10:24 AM
Engine Building question 99RoushStage1 GT & SOHC 3 07-02-2004 07:48 AM
engine building question 96gtmustang GT & SOHC 6 07-22-2002 05:44 PM
Building a 331 and have a question? R302mustang 5.0/5.8 Engine Tech 3 06-27-2002 06:32 PM
